Question about Electrical Supplies
I have a coleman 5500 W generator with a 11HP Tecumseh OHM 90-110 engine. It starts up immediately, runs for 10 seconds, and quits. I have taken the carb apart and cleaned it, everything seems to be in working order, but doesn't help. It seems like it is getting enough fuel, I can smell it. Spark is fine. Any suggestions?
Check the oil level. there is a low oil cut off.
Posted on Nov 08, 2012
  • billgill3492
    billgill3492 Nov 08, 2012
    check the oil level. there is a low oil cut off.
  • awindsr71 Apr 17, 2013
    The main fuel intake seal, is swollen. This assuming that the float moves. Remove the bowl assembly and blow into the main fuel inlet with the bowl assembly above your head. If you can't blow air through the hole, with the bowl empty, then it is swollen and needs replacing. No air means no fuel gutting in fast enough.
  • 151 Answers
SOURCE: Tecumseh model 100 engine 10hp on a coleman
check the fuel mixture settings i believe main screw is 1 3/4 turns from closed and the idle screw is set at 1 1/4 turns from closed. These settings are for non OHV models. also check that if you have a fuel filter installed that it is not plugged up.
Posted on Dec 24, 2009
  • 12 Answers
SOURCE: Spark but no fuel . coleman Powermate 6250
if it's flooding the float may have a tiny hole which makes it not float as well and too much fuel will stall the engine...If it's not getting enough fuel to keep running then its usually because of a small piece of dirt blocking a hole..under the carb there should be a brass bolt...take that off and check that the two side holes are clear...then check the center orifice and blow it out...there is also a tiny little hole up near where the threads start...use a wire from a wire brush to make sure its clean....also clean out the bowl and then reassemble...this works 90% of the time for me
Posted on Jul 02, 2010
  • 2006 Answers
SOURCE: Honda gx410 18 hp generator
Suggest you add either Heat fuel restorer (watch the amount you add) or almost pure alcohol to the fuel to get rid of any water in your system. Make sure the fuel filter is not blocked. Then pull the spark plug and spray one 1-2 second spray of WD-40 into the spark plug hole. Turn over 1-2 times, replace the spark plug - then try to start.
This has worked on my generators for years, and hope it works for you. But take a close look at all your hoses because even a small tear will give you problems.
Posted on Aug 26, 2011
kel1guy2002
  • 3740 Answers
SOURCE: Generator runs for about 10
It appears you have eliminated all of the fuel related issues. That would leave the generatoor safety circuits as a possible reason for the unit shutting down.
The Low Oil Level Sensor is the major reason that generators shut down when your sure there is not a fuel supply problem. Make sure the unit is fully servied with OIL. If the problem persists disconnect ONE wire from the low oil level sensor and see if the problem persists. If you still have the problem inspect the black or green wire from the Start run switch all the way to the Air shroud on the engine looking for signs of chaffing.
If you can not find anything then you will have to re-focus your attention on the fuel system once again. If you have a solenoid on the base of the carb.. the solenoid can be WEAK and stop remaining open once hot. This will cause the engine to lean out and die.
You should also check fuel flow to the carb. The flow should fill a spary paint can lid in under 10 seconds to the point your worried about it overflowing. Most honda engines have a metal sediment bowl under the fuel selector. Remove the sediment bowl and dump the contents. Check fuel flow again.
- Carb. With the float bowl removed fuel selector ON check fuel flow again by holding a spray paint can lid under the float. It must fill up in about 10 seconds to the point your worried about over-filling the lid. If you do not have a good flow rate here the float needle float needle rubber seat and the fuel manifold are the prime suspects.
I know this generator has the Honda GX270 engine. Some have solenoids (Item 49 this link)
http://www.boats.net/parts/search/Honda/Engine/0/GX270%20VPX5%20ENGINE,%20JPN,%20VIN%23%20GCAB-2000001%20TO%20GCAB-9999999/CARBURETOR%20(2)/parts.html
^- No details!
Honda engines by model and VIN can be found here:
http://www.boats.net/parts/search/Honda/Engine/0/parts.html
At this time I think the low oil level sensor (sending uint) may be the culprit causing your problem.
Item 2 this link:
http://www.boats.net/parts/search/Honda/Engine/0/GX270%20VPX5%20ENGINE%2C%20JPN%2C%20VIN%23%20GCAB-2000001%20TO%20GCAB-9999999/CYLINDER/parts.html
Thanks for choosing FixYa,
Kelly
Posted on Sep 16, 2011
stewbison
  • 577 Answers
SOURCE: I have a 5500 ppg
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Posted on Sep 29, 2011
Need to wire my 5hp compressor to a 11hp 5500 watts generater
I'm not sure what you mean by "wire my 5hp compressor to a 11hp 5500 watts generator?" The compressor should have a three prong plug-in cord from the pressure regulator and the generator should have a three prong outlet to plug it into. Do not try to wire the compressor directly to the power generator (dynamo), the current must go through the circuit board then to the outlet to make sure your compressor motor is getting the proper current.
Feb 21, 2012 | Coleman Air Tools & Compressors
I have a coleman maxa 5000 PM525202; I bought it at a garage sale (didn't run); cleaned and rebuilt carb, changed oil, etc, and now it starts great and idles great. But ther eseems to be a part of the...
Parts lists for Coleman generators are here: http://www.jackssmallengines.com/coleman_parts_lookup.cfm
More detailed information about the engine can be found by using the engine model number. Look around the fan shroud or engine block. Coleman used different engnes, however your gen may have incorporated a Tecumseh 10 hp engine. Good luck
Sep 02, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Jun 18, 2010 | Coleman Powermate Powermate 5000W...
I have a Coleman 5500 with Tecumseh motor and it has a really, really slow oil leak when it when it is sitting in the shop not running. I can't tell where the oil is coming from. Any suggestions?
Look for a crack in the crankcase... possibly near a mounting boss. Also oil filler plugs sometime leak if overfilled.
Suggestion: Use some "gunk" engine degreaser to make it sparkle so you can spot where the leak originates. You probably need to put it up on a bench OR use an inspection mirror.
Apr 29, 2010 | Coleman Powermate Premium Plus 6250W...
Tecumseh model 100 engine 10hp on a coleman powermate generator it starts ok however after about 3 minutes the engine sputters like it is running out of gas and quits.
Sep 27, 2009 | Coleman Electrical Supplies
Coleman Powermate 10 HP Generator shuts down after a few minutes.
I have an HM100 on a 5500 watt gen with the same problem. This motor calls for a J17 spark plug, but I found using a J19 (hotter) plug solved the problem. I think the J17 doesn't get hot enough for a complete combustion burn so it act like fuel starvation thus resulting in the black sooty and wet plug.
Sep 24, 2009 | Coleman Powermate Premium Plus 6250W...
Engine won't maintain constant rpm
Hello There
Try cleaning or replacing the spark olug.
Hope this helps.
Many Thanks
May 22, 2009 | Coleman Powermate Premium Plus 6250W...
What carb does the powermate 6875 use?
check this web site http://www.powermate.com/productmanuals.php?cat_id=3 you can down load the manual and parts list for your gen.
Mar 24, 2009 | Coleman Powermate Powermate 5000W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Usage Question
Never disconnect the neutral line as it enters your house. It is held very well at ground potential. Each transformer is grounded, and every home supplies ground as well. The neutral coming in is the reference to both live lines, and without it, anything connected to either live line could see up to 240VAC depending on what is across the other side. Install a proper transfer panel, and the neutral issue will be taken care of.
Aug 27, 2008 | Coleman Powermate Medium Generator Cover...
Electrical Supplies Logo
329 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
