Question about Profile CL1200 Car Audio Amplifier
Car Amp keeps blowing fuses
My in-line fuse blew so I replaced it. Then after I replaced it my amp played for about two minutes. Then It totally quit. I checked the in-line fuse and it is fine. I then checked the amps fuses are they were blown. I then replaced the amp's fuses and when I went to put the new ones in the immediatly blew. What is going on? Any suggestions?
  • Josh Johnke May 22, 2007
    What is the audio power IC? Is that the power cable running from the battery to the amp? If so I checked the power from the battery to the in-line fuse holder and its receiving a good charge. Also I checked the power cable from the back of the in-line fuse to the amp and its also receiving a good charge. The amp in the holder is a 60 (forgot the label, ohm or whatever it may be). This happened to me on one of my other amps also.
  • Josh Johnke May 23, 2007
    Yes, my my amp is rated high. I have a Profile CL1200 amp. I put in new fuses to my amp itself and re hooked it up. When I turned the amp on I noticed smoke coming from out of the top. However, the fuses to the amp, or the fuses to the inline fuses holder were still good. Should I open it or not? Or should I take it to some where to get fixed? About how much do you think it would cost?
    Scholar:
  • 125 Answers
The reason why fuses blow is that the current is too much. Is the fuse rating according to the specs ? If yes then ... One or more output power transistor (or audio power IC) may be shorted. have it checked before replacing another fuse as this might cause more damage.
Posted on May 22, 2007
  • Michael Ifurung May 23, 2007
    IC means Intergrated Curcuit. This is a black rectangular shaped componentinside the amplifier that is normally attached to a hetsink to dissipate the heat generated during operation.
    60 amps. This is big. Your amplifier must be rated at 200 watts or more !
  • Michael Ifurung May 25, 2007
    Holy smoke !
    Smoke can come from several components, the worst smoke pruducer are resistors. Capacitors will just pop, and semiconductor will also create smoke.
    Is your amp new?
    Is it possible that you made the wrong connection ? (Positive=red, negative=black). If you connected the wrong polarity, the first to blow is the reverse polarity protection, in many case this is a large diode connected across the supply in reverse polarity. If you are lucky this diode might be the one causing the smoke, it can be easily and cheaply replaced. The cost of th epart will be probably less than $5.
    However because you said that the fuse did not blow, maybe you put a large fuse. This is bad because it might destroyed other parts.
    If you are absolutely positive that your connection is OK, something else might blew up (power MOSFET transistors, power IC, etc.) This can be expensive.
Amp fuse 30a keep blowing
You have possibly melted a couple of wires together along the radio circuit. Also the radio unit itself has 1 or more protection fuses actually inside the unit that have blown, usually at back of unit in little bay near the wire clusters.
Check your relays too, a blow out through jump starting can do all sorts of little burn-outs.
Oct 15, 2016 | 2006 Lexus Rx 330
Why would my iron heart Lainey 212 combo amp combo be blowing fuses?
Because some component in the amp is failing/failed and drawing too much current. The amp needs a repair shop. Poking around without knowing what you're doing can expose you to leather voltage. Don't do it.
Oct 13, 2016 | Laney IRT60H Ironheart Guitar Amplifier...
2005 Saturn Vue Repetitive Ignition Fuse Failure
I think there is a short in the system, possibly happened while replacing the main brain.
Jun 19, 2012 | 2005 Saturn VUE
Have a hartke lh1000 head . played about 5 total hours then blew the fuse. is this something i shoud be worried about?
If the fuse is correct ( check manual) it shouldn't blow under normal operation. Once in while a fuse will break internally and thus blow the fuse. look close at the blown fuse If it is a "violent" blow (totally black inside) then you have an overload condition. I would use an ohm meter to check the connection to the speakers. Usually it should be between 8 ohms and 4 ohms if the number is lower than 4 ohms your speakers or wiring are putting to much of a load on the amp. If the fuse was not a "violent" blown fuse then replace with a new fuse of the exact proper value. many amps use an MDL fuse that is a slow blow fuse and has much different in circuit function than a ACG fuse so use only the exact proper furse that the manufacture recomends. If the load (speaker and wiring) is correct and the fuse is correct and still blows then you have a component problem and the amp will need repair
Jan 19, 2012 | Hartke Lh1000 Bass Amp Head 1100 Watts...
I have a 1994 Ford Thunderbird LX V8. A few months ago when I put the car in park, the air conditioner and the battery amp guage quit working. I found a fuse that was bad and I replaced it and then the...
I'm betting it has something to do with the shift lock actuator or the harness to the actuator. I'm pretty sure it is located on the top of the steering column on your vehicle. The lower part of the dash will need to be removed and then the steering column lowered in order to gain access to it.
This vehicle does have an airbag and unless you experience with airbag systems I would not recommend tackling this yourself.
unplug the interlock. Replace the fuse. Start the vehicle. with your foot on the brake manually release the interlock with you hand and shift through the gears. If the fuse does not blow your on the right track. If the fuse does blow let me know and I'll get you some more info.
Let me know if you have any questions and thank you for using Fixya.com
Oct 25, 2011 | 1994 Ford Thunderbird
Fuse Keeps Blowing
disconnect rca and speaker wires if they still blow you may have a problem with amp
Jan 17, 2010 | Volfenhag ZX-8400 Car Audio Amplifier
Engine management fuse keeps blowing
My car stopped running without any warning, its a 2005 ford focus, 2.0 and the 20 amp fuse for the engine management keeps blowing, it's number 9 in the panel and I have replaced it twice, both times it blew again, any tips? Also the odometer reads ------ and that's it.
Jan 09, 2010 | 2001 Ford Focus
Amp keeps blowing fuses (alpine mrdm1001
Hello prabh_dusanj,
First make sure that the amp is not operating into too low of an impedance. If the load is OK, it's most likely a short in the output transistors.
Hope this helps.
Sep 11, 2009 | Alpine MRD-M1001 Car Audio Amplifier
Chevy silverado keeps blowing fuses
Your 20 amp fuse will not blow if glowplug wire shorts. each plug draws 15 amps which is 120 amps total.I think there are in line fuses for them. Try to wring out where each output from the fuse goes, disconnect all and reconnect one at a time till it blows.That should point to your problem process of illumination! Good Luck!!
Aug 25, 2017 | 1994 Chevrolet K1500
Profile CL1200 Car Audio Amplifier Logo
292 people viewed this question
Top Profile Car Audio & Video Experts
xxxxxx xxx
Are you a Profile Car Audio and Video Expert? Answer questions, earn points and help others
