Question about LG 60pk200 60 1080p Plasma Tv 60pk200
I am trying to play my game. When I plug the when I plug the red,white ,yellow extention in the AV1 and go on input it does not work it says no signal and I dont understan why I would need signal to play a game.
    Top Expert:
  • LG Master
  • 14,553 Answers
The input is not "seeing" the signal from your game---try another input and make sure connections are correct and the set is switched to the input you hooked up to(they are labeled on the back)
Posted on Nov 07, 2012
  • 52 Answers
SOURCE: LG plasma buzzing
Problem is probably with your cable box as you have confirmed that the set is working by using the dvd player, that is unless you have a bad cable for the cable box.
Posted on Aug 12, 2008
freetek
  • 5568 Answers
SOURCE: LG 42'' TV has no sound but great picture. How do I get the sound?
You shouldn't need anything plugged into the accessory jacks to get local sound from your set. Go through the main setup menu and check audio settings; they may be set to turn off the internal speakers to send the sound to a home theatre that you apparently don't have. Most sets have that as a selection and supply L-R audio for an external system and mute the internal speakers.
FYI: The three connectors you mention are coded as follows:
Red - right channel audio White - left channel audio Yellow - composite video (contains synchronization signals and video)
These may be input connectors (for external VCR/DVD decks) so check your owner's guide to verify.
Posted on Nov 23, 2008
SOURCE: just says no program information
After a month or more of seeing "No program information" on my 32" LG TV and not being able to solve it I recalled that I'd unplugged the TV around the time the problem started.
When you first set up the TV you have to go into the settings and tell it what TIME ZONE you are in. Apparently when the TV is unplugged it erases the time zone information.
I went into the settings a few minutes ago and told the TV that I was in the Eastern Time Zone. Voila!, the TVGOS (i.e. the program information) immediately started working again.
If you're getting "No Program information" check your TV's setup settings.
Hope this helps!
Posted on Jan 16, 2011
SOURCE: I've got a LG 42 inch HDTV model GP-DVB-EU When I
When you have just the cables as you describe, you are using composite inputs. By default, yellow is video, red is right audio, and white is left audio.
Posted on Jan 28, 2011
BElectric
  • 1140 Answers
SOURCE: Can I play Blu Ray
It's entirely possible to play Blu-ray discs on this TV, but whether it's possible in your case depends on the Blu-ray player itself. Many Blu-ray players can downscale the 1080p resolution to 720p (or lower) which is the resolution required for your TV, but this setting needs to be done on the player rather than the TV. Some players have "Auto HDMI" which will automatically downscale the video output to match the TV, but it can often be done manually on players which don't have this feature.
If you can let me know the brand and model number of your Blu-ray player, I can let you know whether it has this feature, and if so, how to configure it. I would be surprised if it doesn't have it.
Regards,
BElectric
Posted on Feb 21, 2011
I have the 3 RCA red, yellow, white cables on back of dvd and to tv. Video only plays when I select video 1 under the input. When when I select video 3 only sound and no video. What else can I try?
Sounds like from the symptoms that you have plugged the white and red cables into AV3 input on the back of the Teleivsion and plugged the yellow cable into AV1 on the back of the Television.
Check the cables are all plugged into AV1 input ports on the back of the Television. Red and White go into the Audio inputs and Yellow goes in the video input. Also make sure you have not plugged cables into component inputs on television look for AV1 in on back of Television .
Mar 08, 2015 | RCA Televison & Video
How do i get my nintendo wii console to appear on the tv screen ive tried every channel and hdmi and such and nothing i know its on and working cause i feel the wii remote vibrate just nothing shows o
Kate what did you plug the cables into I suspect it was a grey cable with a red , white and yellow plugs. If I am correct this cable should be plugged into the AV1 or AV2 input port of your television. Try changing the input source to AV1 or AV2 Check it is plugged to AV1 on the Television and not into Conponent input !
Jan 02, 2015 | Sceptre X32BV-Naga 32 in. LCD TV
How to play a dvd on the samsong? don't know how to connect the red yellow and white wirews?
You just have to match the color of the plug to the color connector on the TV and on the DVD.
Look for something like AV1, or Video 1 on the TV. It should have Yellow jack for the Video, and RED and WHITE jack for the Audio Right and Left channels, same thing applied to the jacks on the DVD player.
The just select AV1 using the remote control, just look for 'INPUT', or 'SOURCE' bottun on the remote.
Oct 12, 2011 | Samsung Televison & Video
Do you know how to get sound back on when you switch to av1 picture fine but no sound thanks
Make sure that you have the audio input hooked up to the correct input (AV1). For the AV1 channel there should be either RCA (yellow, red, and white) or S-Video (generally a black plug) plus the red, and white from the RCA. Make sure the red and the white are both connected to the AV1 Input. Hopefully this solves your problem.
Thank you
Feb 28, 2011 | Sony Televison & Video
There is no picture anymore, all shows a blue screen.
do you have the orginal remote that has device button on it such as tv,dvd,av1,av2 or a input button on it if so play around with it such as when the blue screen comes on press the tv button or even better if you have cable box with the red,white and yellow plug in the back just plug the red,white,yellow cable from your cable box to the red,white and yellow into
the input of the tv
Jul 31, 2009 | Televison & Video
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Jan 31, 2009 | GE 27GT619 27" TV
Blue screen
At least a couple of possibilities, check the yellow video cable that runs from the VCR to the TV, is it plugged into the side of the combo unit that says vcr?
Is your TV on the right source? You could have plugged the audio into say AV2 and the video into AV1, causing a mismatch. Make sure the yellow, red, and white are all plugged into one input section on the TV (AV1, AV2, Video 1, Video 2, etc).
Dec 09, 2008 | Philips MRV700VR DVD Recorder/VCR
Hooking up my dvd/vcr playing
The problem definitely lies in your connections. Make sure that the red is in red, white in white and yellow in yellow. If you have multiple sets of these to plug into on the back of your TV, then make sure that look at what that row is named (e.g. AV1, COMP 1, etc...).
Next, change the input on the TV (w/ the remote) to that name: AV1, COMP 1, etc...)
Mar 25, 2008 | Philips Magnavox DVD/VCR Dual Player
Wii gone black and white, no colour
I bought a wii a few days ago and like everybody else mine too was in black and white with a grainy picture. I have a Panasonic lcd flat screen and thought I had connected it corrected, I got somebody out to have a look at it and found out there are some connections on the side of the TV which I hadn't even noticed before, once I put the red white and yellow leads in these and set the TV to AV3 everything is in perfect colour. Hope this works for some of you.
Dec 11, 2007 | Nintendo Wii Console
LG 60pk200 60 1080p Plasma Tv 60pk200 Logo
18 people viewed this question
Computer Repairing
Computer Repairing
