Question about Electrical Supplies
Honda ex1000 generator will only run with choke on full?
  • 4 Answers
SOURCE: Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Posted on Jan 02, 2009
  • 4088 Answers
SOURCE: Coleman 6250 generator runs rough
Fresh fuel? Does carburetor have adjustable jets? Turn the high speed jet (at bottom of float bowl) about 1/4 to1/2 CCW (looking at bottom of bowl). If no improvement, carburetor should be torn apart and cleaned. This also applies if there are no adjustable jets. Is there a fuel filter anywhere?
Posted on Jul 14, 2009
Richie_asg1
  • 1036 Answers
SOURCE: honda generator gx390 will only run with the choke
Most problems like this are a fouled inlet in the carb. Try adjusting the carb settings fully in - then back out tooriginal position. This often crushes any debris causing the problem.
Failing that, clean out the carb.
Posted on Feb 07, 2010
ROMOAS
  • 97 Answers
SOURCE: I have a honda ex1000
if it is in fact made for the country's you stated then that's common do to they don't use 110 but unlikely do to there sales are international in reading the manual the rating is
120volt 60 Hz rated 900va max 1000va
the 12volt section 12volts 8.3 amp current
i am attaching 3 pix's of the wiring diag so you can trace the wires hope this helpsb34e74f.jpgb589d04.jpg1eb189d.jpg
Posted on Aug 31, 2010
  • 3 Answers
SOURCE: i have a coleman powermate premium plus 6250
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Posted on Jan 17, 2011
Is there a low speed jet adjustment on a honda ex1000 generator(ea4-1212412
You have dirt in the carb, remove it and rebuild it and blow out all the passages with compressed air.
Mar 15, 2017 | Honda Portable Generator Model Ex1000
My EX1000 Honda generator runs ok but the green light stopped coming on what does that mean
isn't that the invertor light ??? plug something into it... does it work??? then no worries mate
Aug 28, 2014 | Honda Portable Generator Model Ex1000
Wont run off 1/2 choke
I had a problem with a honda generator that would only run on full choke. I removed the carburetor and cleaned the main jet with a wire and carb spray. Problem solved. Fuel stabilizer should be used with todays gas mixtures that have ethanol in them. Hope this helps.
Aug 29, 2010 | Honda 6370C - Parallel Power Kit For ...
Electrical Supplies Logo
134 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
