I try to install audio driver for compaq cq60-104tu model. But not able to install the driver. Any body guide me and send me the correct audio driver .
if using xp sp3 change the CSDVersion from 300 to 200 and then install the xp driver how to change CSDVersion found here:
1. Click Start, Run. Type Regedit.exe and press ENTER
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ Windows
3. Note down the existing value data for CSDVersion, as
you’ll have to reinstate the original value data later. (The values of
CSDVersion will be 0×100 for SP1, 0×200 for SP2, 0×300 for SP3 and so
forth.)
4. Double-click CSDVersion and set its data to 0×200
5. Run the Change Analysis Diagnostic installer.
6. After setup is complete, restore the original value data for CSDVersion.
7. Exit the Registry Editor.
if helped rate fixya
I need audio driver for the compaq cq60-104tu model. I installed win xp sp2. But still am not able to get the drivers. please help me on this issue.
