Question about Consew 206RB
Thread skips I have a Kenmore 158 with out a manual. After changing a needle it started skiping on heavy material with a heavy duty thread and needle. Thanks for your help, Kim
  • rail123 Jan 06, 2009
    I just received the kenmore instruction manual and it doesn't show what the needle bar is, I wouls asume it it the device that holds the needle? If that's true I could not find the or lines you say should be flush with the body. If that's not it I should probably get another manual.
    Thanks again,
    Kim
  • 30 Answers
Well, Hello Kim. Once the Needle for the machine is changed, there is a good possibility of the timing of the stitches being altered and hence the problem.
  •  Firstly, make sure that the needle is in correctly with the scarf of the needle towards the hook. Take the needle plate off and the presser foot off.
  • Turn the handwheel towards you until the needle is in the lowest position, and on the needle bar you will see two lines somewhere near where the needle bar enters the machine.
  • When the needle is in the lowest position, the top line of the two lines should be flush with the body of the machine.
Posted on Jan 05, 2009
How do I get it to sew?
was the presser foot lowered? check if the loop-taker is properly installed or seated.
Oct 03, 2015 | Brother XL2600I Sew Advance Sew Affordable...
What kind or brand of thread is best to use on a singer4423 heavy duty?
Your thread choice depends on the fabric weight and type. Denim needs a different thread from a sheer fabric. See page 49 of the manual: http://www.singerco.com/uploads/download/a719909a6ca001462cb1c2536a04506fa9ff327c.pdf . (That's page 55 of the PDF.)
Beyond that, you want to buy a quality thread that hasn't been exposed to a lot of light (particularly UV light). Many recommend replacing a spool that has been out in the open for over a year. I've had good luck with Coats & Clark.
I hope this helps.
May 09, 2015 | Singer 4423 Heavy Duty Sewing Machine
My thread keeps breaking. bobbin thread seems to be alright, have changed thread, needle.
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Dec 16, 2012 | Kenmore 19606 Computerized Sewing Machine
I have a Bernina Virtuosa 153 sewing machine that is skipping stitches while trying to shorten a pair of jeans. I changed the needle to a 100/16 and am using all purpose thread.
You may need to increase the foot pressure to cope with the heavy denim material. Look carefully at the material as the machine tries to stitch ... if the foot is not keeping the material firmly on the stitch plate, it might be riding up on the needle (denim tends to be rather 'grippy') which will prevent the thread loop being formed correctly below the stitch-plate and therefore not getting picked-up by the CB hook. Changing to a bigger diameter needle might actually make the situation worse in this case ... go back to an 80 and try again.
Sep 17, 2011 | Bernina Virtuosa 150
I want to sew two pieces of fleece together and put blanket binding on with a decorative stitch. (Making a baby blanket). Thread breaks or skipping stitches. What needle and thread combination should I...
Take a look at the chart on needle and thread I posted as a tip, but generally, you'll need to use a larger needle, something like a 14 or maybe even a 16, but you shouldn't need heavy-duty thread.
Aug 03, 2010 | Brother NX-400
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
Tension
You would do best with a heavy weight needle. You also might want to use Upholstery thread rather than normal weight thread. Depending on the machine, you probably need to change the tension. Some high end machines do this automatically. Your best bet is to try a test run on scrap material to get the right needle, stitch, thread combination. Good luck.
Dec 29, 2009 | Kenmore Sewing Machines
Stitches are skipping, bobbin problem?
Here are a few things to try. One of these should fix your problem.
* Re-thread your needle
It may be threaded incorrectly (backwards).
* Change your needle
Your needle may be blunt, bent, or otherwise damaged.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
thinner fabrics, smaller needles. You may also need a larger needle if
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit
fabrics and a sharp needle for wovens (or a universal needle for either).
And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot
It may be too light for your fabric.
* Change your thread
If your upper thread and bobbin threads are different types, try using the same thread for
both. And use a good quality, brand name thread.
* Adjust your thread tension
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
* Change your needle plate
Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure. I know you said you checked this already but it might not hurt to double check it.
Important Note:
After changing your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which
could be dangerous. And make sure to change your needle plate back for zigzag and other wide
stitches.
Hope this helps.
Sep 15, 2009 | Kenmore Sewing Machines
How do I fix skipped stitches?
i work on this kind of machine all the time.but i have never set one up for this type of material.if i was having this kind of trouble on a machine i would make sure the tension for the thread is not to tight because this can cause it to skip.if the material is real heavy it will push the needle away from the bobbin hook causing it to skip .is the needle depth set right.tilt the machine up and watch the bobbin as you spin the machine by hand.the needle should just start to come up then the hook on the bobbin should grab the thread.the hook on the bobbin should be as close as you can get it to the needle with out touching the needle.try putting some of the material on the machine while you run it by hand and watch needle and bobbin.if you need to adjust the machine their are two bolts on the bobbin block.if you loosen the screws you can move the bobbin closer to the needle. also their is a screw on the needle bar to adjust the needle depth up or down, i hope this will help you out.
Apr 05, 2009 | Consew 255RB-3 Mechanical Sewing Machine
Consew 206RB Logo
108 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
