Question about Garden
My husky 1800 pressure washer capacitor melt with a plastic collar that is around. I found the capacitor online but no the collar, where to find it?
  • maritza Nov 06, 2012
    the manual doesn't include the parts on the interior of the machine. My pressure washer is Husky, so the Kacher website doesn't show the parts i need
  • Fred Ford
    Fred Ford May 27, 2017
2 Suggested Answers
  • 553 Answers
SOURCE: Owner's manual for Husky #HU80432 pressure washer
If you can't find it under Tech Support, Manuals & Guides on this site you could go to:
You can also call Husky at: 1-888-550-1606 from 8:00 AM to 4:30 PM Central time.
I hope this helps.
Posted on Mar 28, 2010
Testimonial: "thanks for the info. the # that I was referred to for manuals is - 866-340-3912."
Husky 1800 Pressure Washer motor will not turn off when wand trigger is released
I think you have one of two things going on hear, an overpressure problem or a carburetor issue with the engine.
Jul 25, 2017 | Husky Garden
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 | Garden
How do I replace the gun and hose on my Husky 1800 powerwasher?
the hoses are normally a push in with an "o" ring seal
they are held in by a collar that you unscrew to release and then pull the hose out
May 01, 2015 | Garden
Husky powerwasher 1800 parts schematic
Nov 21, 2013 | Garden
Husky pressure washer is tripping my circuit
throw it away and go by another one...
Nov 03, 2013 | Garden
I have a karcher pressure washer 1800 psi i bought from walmart it was running good until i had a power surge with the plug in. what can i do can i change the fuse in the plug or do i have to open the...
you will have to take the cover off & look for melted wires or a fuse.
if there is no fuse the capacitor may have been cooked.
it should be a white cylinder.if it has been damaged it will have burn marks and may be swollen.
replace the capacitor and it should start.
Dec 19, 2010 | Karcher PSI Electric Pressure Washer
My Husky pressure washer 2600 psi powered by a gcv 160 Honda. Engine starts no pressure other then from water source and soap is not being dispensed
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Jul 10, 2010 | Garden
I hope this helps.
Mar 28, 2010 | Garden
I have an 11 year old, single handle shower control that when turned off has dripping. I have taken off the handle, etc and am at the wall. What is the next step or steps?
After you remove the chrome collar and plastic collar washer (behind the faucet handle), pry the beauty plate off the wall. Turn off the house main water supply. Remove the four screws and washer holding the cartridge and valve stem in place. Save the metal washer under the four screws for use with the new cartridge. Replace the stem/cartridge assembly and secure with the saved metal washer and four screws. Reinstall beauty plate, collar & collar washer, then handle.
Dec 21, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Pressure washer not working
OK here is the solution. There are six plastic vaules inside the pump if you have any mechanical skills you can fix this.
These plastic valves melt when you leave your pressure washer running for a short period when you are not pressure washing. once this happens the pump becomes cloged and does not function. I spent alot of time and research on finding the parts for replacement. I called the main company of this washer pump and here is the toll free number
800-999-2245 and the web sight but to save time just call and talk to the service tech tell him you model number and he will give you the part number.
I only paid $13.75 plus shipping around $5.50 I do not work or have any intrest in this comapny but I tell you after all the frustration and run around I had trying to fix this Home depot power washer I deesided to help eveyone else out
I can be reached at if you have any other questions
May 30, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Garden Logo
402 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
