Once device warms up, CD drawer opens and stays open
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 236 Answers
BUY A MINIDISC.
Posted on Jun 19, 2013
Cd drawer will not stay open
It may just need a good cleaning and a can of computer compressed air while drawer is open. Let us know. Thank you Phirohrer and please leave feedback. Good luck
Jul 12, 2016 | Onkyo DX-C380 6-Disc CD Changer
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
HI. My Acer Aspire 3500 DVD drawer was I guess off track. The drawer wouldn't open so I pried it open. Now it won't stay shut and when it is shut I can't open it unless I use a paper clip.
There is very little you can, these items in general cannot be repaired. Go to www.ebay.com Type make and model of laptop, refine search to cd/dvd driver.
Jun 12, 2012 | Computers & Internet
Cant open cd drawer
most cd players have a small hole in front under the drawer, with the power off, you need a paper clip and straiten it, slowly slide it in the hole until it bottoms out, once it bottoms out you need to push it slowly until the drawer starts to open, mind you it wont open all the way so you will have to open it the rest of the way manually.
Jun 06, 2011 | Audio Players & Recorders
I have a Teac PD-495 CD player. The door will not open - just makes a 'noise' as if it's trying to open the door but can't for some reason. Any thoughts?
Sounds like the door may have something sticky around the edges. Even a little sticky stuff (like from candy-coated fingers...?) can prevent the door\drawer of any CD player from opening.
Try gently "assisting" the door during the few seconds it's trying to open. If it seems like it's not sticking to the housing try the manual eject button.
Depending on your specific device, there should be a very small hole near the door\drawer (Refer to your owners manual for the exact location). It will be just big enough to stick the end of a large paperclip into. Insert the end of a paperclip into the hole and push firmly (make sure nothing is blocking the door\drawer from opening) and the door\drawer should open slightly. Then pull the door\drawer open the rest of the way. If you have to do this, make sure the power is off as the unit might try to close the drawer automatically while you're trying to pull it open.
Once you have the drawer open, inspect the inner surface of the drawer and the area it contacts for anything sticky. Clean with a damp cloth only. Do not spray any cleaner on the unit. If you need to use any cleaners, spray them on the cloth. Clean the area around the inner drawer faceplate and surrounding areas. Let dry for a few minutes then power up and test for operation. It should work fine now.
If not, it may be time to replace this old unit with a new one as repair costs generally exceed the cost of replacement.
Hope this answers your problem. Good Luck!
Dec 04, 2010 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
Dell dimension 2400 cd drawer opens up when
The latch which holds the CD tray in place once the drawer retracts must be faulty. You will need to take it to a repair shop in order to have it fixed, unless you are comfortable with pulling apart the computer shell in order to test the latch to see if it is functional.
If you are not a professional, I would suggest taking it to your local computer repair store for service. They will be able to assess if that is the issue you are having.
Jan 06, 2010 | Dell Dimension 2400 PC Desktop
My CD drawer will not open or close
I had a mini system with the same problem, out of guarantee so was either fix it myself or bin it.
I opened the unit and removed the whole cd drawer assembly from it's housing. I then, not really recommended, plugged it back in and by pressing the open/close a few times the drawer finally opened. Put it all back together and it now works fine. I think what had happened is that I use the cd player once every couple of months and combined with the lack of use is the fact that there are several smokers in the living room and basically it got jammed by a build up of nictotine or whatever.
Apr 01, 2009 | RCA 5-cd 300w Stereo System Shelf System
DVD had a jammed disc. Got it out but drawer stays open
You broke it. Spend $30 to buy a new CD/DVD reader/writer.
Dec 21, 2008 | Compaq (224130-001) Internal 4x CD-ROM...
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
