Question about Ryobi Garden
Ryo8570 timing mark - Ryobi Garden
  • 430 Answers
Timing is not adjustable. If you suspect the unit to be out of time remove the flywheel and check the flywheel key. Set armature air gap ( module to flywheel magnet gap) to .020
Posted on Nov 12, 2012
How do you adjust valves on a 2006 3.5L V6 Toyota Avalon?
There is a Toyota Technical Service Bulletin issued for this:-
T-SB-0291-08 September 11, 2008 2GR-FE Valve Timing
Procedure Service Category Engine/Hybrid System Section Engine Mechanical Market USA Applicability YEAR(S) MODEL(S) ADDITIONAL INFORMATION 2005 - 2009 Avalon 2007 - 2009 Camry VDS(s): BK46K 2008 - 2009 Highlander 2006 - 2009 RAV4 Engine(s): 2GR VDS(s): BK31V, BK32V, BK33V, BK34V, ZK31V, ZK32V, ZK33V, ZK34V, ZK35V 2007 - 2009 Sienna Introduction This service bulletin provides information regarding valve timing inspection and service guidelines for vehicles equipped with 2GR-FE engines. © 2008 Toyota Motor Sales, USA Page 1 of 5 T-SB-0291-08 September 11, 2008 Page 2 of 5 2GR-FE Valve Timing Procedure Introduction (Continued) Figure 1. 3 2 1 5 9 8 7 6 4 1 RH Bank Intake Camshaft Timing Gear 2 RH Bank Exhaust Camshaft Timing Gear 3 RH Bank No. 2 Timing Chain 4 Crankshaft 5 Idler Gear 6 Timing Chain 7 LH Bank No. 2 Timing Chain 8 LH Bank Exhaust Camshaft Timing Gear 9 LH Bank Intake Camshaft Timing Gear Warranty Information OP CODE DESCRIPTION TIME OFP T1 T2 N/A Not Applicable to Warranty © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 3 of 5 2GR-FE Valve Timing Procedure Inspection 1. Set the No. 1 cylinder to TDC/compression. A. Set the timing mark to 0 on the timing chain cover by rotating the crankshaft clockwise. B. Verify the timing marks on the camshaft timing gears are in general alignment with the timing marks of the camshaft bearing cap: TIMING MARK IDENTIFICATION CYLINDER BANK INTAKE GEAR MARK EXHAUST GEAR MARK RH Bank (Bank 1) Small Mark Single Line LH Bank (Bank 2) Large Mark Double Line HINT When the engine is correctly timed, the timing marks will NOT perfectly align. Figure 2. Figure 3. RH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 4. RH Bank Intake Camshaft Timing Gear 2 1 1 Bearing Cap Timing Mark 2 Gear Timing Mark © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 4 of 5 2GR-FE Valve Timing Procedure Inspection (Continued) Figure 5. LH Bank Intake Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 6. LH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark HINT If the timing marks appear vastly out of alignment, turn the crankshaft one revolution (360 ) clockwise and note the position of the timing marks. Component Removal Guidelines 1. If engine disassembly is required that involves removing the camshafts or timing gears, set the #1 cylinder to TDC compression, wipe away any oil, and mark the following items in relation to each other prior to disassembly: • Timing gears • Timing chain • Timing chain No. 2 NOTE This relationship MUST be maintained. The intake gear is timed in relation to the crankshaft via the timing chain; the exhaust gear is timed in relation to the intake gear via the No. 2 timing chain. © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 5 of 5 2GR-FE Valve Timing Procedure Component Removal Guidelines (Continued) 2. If NEW camshaft timing gears or the No. 2 timing chain are being installed, the two yellow links on the No. 2 timing chain can be used to ensure correct relationship between the intake timing gear and the exhaust timing gear. Figure 7. 1 1 Yellow Link A. Align the paint mark on the timing chain with the intake gear timing mark (to ensure the intake gear is correctly timed to the crankshaft). Figure 8. RH Bank and LH Bank 3 3 4 3 3 4 5 4 5 4 1 2 1 RH Bank 2 LH Bank 3 Yellow Link 4 Gear Timing Mark 5 Timing Chain Paint Mark B. Align the two yellow links on the No. 2 timing chain to the timing marks on
May 04, 2015 | 2006 Toyota Avalon XLS
Setting timing marks to get vehicle to start after engine overhaul
Timing marks setting Corolla 4A-FE.
Align the notch on the crankshaft pulley with the "0" mark on the timing belt lower cover.
With the crankshaft pulley being aligned with the 0 mark on the timing belt cover, the hole on the camshaft sprocket should exactly be in front of the notch of camshaft bracket.
Hope that works.
May 04, 2015 | 1998 Toyota Corolla
How to aline timing marks on hyundai elantra 2009 4 cyl.
valve timing, crank pulley T D C mark to mark on timing cover. Cam gear mark to mark on head or block . Ignition timing T D C mark on crank pulley to timing mark on timing cover.
Sep 21, 2014 | Cars & Trucks
Ichanged the head on my 91 geo storm 1.6 dohc and now it won't start
Double check crankshaft timing mark, on your lower timing cover has some timing marks - crankshaft should be on the 0 mark. Camshaft timing marks--intake camshaft mark set at 3 o'clock and exhaust camshaft mark set a 9 o'clock. These timing marks are critical for motor to run and start correctly. These timings marks can move while trying to install the timing belt. After, you confirm or reset timing and belt, you can confirm timing is correct by rotating the crankshaft twice. Your timing marks should be on right on timing marks discussed at the top of the page. If timing marks are off, start over with timing process.
Jul 11, 2012 | 1990 Geo Storm
Ed to know what marks to use on the exhaust cam there are 2 single dots and a double dot should i use the double dot to line up the cam timing\
TIMING MARKS ON CAMSHAFT SPROCKET A LITTLE SMALL SQUARE MARK ON TOP BOTH GEAR SPROCKETS ON CAMSHAFTS TIMING MARKS SHOULD BE IN THE 12 OCLOCK POSITION BOTH CAMSHAFT TIMING MARKS SHOULD BE LINED UP WITH TIMING MARKS REAR OF TIMING MARKS ON TOP OF CAMSHAFT SPROCKET HOUSING. IF STILL HAVING TROUBLE WITH FINDING THE TIMING MARKS.YOU NEED A HAYNES REPAIR MANUAL.
Apr 12, 2011 | 1996 Toyota Camry
Hello, I have a 1978 honda xl 125 motorcycle. my father is a mechanic. butwe were wondering what the ignition timing need to be on? thank you
There should be 3 marks on the flywheel. As the flywheel turns counterclockwise, the first mark is the full advance timing mark. The next mark is the BTC timing mark. the third mark is the TDC mark. Set the points to .015 gap then use a timing light while rotating the base plate to line up the BTC mark at idle speed, 600 rpm. Now check the full advance timing mark at around 2000 rpm. The idle timing is not as important as the full advance timing. Hopefully the spark advancer is in good condition. Please rate my answer. Thanks!
Mar 31, 2011 | Honda XL 125 R Motorcycles
2005 f250 5.4 gas need to know specs for timing a diagram would be awesome
To Install:
  1. Install balance shaft drive gear onto the left camshaft.
  2. Install the camshaft sprockets and new bolts finger tight.
  3. Using a vise, compress the timing chain tensioner plunger.
  4. Install a retaining clip on the tensioner to hold plunger IN during installation.
  5. If timing chain copper links are not visible, mark 2 links on one end and 1 link on the other end to be used as timing marks.
  6. Install right and left timing chain guides. Tighten bolts to 89 in-lbs (10 Nm).
  7. Rotate the left camshaft until the timing mark is at the 12 o'clock position.
  8. Rotate the right camshaft until the timing mark is at the 11 o'clock position.
  9. Position the crankshaft using the special tool. Then remove the tool.
  10. Install the crankshaft sprocket with flange facing forward.
  11. Position lower end of left (inner) timing chain on the crankshaft sprocket. Align the copper (or marked) chain link with the timing mark on the outer flange of the crankshaft pulley. NOTE: Upper half of timing chain must be below the tensioner arm dowel.
  12. Position the left timing chain on the camshaft sprocket. The timing mark on the camshaft sprocket must be aligned between the 2 copper (or marked) chain links.
  13. Place the left timing chain tensioner arm on the dowel pin and install the timing chain tensioner and bolts. Tighten bolts to 18 ft-lbs (25 Nm). NOTE: Lower half of timing chain must be above the tensioner arm dowel.
  14. Position lower end of right (outer) timing chain on the crankshaft sprocket. Align the copper (or marked) chain link with the timing mark on the outer flange of the crankshaft pulley.
  15. Position the right timing chain on the camshaft sprocket. The timing mark on the camshaft sprocket must be aligned between the 2 copper (or marked) chain links.
  16. Place the right timing chain tensioner arm on the dowel pin and install the timing chain tensioner and bolts. Tighten bolts to 18 ft-lbs (25 Nm).
  17. Remove the retaining clips from the right and left timing chain tensioners.
  18. Verify alignment of all timing marks.
  19. Install crankshaft sensor ring on crankshaft.
  20. Locate index mark on balance shaft and mark corresponding gear tooth with chalk.
  21. Position balance shaft on journals. NOTE: It may be helpful to use an inspection mirror to view the marks timing marks.
  22. Align the chalk mark on the balance shaft with the camshaft timing mark.
  23. Install the balance shaft bearing caps in their original locations. Follow the tightening sequence as shown in the illustration. Tighten bolts to 89 in-lbs (10 Nm).
  24. Tighten the camshaft phaser sprocket bolts in the correct sequence using 2 steps, as follows:
    • Step 1-30 ft-lbs (40 Nm)
    • Step 2-tighten an additional 90 degrees
  25. Position the crankshaft keyway in the 11 o'clock position.
  26. Lubricate and install all camshaft roller followers. WARNING
    Engine front cover replacement procedure must be completed within 4 minutes or entire procedure must be repeated. Failure to do so may result in future leaks
Oct 07, 2010 | Ford F-250 Cars & Trucks
Timing marks setting Hyundai Lantra
Installation
Ensure timing marks aligned [6] & [7] . 1. Fit timing belt in anti-clockwise direction, starting at crankshaft sprocket. Ensure belt is taut between sprockets. 2. Slacken tensioner pulley bolt [8] . Push tensioner pulley firmly against timing belt to tension belt. 3. Tighten tensioner pulley bolt [8] . Tightening torque: 43-55 Nm. 4. Except Matrix: Turn crankshaft one turn clockwise. 5. Matrix: Turn crankshaft two turns clockwise. 6. Ensure timing marks aligned [6] . 7. Apply a load of 2 kg to belt at . Belt should deflect 4-6 mm. If not: Adjust position of tensioner pulley. 8. Install components in reverse order of removal. 9. Tighten crankshaft pulley bolt [2] . Tightening torque: 170-180 Nm
7 is timing mark on cam,pin mark to top,hole in spoke below pin mark lines up with mark on head
6 is crank timing mark,pin mark on crank lines up with mark on block
NOTE this mark is just before top
Mar 21, 2010 | Hyundai Motor 1996 Elantra
Timing belt timing marks, 1997 ford escort where are they?
Ford Escort/Tracer 1991-1999 Repair Guide
REMOVAL & INSTALLATION 1.8L Engine
(see Figures 1, 2, 3 and 4)
  1. Disconnect the negative battery cable.
  2. Remove the timing belt covers.
  3. Rotate the crankshaft and align the timing marks located on the camshaft pulleys and the seal plate.
  4. Remove the crankshaft pulley and hub.
  5. If the timing belt is to be reused, mark an arrow on the belt to indicate its rotational direction to enable correct re-installation.
  6. Loosen the timing belt tensioner lockbolt and remove the timing belt.
To install:
  1. Temporarily secure the timing belt tensioner in the far left position with the spring fully extended, then tighten the lockbolt.
  2. Make sure the timing marks on the timing belt pulley (crankshaft sprocket) and the engine block (oil pump housing) are aligned.
  3. Make sure the timing marks on the camshaft pulleys and the seal plate are aligned.
  4. Install the timing belt.
  5. Loosen the tensioner lockbolt. Using a suitable prying tool, position the timing belt tensioner so the timing belt is taut, then tighten the tensioner lockbolt.
  6. Turn the crankshaft two turns clockwise and align the timing belt pulley mark with the mark on the engine block.
Fig. 1: Timing marks are located on the camshaft pulleys as shown-1.8L engines
Fig. 2: Make sure that the crankshaft sprocket (timing belt pulley) and oil pump timing marks are aligned-1.8L engines
Fig. 3: Align the timing belt pulley mark with the tension set mark, at approximately the 10 o'clock position-1.8L engines
Fig. 4: Check the timing belt deflection at the location shown-1.8L engines
  1. Make sure the camshaft pulley marks are aligned with the seal plate marks.
If the timing marks are not aligned, remove the belt and repeat the procedure.
I hope help you with this; remember rated this help. Good luck.
Sep 11, 2009 | 1997 Ford Escort
Timing belt marking
The timing marks are just above the cams at the "twelve o'clock position"
If necessary, align the timing marks.
NOTE When aligning the cam pulleys with the seal plate marks, align the left cam pulley “I” mark and the right cam pulley on the “E” mark.
WARNING When aligning the timing marks, do not turn the timing gear counterclockwise. Damage to the engine will occur.
Oct 17, 2008 | 2000 Kia Sportage
Garden Logo
145 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
