Question about Toshiba Portege S100-S1133 Notebook
Toshiba protege 100s
Have taken it apart to service the fan put it together and it wont turn on but i have a little bit i have not put back . a metal piece almost t shape i would suspect it to be an earth some where
I have taken my acer aspire apart to clean the fan,, when I put it bk together the screen does not come on,,any idea on what to do ?
Can you be more spacific? Did you pull it fully apart eg, the whole case. If so make sure the ribbon or conectors are connected back to the board, even the slightests bit off can cause it to not work.
Jan 27, 2015 | Acer Aspire Computers & Internet
I have clippers model number HC95WV. I can not get blades back together
Ok place the small metal cutter on top of the large metal comb, place the white plastic piece into the top of the cutter with the protruding bit at the back, place the metal bracket with 4 holes on top first locating the front into the white plastic slot, then place the last metal bracket on top with the raised part to the front, then simply hold it all together and put the screws in form the back!
Hope I got the right blade style!!
Mar 18, 2014 | Conair Health & Beauty
Marcy Upright Fan Cycle - Fan Hitting Cage As It Spins
You did great with the assembly, however, you're off on the alignment. Try to adjust to pull the axle in the opposite direction to clear the cage.
Nov 11, 2013 | MARCY MCPL 105 Upright Fan Bike
I had to replace my twist shifter cable for the front deraileur. A small metal "V" shaped piece dropped out, how do I put this back in and at what position.
Those are pretty tough to replace... The shape of the plastic shifter case should be your guide- there's a little nook that the v-shaped metal sits in. I *believe* that the side with the little bump-out goes towards the middle of the shifter- but you could look for what's called an "exploded diagram" of your shifter online (use the numbers & letters on the shifter for your search). Then you have to line up the two parts correctly (with the number 7 on one part at the little white line on the other) and twist them back and forth just a little bit while you push them together. Sometimes those little guys are impossible to put back together once they've come apart. You could find a cheap replacement for around $25- or try used!
Oct 24, 2010 | GMC Denali 700C Road Bike
Do i fix the tray that wont open on my xbox 360
Either you have something sticky spilled on your unit, or you may have to replace the motor for the disc tray. Also take note if the tray is even attempting to open at all. If so, it might just need to be cleaned.
Oct 01, 2009 | Microsoft Xbox 360 Console
I have a toshiba A135-S4656. The fan needs replaced or a cleaning
Getting to the fan on your laptop is VERY DIFFICULT. There's a lot more screws, wires and snaps holding the computer together than you'd imagine. It's best to get a professional to do it, however less and less people these days are willing to pry open someone's laptop because a lot can go wrong.
If you've backed up your laptop and are willing to risk not being able to put it back together, then go ahead. To get to the fan you actually need to get through the top. Unscrew every screw you can find on the back and the bottom. You'll need to open up the hard drive and motherboard because there's screws there too. Pry off the piece covering your speakers, then the keyboard, then unplug the ribbon wires by moving the little plastic things, all the while unscrewing everything you see. Good luck.
Mar 21, 2009 | Toshiba Satellite A135 Notebook
Toshiba satelite a45-s130 manual
turn on my toshiba satellite a45-s130 hear one beep and the screen stays on for a couple seconds and shuts off.
Nov 03, 2008 | Toshiba Satellite A45-S130 Notebook
My dishwasher won't drain
was it loose? I don't think it goes in there.
Nov 02, 2008 | Danby 22 in. DDW396 Free-standing...
Toshiba Portege S100-S1133 Notebook Logo
64 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
