Hook up for fisher studio standard system scamatic
I have Fisher studio standard system with following units turntable MT-9000 , Remote control center, Stereo synthesizer tuner fm-550,Stereo amplifer ca-550,Stereo cassette deck dd-350, Graphic equalizer eq-550 . Lost hook-up inst. in a move
4 Suggested Answers
marsrover
  • 682 Answers
SOURCE: Graphic Equalizer installation
record out from stereo to equalizer in----equalizer out to stereo pb[play back]in.
Posted on Mar 22, 2009
caroldon
  • 17129 Answers
SOURCE: HELP NEEDED I am having trouble
In the first part use the following leads
1. Keep the Power amp as the base and connect to the Cd input the CD player, the tuner to the tuner input, the cassette deck - play output to the tape in ( amp) and Rec out of tape to the tape out(amp).
connect all the RCA sockets with the R&L in the same side of the input/output.
Now the graphic equaliser input must be connected to the Amplifier's preamp output and the equaliser's output must be connected to the Amplifier's preamp input.
Now the equaliser will work through the amp.
The left and right speakers can be connected accordingly with the polarity in order.
The second system can be connected similarily with the cassette deck, tuner and cd player connected to the input of the Amplifier using the R&L RCA sockets.
Connect the speakers accordingly and test.
Please connect each RCA cord one by one and do not mix them up.
Posted on Aug 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: i need manuals for hooking
I can't even find a reliable picture of the amp but it's not rocket science.
The Tuner output goes to, say, FM or Aux on the am, anything BUT Phono, which is ONLY for a turntable.
The EQ output goes to the first available Tape In; Input Comes from the same Tape Out. Select that tape function to engage it in line with any source and the downstream electronics (second tape, tone, volume, speakers).
The tape deck output goes to Tape In; Input comes from Tape Out. If there is not a second tape loop on the amp, nest the Tape Deck into the EQ's Tape loop. They always have at least one to replace the one they use. Select THAT tape function to engage it in line with any source and the downstream electronics.
Posted on Mar 13, 2011
Fisher mt 6250 I need a replacement stylus. What will fit my turntable?
Hi, your Fisher MT6250 takes a Pickering XV-15 stylus. We have them in stock. cheers john. Stylus City
Jan 25, 2014 | Audio Players & Recorders
I don't no what speakers work with my fisher mc-723
The speaker output connections on this stereo system unit are called RCA...named from the inventing company. Computer speakers use what is called a "mini-plug" and as you've found out, the two are not the same.
I would suggest checking at your local Goodwill or Salvation Army store for an inexpensive pair of speakers with the proper RCA connection you need. Second choice is the local Radio Shack store...tell them you need speakers with RCA type connections and you will also need two RCA to RCA speaker wires to make the connection needed.
Nov 05, 2013 | Fisher Model Mc-723 Studio Standard Audio...
My Studio Standard by Fisher stereo system's audio keeps breaking up.
Could be a defective volume control. After 20 years, it would not be surprising
Apr 10, 2013 | Fisher Studio Standard Am/fm Synthesizer...
I Have Lost My Remote To My Studio Standard RS-912 by Fisher, Is It Possible For Me To Still Turn It On Without The Remote ?
If you have switched off it by using power button to its remote control, you must have its remote control to switch it back on. Anyway, try pressing the Ch up or Vol up buttons once. In rare cases, this might make it switch back on.
Feb 15, 2013 | Televison & Video
Fisher Studio-Standard Belt-drive Semi-Automatic Turntable MT-32
Most likely the grease in the whole system has started to stiffen or the motor is failing. This can be fixed. Try oiling the motor first. If that fails, I'd look at the motor driver IC as the most likely failing part.
Dan
May 22, 2008 | Audio Players & Recorders
Fisher turntable mt 6410 removal
Look at spindle bearing in center of t-table. There is probably a small ring lock there holding the table. Use a pick or small screw driver to carefully remove this ring.
May 07, 2008 | Audio Players & Recorders
Earlier; Fisher stacker type unit. stuck in Standby. mode
Hi jamz.
I see this is a pretty ancient posting so you've probably fixed it or given up by now.
I also own a CA-350 Amp which I purchased many years ago here in Auckland NZ.
I've recently had it in bits to fix so if you're still looking for a solution I may be able to offer you some help.
If so, you can contact me at martymarvel@hotmail.com
Oct 25, 2007 | Audio Players & Recorders
79 people viewed this question
 Grubhead
Grubhead
