Question about Razor MX500 Dirt Rocket
Does the charger port for razor mx500 go bad.. it seems to go from red to green if i move it where it connects to the bike
    Problem Solver:
  • 15 Answers
Yes .stop playing with the connectors...but that do tell urself that is a future problem
Posted on Dec 30, 2012
5 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: mx500 razor
Have you checked for a frozen bearing
Posted on Feb 07, 2009
  • 71 Answers
SOURCE: how do you get the tire of the rear rim of the
i would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
Posted on Jun 09, 2009
vincob
  • 718 Answers
SOURCE: Charge port (blk. wire melted at the end) Smoke from motor
I'm sure it already is cooled down but it needs to cool down after an episode like that. Hopefully the motor stopped running as an over heating issue. If the charger wire melted on the motor where it plugs in, it was to HOT to plug it in at that moment, you should only charge a cool battery. Fuse you can check for look somewhere in the area of the battery, you might need to remove a cover or two to find, if there is one or maybe a fusible link is somewhere in the system.Without seeing this particular bike I cannot tell you exactly where to look. Maybe try online they have service centers for these bikes maybe in your area type in the info on the bikes info plate somewhere on the bike, as a random search for parts and info. Good luck!
Posted on Oct 08, 2009
SOURCE: bought a used razor mx500.
Did you ever solve this problem?
Posted on Dec 03, 2010
It will not run it just click
Most likely, the last 2 answers are correct. When you charge the battery, does the light on the charger stay red for several hours before turning green? Check the voltage of the 3 batteries after the charger light turns green. It should be 39-40 volts or so no load. Turn the throttle and see if the voltage drops when the relay clicks. You can connect the batteries directly to the motor and it should go full speed if they are good.
Mar 02, 2015 | Razor MX500 Dirt Rocket
When charging my light stays red does that mean its charging
Some chargers have 2 LEDs (lights), some have one. Both chargers have an LED that is red (or orange) when the charger is charging a battery and turns green when the battery is charged and the charger has dropped back to trickle charge mode or off.
On the charger with two LEDs , the extra LED is normally red to indicate the mains power is connected.
Sep 10, 2013 | Razor MX500 Dirt Rocket
Our Razor MX500 won't run with out giving the motor a little help getting going. We took the motor off and hooked it to a battery charger and it works fine, you put it back on the bike and it won&
remember the motor transfer the power to the front..there no weight on the motor when you take it off..the motor can be going bad/a singnal! most people change the battery without checking the motor for wear..
Sep 14, 2012 | Razor MX500 Dirt Rocket
Charger keeps flashing red and green and wont charge
Look at the connector end that plugs into the bike. You might have to take it apart to see the wires inside. My son has a Razor Vespa type scooter and the solder job for the wires inside the connector were not the best. It might be a broken wire, especially if it's flashing between red and green.
Hope this Helps!
Please Rate;)
Gary
May 25, 2011 | Razor MX500 Dirt Rocket
Charger flashes red, does this mean it is still charging or is there a problem?
red means it's done or not connecting to charge. Green lit when excepting charge
Feb 26, 2010 | Razor MX500 Dirt Rocket
Oct 06, 2009 | Razor MX500 Dirt Rocket
Razor MX500 Dirt Rocket Logo
117 people viewed this question
Top Razor Cycling Experts
Erick Williams
Erick Williams
Level 1 Expert
Donald Ayers-Marsh
Lawrence Oravetz
Are you a Razor Cycling Expert? Answer questions, earn points and help others
