Question about Handhelditems Bluetrek Mini Bluetooth Headset
Does bluetrek mini compatible with iPhone 4GS?
Cause iPhone does not find the device via bluetooth to pair...
Why i cant stream music from my iphone 4s to play in my nissan 370z via bluetooth
Not sure, If the manual, from the car radio says it should pair with Apple bluetooth devices, it must be a setup problem. If your radio is not (yet) compatible with MP3 over bluetooth from Apple devices, you should ask nissan if they have intentions to upgrade the software in the radio. I think you spent enough on your car, to get this kid of service.
I'm sure most modern car radio's are compatible, because my 2 year old Toyota Yaris can play my music and take my calls from my iPhone 4 without problems.
Jul 22, 2014 | Plantronics Explorer 220 Bluetooth Headset...
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 | Cell Phones
Have lost the manual to bluetrek and have an iphone 3 now and need to get the bluetooth working with this new phone
First, here is the link to the manual:
http://www.bluetrek.com/getfile.php?source=/download/product_download-manual63.pdf&filename=CompactClassic+Manual%2C+English&file_extension=pdf
Here are the instruction: 1. Switch on your Bluetrek and press and hold Talk button and Vol+ button for about five seconds untill indicator light flashes red and blue alternatively and you will hear a sound from speaker.
2. Open bluetooth in Iphone 3 search for bluetooth device. You will see Bluetrek Compact Classic. Click on name to pair and enter "0000" as pin code.
Bluetrek will be connected to iPhone.
Jun 02, 2011 | BlueTrek Compact Classic Ultra Slim...
I don't have the manual anymore and I forget how to pair the blue trek car kit with my phone. Please help!
Try this:
1. Put them close together
2. Switch on phone and select bluetooth discover mode (make sure it's visible to other devices)
3. Switch your BlueTrek device. Press and hold both Talk and Vol+ button for about 5 seconds until the indicator light flashes red and blue alternatively and sound can be heard from the speaker.
4. The phone should then detect the Bluetrek device. Follow the instructions from the phone to accept the pairing request. If you didn't change it, the PIN code should be 0000 (zeroes).
Hope this helps.
May 04, 2011 | BlueTrek Surface sound Duo Bluetooth Car...
What is the password for my bluetrek mini
The Bluetrek Mini pairing password is “0000”, four zero. I found this pairing instruction from their website :
http://www.bluetrek.com/file/product-how_to_pair10.jpg
Hope this help!
Aug 08, 2010 | Cell Phones
I cant get my iphone to detect bluetooth devices. some devices detect it but are unable to pair with the iphone 3g
Most Bluetooth devices can connect only to one device. Make sure that it is not paired with any other device. Then again, if that doesn't work then, probably the Bluetooth device is non-compatible.
Oct 28, 2009 | Apple iPhone 3G
Have put bluetooth on but it wont paid with any
To your diappointment the Iphone cannot send photos, songs, or anything like that, yet. What you can try is restoring your Iphone and then see if you can pair it with your device. If that doesn't work, then it just means that the device you are trying to pair with it non-compatible with the Iphone.
Oct 27, 2009 | Apple iPhone 3G
Need code for g2 earpeice
Pairing the BLUETREK® G2
Before using the BLUETREK® G2 headset, you must pair it with your Bluetooth® mobile
phone. Pairing is the process of linking 2 Bluetooth® devices, so that they can
communicate.
To initiate pairing:
1. Place the BLUETREK® G2 and your mobile phone within 0.3 meter (1 foot) from
each other.
2. Switch on your phone and select its Bluetooth® discover mode (refer to the
Bluetooth® mobile phone user manual).
3. When the BLUETREK® G2 is switched off, press and hold the TALK button for
about 7 seconds until the indicator light flashes red and blue alternatively. And a
sound can be heard in the speaker.
4. Once the mobile phone detects the headset, a “BlueTrek G2” message will be
displayed. Follow the phone instructions to accept the pairing. The PIN code (or
passkey) is 0000, then press “yes” or “ok”.
If pairing success, the indicator light will switch to blue and flashes slowly.
If you haven’t started the discovery mode within 5 minutes, the headset
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | BlueTrek G2 Consumer Headset
Phone can't pair with bluetooth but is bluetooth compatible.
well whats the problem you cant connect your bluetooth to your phone or is it not comming up on your phone? did you pair it correctly?
Jan 29, 2009 | Nokia 6133 Cellular Phone
Nokia 6680 wont connect to Bluetrek G2
Just had the same problem.
But I found some bluetrek instructions on the net & it works
communicate.
each other.
Jun 26, 2007 | BlueTrek G2 Consumer Headset
Handhelditems Bluetrek Mini Bluetooth Headset Logo
35 people viewed this question
Top Handhelditems Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Handhelditems Radio Communication Expert? Answer questions, earn points and help others
