Question about Electrical Supplies
I have a coleman 5500 W generator with a 11HP Tecumseh OHM 90-110 engine. It starts up immediately, runs for 10 seconds, and quits. I have taken the carb apart and cleaned it, everything seems to be
There are no adjustment screws for air/gas mixture, just a idle adjustment setting.
  • Russ Creange Nov 08, 2012
    The bowl is full, so gas is getting in to the carb. Spark is good. I didn't know about the low oil protection system, will check that today.
SOURCE: Coleman Powermate 6250 only runs with choke closed/air restricted
A call to Elliott Small Engine solved my problem - Oil Guard. I had checked the oil and it was just a little low but seemed well within the normal range. I was told to add more, bringing it just over the Full mark. It seems that the low oil protection system is very sensitive and shuts down the engine even when the oil is withing 1/8" of the mark. I added about 2-3 oz of oil and no more problems
Posted on Dec 16, 2008
  • 63 Answers
SOURCE: generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Posted on Mar 16, 2009
  • 57 Answers
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
Posted on Jul 31, 2009
SOURCE: McCulloch 11HP FG6000MK surging
I just came across this post. Hopefully you have it solved. But for others who may run into this problem here is my advice. This model has a low oil sensing system. Over time the oil breaks down or gets contaminated. This can cause sympoms very akin to carb issues. I'd check this 1st as its the easiest fix. Drain and replace oil to the factory recommended specs. Make sure it is to the proper level. Your not finding any carb issues makes this almost a sure thing. DO NOT DISCONNECT or DISABLE the sensor or you defeat its purpose.
Posted on Jan 12, 2010
  • 905 Answers
SOURCE: I have a Coleman Powermate 5500 Generator. It is
This engine was not built with quiet in mind, it was built to be cheap. upgrading the exhaust is your best bet and likely the cheapest. Talk to a small engine shop about the possibility of using a muffler from an ATV.
Super Trap makes a fantastic muffler, if it will fit your application (most do). A link has been provided at the end. When you are looking at the various options, you will notice that a rating in db units. Reducing noise by 3db is half the original noise level.
if you can, go with the SuperTrapp. If still noisy (probably won't be), then add on the resonator as well. Downside to using aftermarket is that you will have an exhaust stack / system that sticks out the side of the generator. Upside is that you will be able to think quietly about how much the exhaust sticks out.
And no, I don't have any connection with Jack's, they are just the first hit that came up. Now that you know that something is available, you can do more research on it.
http://www.jackssmallengines.com/Quietmuf_index.html
Posted on Jun 12, 2010
Need to wire my 5hp compressor to a 11hp 5500 watts generater
I'm not sure what you mean by "wire my 5hp compressor to a 11hp 5500 watts generator?" The compressor should have a three prong plug-in cord from the pressure regulator and the generator should have a three prong outlet to plug it into. Do not try to wire the compressor directly to the power generator (dynamo), the current must go through the circuit board then to the outlet to make sure your compressor motor is getting the proper current.
Feb 21, 2012 | Coleman Air Tools & Compressors
I have a coleman maxa 5000 PM525202; I bought it at a garage sale (didn't run); cleaned and rebuilt carb, changed oil, etc, and now it starts great and idles great. But ther eseems to be a part of the...
Parts lists for Coleman generators are here: http://www.jackssmallengines.com/coleman_parts_lookup.cfm
More detailed information about the engine can be found by using the engine model number. Look around the fan shroud or engine block. Coleman used different engnes, however your gen may have incorporated a Tecumseh 10 hp engine. Good luck
Sep 02, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Jun 18, 2010 | Coleman Powermate Powermate 5000W...
I have a Coleman 5500 with Tecumseh motor and it has a really, really slow oil leak when it when it is sitting in the shop not running. I can't tell where the oil is coming from. Any suggestions?
Look for a crack in the crankcase... possibly near a mounting boss. Also oil filler plugs sometime leak if overfilled.
Suggestion: Use some "gunk" engine degreaser to make it sparkle so you can spot where the leak originates. You probably need to put it up on a bench OR use an inspection mirror.
Apr 29, 2010 | Coleman Powermate Premium Plus 6250W...
Tecumseh model 100 engine 10hp on a coleman powermate generator it starts ok however after about 3 minutes the engine sputters like it is running out of gas and quits.
check the fuel mixture settings i believe main screw is 1 3/4 turns from closed and the idle screw is set at 1 1/4 turns from closed. These settings are for non OHV models. also check that if you have a fuel filter installed that it is not plugged up.
Sep 27, 2009 | Coleman Electrical Supplies
Coleman Powermate 10 HP Generator shuts down after a few minutes.
I have an HM100 on a 5500 watt gen with the same problem. This motor calls for a J17 spark plug, but I found using a J19 (hotter) plug solved the problem. I think the J17 doesn't get hot enough for a complete combustion burn so it act like fuel starvation thus resulting in the black sooty and wet plug.
Sep 24, 2009 | Coleman Powermate Premium Plus 6250W...
What carb does the powermate 6875 use?
check this web site http://www.powermate.com/productmanuals.php?cat_id=3 you can down load the manual and parts list for your gen.
Mar 24, 2009 | Coleman Powermate Powermate 5000W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Usage Question
Never disconnect the neutral line as it enters your house. It is held very well at ground potential. Each transformer is grounded, and every home supplies ground as well. The neutral coming in is the reference to both live lines, and without it, anything connected to either live line could see up to 240VAC depending on what is across the other side. Install a proper transfer panel, and the neutral issue will be taken care of.
Aug 27, 2008 | Coleman Powermate Medium Generator Cover...
Electrical Supplies Logo
80 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
