Question about Canon PIXMA MP760 All-In-One InkJet Printer
I got the following message: "The type of print head is not correct. Install the correct print head", but the head is all the time the same.
I got the message after changing the ink cartridge.
    Sergeant:
  • 241 Answers
Assuming you have tried resetting the PC and printer and that the printer isn't in warranty I would suggest some cleaning of the printhead contacts.
1. First of all remove any cartridges from the printhead.
2. Lift the release on the right of the printhead, so that it is free to move in its holder.
3. You should be able to remove the printhead now, but be careful as you may need a small screwdriver to loosen fitting behind.
4. Clean all available contacts on the printhead with a clean piece of non-fibrous tissue.
5. Reinstall the printhead carefully.
6. Check to see if the printhead is accepted.
If this doesn't help it may be that the printhead has developed a genuine fault and will need replacing.
Posted on Nov 07, 2012
  • Josip Mucko Nov 09, 2012
    Dear friends! I thank you for your advice and help. It seems that I've reset the printer so that I've disconnected it from the computer and re-connect later. It's all right now. However, a detailed description of the removal of the print head that you gave me, maybe I will get well soon. Thank you again.
SOURCE: Canon Mp 610 error u052 incorrect print head
Hi I have U051, and U052 coming up, I did what it said to do press ok if that doesn't work turn it off, now it is continuously going to these problems. What do I do.
Posted on Mar 17, 2009
komguy
  • 2306 Answers
SOURCE: The type of print head is incorrect. install correct print head
That happens when the printhead goes out, you'll need a new printhead,QY6-0075-000 around $50.00
Posted on Aug 11, 2009
pineworks
  • 4041 Answers
SOURCE: We installed a new Canon black ink cartridge and
Hi there
Take out the print head and just gave it a good clean and put back in.
All the best Pineworks
Posted on May 06, 2010
  • 284 Answers
SOURCE: The printer won't print. Shows the following
It's mean you should replace a new print head
Posted on May 28, 2010
Testimonial: "Thanks! I had resigned myself to buying the print head. Now, I've got to find the least expensive, I don't want to throw away this printer that has worked so well for me."
harit1988
  • 149 Answers
SOURCE: The type of print head is incorrect. Install the
yes . put exactly the cartridge that is compatible with your printer , make sure that you are replacing with the one that has the same number on it as that of the previous cartridge
Posted on Jul 07, 2010
How do i fix print head error message for mp980
See if you can correctly print out a test page. If so the printer is mechanically sound but you have a software issue if still does not work properly. Make sure that you have the correct driver for Win 10 since that OS usually requires new drivers especially if you use the 64 bit version.
Sep 09, 2017 | The Office Equipment & Supplies
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
U052 error - The type of print head is incorrect. I have not changed the print head from new, and have done all that was suggested in the on screen help list. It would appear that I have to replace the...
u Can Follow this step :
http://support-sg.canon-asia.com/contents/SG/EN/8200986100.html
if that reference can't solved, in other reference i found this statment
http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/MP620.aspx?faqtcmuri=tcm:14-610963&page=5&type=faq#Print%20head%20is%20not%20installed.%20Install%20the%20print%20head.%20U051/The%20type%20of%20print%20head%20is%20incorrect.%20Install%20the%20correct%20print%20head.%20U052
" Print head is not installed. Install the print head. U051/The type of print head is incorrect. Install the correct print head. U052 Follow the directions given in your setup sheet to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it."
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Aug 11, 2009 | Canon MP610 Photo All-In-One Printer
Code U052
Dear dgthorpe,
This indicates that printhead of your printer faulty. Commonly this problem come with short circuitry problem in printhead so it may harm logic board and carriage unit too. I suggest you to try checking with another printhead first.
Regards,
Oct 10, 2008 | Canon MP970 Photo All-In-One InkJet...
Code U052
It's most likely an after market cartridge. Try a diiferent one or get the OEM.
Jun 02, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
257 people viewed this question
old marine
old marine
