MY PEN DRIVE DOESNT START IN PC.
NOTHING IS DISPLAYED IN PC WHEN INSERT THE PEN DRIVE. WHY DOES IT HAPPEN SO?
  • 4 Answers
Which systen you are using, insteed of that your pen drive must be detect by PNP support of
operating system , So in short and sweet there is problem in pen drive's communication controller, (may be short circuited or conection termical broken).....
Dinesh patel B.E.Electronics
Posted on Jan 05, 2009
My pen drive works on different computers but doesnt work on mine. I have pen drives that work on my computer except this one. It's a Sony 4 GB pen drive and worked on my PC till a couple of days back. Now...
Check your computer for recently installed updates and use the system restore to try to restore to a point before the drive stoped working. Also, carry out a full virus scan.
Feb 20, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When i insert transend pendrive in my pc it shows a massage f is not formated format it now but when i tried to format it, it displays a massge f can not be formated
VIRUS OR TROJAN INFECTIONS:
Virus or trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert thepen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
CORRUPTED FLASH CHIPS ON PEN DRIVE:
If the pen drive is not detected at all, or shows a less capacity, then there are high chances that its a chipcorruption. Flash chips are the actual hardware components that save the data. A physical or electrical or electromagnetic damage to these chips make the pen drive faulty. This can happen because of voltage fluctuations and faulty USB ports. In such case, get the flash drive replaced if its under warranty as it can not be fixed otherwise.
FAKE PEN DRIVES:
Sounds a bit un-believable but true. There are a lot of pen drives in the market which are of very cheap quality which are fake copies of some known brands. Beware of such pen-drives. Always purchase pen-drives or memory-cards from a reliable source with bill and warranty to avoid any mess later.
Jan 02, 2011 | Transcend (589307) Media
Hello friends, i have one Transcend JF v30/2GB Pen Drive. But when i insert Pendrive then i can't access that. It show the error for fromat the drive. Then i go for do that. Then it display error...
This might happen due to an error or corrupted MBR, which is the sector that allow you pen to be readable and the PC might not recognize the system file being used.
I would try to connect it to another PC with a different Operating system and format it from there.
alternative you can also use Transcend recovery tool. You can download from HERE
Sep 24, 2010 | Electronics - Others
Whenever I insert my pen drive into my pc,it restarts computer. what is the problem ?
if this is only happening on 1 usb port, there is a short in that port that is causing you PC to shut down. Your motherboard BIOS is probably set to reboot on power loss which means it will boot right back up if it shorts out.
If it happens on every USB port then your pen drive is faulty and I would refrain from inserting it anymore before you damage your hardware.
If the pen drive works on someone elses computer, then it sounds like the SOUTHBRIDGE chip (chip on motherboard that controls USB, PCI slots, firewire ports, etc) is going bad or is faulty.
Oct 01, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Malfunction
This can occur if the pen drive was inserted into a HUB rather than direct into a proper usb 2.0 port on the compuer.
It can also happen if the dmive has been mistreated in any way.
You may want to try re-format it from the computer mangement console
rather than my computer or windows explorer
Aug 23, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Loss of volume control
To use another pc and insert volume control cd , then the driver copy to a pen drive and peste it . then you can insert pen drive in your laptop and install the driver.
JEMS 4 U''''''''''''''''
Mar 08, 2009 | NeoWave PC Audio Graphic Equalizer...
4gb SanDisk Cruzer Titanium not working
"limitation is that flash memory has a finite number of erase-write cycles. Most commercially available flash products are guaranteed to withstand around 100,000 write-erase-cycles, before the wear begins to deteriorate the integrity of the storage"
This means that your flash card may have been damaged by not removing correctly Flash card are not that reliable AS previous pen drives
just a sugestion
Dec 22, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
After connecting pendrive with pc it says insert disk into drive.
see first u see the contents in it and then there u see some files not deleted so delte them and then format
Dec 05, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pen drive does not open
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
Jun 17, 2008 | Computers & Internet
Problem detecting transcend pendrive
On opening my pen drive it displays "Pl insert a disk in drive G
Feb 16, 2008 | Transcend T.sonic 612 MP3 Player
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
