Question about Air Tools & Compressors
Hunter tire machine, tc3250 will not release wheel
2 Suggested Answers
  • 98 Answers
SOURCE: Hunter tire machine, TC3250 bead breaker has no
Check the filter that is in line with where the air line hooks up . it could be restricting your air flow.
Posted on Jul 23, 2009
Who makes the best tire machine
Hunter is good - a lot of shops have them and all pretty good reviews but heres a link to have a look at to see what you like...
https://www.bestbuyautoequipment.com/Tire-Changer-and-Wheel-Balancer-Combos-s/428.htm
May 07, 2017 | Cars & Trucks
Hunter wheel alighment rack RM. What does it mean when the green light flashes?
Hunter Wheel Alignment Lift Repair Manual - Vckystxx.com
vckystxx.com/taggedby/hunter-wheel-alignment-lift-repair-manual/
Hunter Alignment Lift Rack Manual Pdfsdocumentscom, Hugh Dixon Hunter AlignmentLift Rack Manual.pdf ... For Hunter Wheel Alignment Lift Racks. ... Repair ...
Jul 28, 2015 | Cars & Trucks
What does error code 2 mean on my hunter dsp wheel balancer
Call hunter support and request error code sheet. Let them know you are a end user and your machine is out of warranty. They should email or fax it to you.
Oct 20, 2014 | Cars & Trucks
Steering gets really sensitive at highway speeds. Hit a bump then car likes to shake left and right.
Sound like out of balance tire or a separated tire or bearing but, the two most common causes are the ones. I suggest visit some tire shop and would like to have the tires inspected and balanced.
Some customers may comment on shaking/vibration in the steering wheel, floor or seat while driving at highway speeds (typically between 60-72 mph (96-115 km/h)) on smooth roads.
These specific vehicles may be sensitive to various rotating mass assemblies, especially if they are considered to be out-of-balance.
In order to correct this:
1. Visually inspect the tires and the wheels. Inspect for evidence of the following conditions and correct as necessary.
- Missing balance weights
- Bent rim flange
- Irregular tire wear
- Incomplete bead seating
- Tire irregularities
- Mud/ice build-up in wheel
- Stones in the tire tread
2. Set the tire pressure to 30 psi (205 kpa) COLD.
3. If the road test indicates a shake/vibration still exists, check the imbalance of each tire/wheel assembly on a known, calibrated, off-car dynamic balancer. If any assembly calls for more than 1/4 ounce on either rim flange, remove all balance weights and rebalance to as close to zero as possible.
Important: Some GM dealers may have a Hunter GSP9700 Road Force Balancer. This will simplify Step 5 by not requiring dial indicators. If a Hunter GSP9700 machine is available, it may also be used to measure the radial force of the tire/wheel assembly. A guideline here is 18 lbs or less.
4. While on the balancer, measure wheel runout. If radial or lateral runout exceeds .020 in (0.50 mm) for aluminum wheels (.030 in (0.76 mm) for steel wheels), replace the wheel.
5. After confirming wheel balance and wheel runout, if any changes were made, road test the vehicle again.
6. If the smooth road shake/vibration still exists:
Important: The completed worksheet must be attached to the hard copy of the repair order.
Record Radial Force Variation readings if you have access to Hunter GSP9700 Wheel Balance equipment. Use the worksheet shown in this bulletin to record the readings.
If one or more of the tires have RFV readings in excess of 18 lbs, match mount the tires to get below 18 lbs. Readings of 12 lbs. or less are preferable for critical customer concerns.
If the RFV can not be reduced to an acceptable level, replace the affected tire with one obtained locally.
The screened tire program is no longer in effect for Bridgestone/Firestone, Goodyear and Michelin. Low speed screened tires are available from Continental General only, and only for the Buick LeSabre.
Road test the vehicle to ensure the shake/vibration has been resolved.
7. Replace both lower control arms on vehicles built prior to the VIN breakpoints shown. The new lower control arms may provide an incremental improvement to the vehicle ride. Customers who have become "tuned in" to the shake condition may still feel some shake in the vehicle after the new lower control arms are installed.
Refer to Lower Control Arm Replacement, (refer to the Parts Information table below for SI document ID numbers).
Important: THE CONTROL ARMS SHOULD ONLY BE INSTALLED ON VEHICLES IF, AFTER THE TIRE AND WHEEL DIAGNOSIS AND REPAIRS HAVE BEEN PERFORMED, THE VIBRATION CONDITION STILL EXISTS.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice weekend.
Nov 18, 2011 | 1996 Geo Prizm
Steering wheel wiggles from side to side under
Bring the vehicle to a repair shop that has a Hunter wheel alignment rack. They will tell you what your suspension needs and do the correct alignment.
Sounds like tires and ball joints, possible control arm bushings . I need to do visual inspection and know make , year and model of vehicle to give a fairly decent diagnosis of your problem.
Jun 23, 2010 | Dodge Ram 1500 Cars & Trucks
What should the front wheel alignment be on an E34 5 series BMW Touring
The only thing you should have to worry about is a full tank of gas and four good tires. The alignment machine (usually a HUNTER) does it all.
May 14, 2010 | 1994 BMW 5 Series
Vehicle suffering with a vibration at 150kms/hr
get tires spin balanced on a force variation tire/wheel balancer. Hard to find a shop with one but worth it. It can chek for excessive force variations in tire that other machines can't. It's a Hunter 9700 machine in the USA.
Feb 04, 2010 | 2004 Jaguar X-Type
Hunter tire machine, TC3250 bead breaker has no power.. still moves... what next??
May 09, 2009 | Air Tools & Compressors
2001 Lincoln Navigator shaking around 70 mph
check ur sway bar. the bolt probably came out, look at the front wheels behind the brake disk, you'll see the sway bar
Mar 16, 2009 | 2001 Lincoln Navigator
Air Tools & Compressors Logo
91 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
