Question about GPS
My garmin nuvi 260w want hold a charge
I charge my garmin nuvi 260w all night, but when I unplug it and start to use it, after about 2 min. it say's battery is low. Do I need to replace the battery?
    Top Expert:
  • 14,553 Answers
Bad battery or voltage not reaching from the charger--I would test for voltage first from charger or if using lighter adapter the fuse in it.
Posted on Nov 07, 2012
fidoliedo
  • 162 Answers
SOURCE: Garmin nuvi 260w not operating while plugged in
If you are trying to use your unit in the car via the USB port and not the supplied cable, it will not work. You must use the bracket that came with the unit or the specific charger that came with the unit. The pins in the Garmin USB charger only use two pins whereas a regular charge cable uses 4.
Posted on Aug 22, 2008
SOURCE: Charging a Garmin Nuvi 260W
Generally most batterys are left on the charger overnight, thats a good way to ensure a full charge, but as you will be using it in your car, it doesn't matter much as power is always available.
To ensure best possible battery life when you have a brand new battery, charge it fully and then drain it almost to 0% Draining most batterys into 0% will be harmfull instead of helpful, I assume the nuvi uses a Li-ion battery so draining it fully is not a good idea, drain it almost fully and then charge it fully.
And you are good to go, repeat the process if you leave the unit unused for a month or two for best battery life.
Thank you,
IwillFixIT!!
Posted on Nov 15, 2008
mastersaintx
  • 928 Answers
SOURCE: I have a broken LCD
You can contact Garmin support to inquire about the price and authorized service center near you
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Posted on Aug 24, 2008
dacust
SOURCE: Garmin nuvi 350 battery replacement
I can't do it for you, but I have done it myself. See the instructions on my webpage at www.dacust.com/nuvi350/index.html. Pictures and everything, along with where I got my battery and the part number, etc. Warning, there are many opportunities to damage your unit doing this. Not for the novice.
-dan
Posted on Jun 07, 2009
RixsFixes
  • 2200 Answers
SOURCE: Charging Garmin Nuvi battery for first time
The Garmin Nuvi 855 uses a Lithium-ion battery. It is a very clean system and does not need priming as nickel-based batteries do. The 1st charge is no different to the 5th or the 50th charge.
In other words there is no memory effect with these batteries and it should be safe to charge it for as long as you like on the first charge. I would estimate 4 hours will give you a full charge if you wish to do this from the outset.
Posted on Jun 21, 2009
Garmin nuvi 260 battery does not hold a charge
If a wall powered charger is used it could be bad or the connection from it to the unit damaged---happens if the charger is connected/disconnected a lot----same thing can happen if using the lighter plug adapter for charging.
Nov 06, 2012 | Garmin nuvi GPS
Hi - I own a Garmin Nuvi 260w. Is it possible to use the SD card to download a trucker navigation road map and upload this to my Garmin Nuvi 260w? Thanks for your response.
It is possible as long as the map is Garmin compatible.
However even with a trucker navigation map installed, the nuvi 260w will not function as a trucking GPS as the routing and IQ of the nuvi 260w does not have the capability to operate in this manner.
The nuvi 260w does not have a trucking mode to allow for the input of specific truck information like truck and trailer length and gross vehicle weight to use as factors on determining the best route for the specific truck/trailer combination.
I would recommend using a GPS specifically designed for trucking like the Garmin Dezl.
http://www.gpscity.com/garmin-dezl-560lmt.html
Sep 10, 2011 | Garmin nuvi 260W GPS Receiver
How to unlock the garmin nuvi 260w
  • 1
    Turn on your Nuvi 260W.
  • 2
    Enter the four-digit PIN you chose when you locked the device. If you have forgotten the PIN, proceed to Step 3.
  • 3
    Drive to your security location. When you reach your security location the Nuvi 260W will unlock automatically. If you forgot your security location or cannot drive there, proceed to Step 4.
  • 4
    Call Garmin to unlock your device. You need your receipt to complete the process. Call 1-800-800-1020 in the U.S., 1-866-429-9296 in Canada. See Resources for the Garmin support webpage.
  • Mar 05, 2011 | Garmin nuvi 260W GPS Receiver
    Garmin nuvi 260w is not charging with car charger
    You have a short in the wire that runs to your unit. Other than holding the wire in the exact location until your charge is complete you would be better off replacing the charging cord. They should be available at your local shop for around $19-$29.00.
    May 29, 2010 | Garmin nuvi 260W GPS Receiver
    Hello, My Garmin 260 ran out of battery 3 months ago. I did not attempt to recharge it until two weeks ago. i used a usb cable and plugged it into my computer overnight. It still did not charge... what...
    http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+260&Show=ExtInfo&gclid=CLzv0pac46ECFQQTawodklsxIg.
    This place has the battery and tools come with it!. its super easy and way cheaper than buying a new garmin. 2 screws and unplug the old battery and plug in the new. I did mine and I never messed with the internals before.
    May 03, 2010 | Garmin nuvi 260W GPS Receiver
    Garnin 260w slide switch will not turn off unit.
    Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
    May 01, 2010 | Garmin nuvi 205 GPS Receiver
    My new nuvi 255w will not start displaying info
    When using a usb from your computer it is only a trickle
    charge to the garmin. Will take a day or two to fully charge. If you use a the cigarette lighter plug that came WITH the garmin, it will fully charge in 4 hours. Stick with garmin approved plugs and all will go smooth. I know, I made the same error.
    May 15, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
    Garmin nuvi 260
    What you would do is, under where the model code sticker is under is the reset button. remove the sticker and hold down the reset button for 10 seconds at the same time hold the power button towards the left.
    May 14, 2009 | Garmin nuvi 260W GPS Receiver
    Garmin 260w does nor start at all, itis dead
    there will be a reset button, take a pen and push the reset button providing that the sat nav is charged it should reboot.
    Apr 05, 2009 | Garmin nuvi 260W GPS Receiver
    Proper charging advice for Nuvi 260w
    Turn it off and Always unplug it when you're done with it.
    That's assuming you have a live plug (stays on when car turned off)
    Mar 16, 2009 | Garmin nuvi 260W GPS Receiver
    GPS Logo
    89 people viewed this question
    Top GPS Experts
    Will Halftowaite
    Are you a GPS Expert? Answer questions, earn points and help others
