Question about Maytag Washing Machines
A clothing item is stuck underneath the agitator of our Maytag Bravos MCT washer model number MVWB850WR2
  • 36 Answers
SOURCE: maytag washer won't agitate
your transmission is no good and needs to be replaced
Posted on Jan 02, 2009
SOURCE: clothes stuck under the agitator
The clothes do not go under the plate they spin out of the top and fall over the side, this is because socks and underwear are either overloaded or spun out, this can be solved by reducing the load size and also spinning small clothing items on lower speeds, but the solution above is very helpful for getting the clothes out, but you will need a long pair of needle nose pliars to pull the clother out of the bottom of the tub. This problem presented itself by a "LD" error (long drain) Thanks tzweeb and I hope this helps others
Posted on Jan 09, 2009
  • 219 Answers
SOURCE: LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
Posted on May 21, 2009
  • 3 Answers
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Posted on Sep 25, 2009
  • 2180 Answers
SOURCE: REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Posted on Nov 03, 2009
Testimonial: "Super fast and accurate info. Thanks so very much."
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
Is there a reset on a may tag bravos mct washer
Top 565 Complaints and Reviews about Maytag Bravos
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.2 - ‎241 votes This Maytag Bravos HE machine has the poorest design! ... So disappointed in Maytag - I have a 2013 Bravos washing machine that if I had it repaired again (less .... Called Maytag because my owner's manual stated I had a 10 yr warranty.
Jul 26, 2015 | Washing Machines
I have a maytag top load washer (Bravos quiet series 300) that has stoped working. it flashes a code of "F51". It did this before and the repair man opened it up and found small clothing items...
Press 2 metal tabs. About 6" from the sides on the front of washer. Plastic ring on top has tabs that need to be disengaged to disconnect the ring. Once ring has been removed the area between the plastic tub & metal tub is accessible. Check for small articles of clothing, like socks or underwear. Inner tub can be removed by: snap up plastic cap (small slot for tool to slip in and pop up). Remove 7/16 nut and remove agitator (may require to be rocked back & forth, sits on a splined shaft). Remove 5 small phillips screws, being careful not to drop any, and pull inner metal tub up (may require it being shimmied back and forth). Removing this tub will give full access to any debris or articles of clothing that may be under it. Please keep in mind that if you're challenged in reassembly
Jun 16, 2017 | Maytag Atlantis MAV6000 Top Load Washer
I have a brand new Maytag Bravos MCT top loaded washer. It makes a squeaky noise when agitator is cleaning. The squeak is getting louder and I've probably only used the washer a dozen times. We checked...
I had this one come up on a washer I had professionally installed for a client. When I looked into it I found there were shipping blocks made of squeaky Styrofoam the installers left in place. Only made the noise when it was full of water and working hard shifting back and forth in agitation. It said right in installation instructions to take the shipping blocks out too.
Feb 20, 2011 | Maytag Dependable Clean Top MAV5920EWW Top...
Error code f-51
The F51 code indicates that the control is not detecting proper motor rotation in the washer. This can be caused by overloading the washer, a fill problem or even a toy or item that is stuck underneath the washer that is preventing the motor from spinning properly. With the washer empty, see if the spin basket rotates freely. If you detect resistance, then you check between the basket and tub for an item that is stuck in this area.
Feb 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
My maytag bravos 580 quit working. It stopped towards the beginnging of a cycle. It kept beeping and lights went around and around the dial. It wont let me change the cycle and wont shut off unless I...
Hello & Welcome to FixYa
LD error code means long drain, you can try to check the drain hose and clean it completely. Also take out the agitator and check any stuck clothes there. After this if the problem is back then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | Maytag Bravos MTW6600T Top Load Washer
My Maytag Topload Bravo washer has the smell of bad well water, or stagnant water on occassion. (I have city water, btw.) Also, no matter what detergent I use or what cycle I wash, or what tempurature the...
I can't be sure without looking at the machine but I have had several of these type of machines the get cloths under the agitator "wash plate thing" in the bottom of the basket. This will eventually clog up the pump but stuff that hangs out in there can really get to smelling after a while. Try removing the wash plate and see if you see anything under there. In the future make sure you use a lingerie bag for all small items to prevent them from getting stuck under the wash plate.
Oct 28, 2010 | Maytag Bravos MTW6600T Top Load Washer
Need to remove agitator because clothing is caught underneath
To remove the agitator on most Maytag models, you remove the center post cap or softener dispenser on the agitator and locate the agitator bolt underneath. Remove the bolt and pull the entire agitator straight up. If this does not match your washer configuration, please post back with a model number so that I may be able to provide you with better assistance. I hope this helps you.
Nov 21, 2009 | Washing Machines
A piece of clothing is stuck underneath the agitator! It won't turn during the wash cycle. The spin cycle still works. How do I disconnect the agitator, so I can remove the piece of clothing?
remove the agitator by first taking off the softner dispenser at the top of the agitator and then look down inside. inside you will see a half inch head bold. remove bolt and lift agitator out.
Jan 27, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Small items stuck under the agitator
it should have a cap on top with a bolt underneath it that you can take loose.the top of the agitattor should pop off
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
