Question about Humidifiers
The red vacant light is flashing and it is not working, it shows the humidity level but wont work
Germ guardian humidifier H-3000
  • 10 Answers
SOURCE: Aprilaire 600 just installed and showing an error code
No, it is not an accurate statement.
These units have simple configurations They have a water supply similar to a ice making referigerator, an enclosure connected to your supply duct that houses a prop fan and media, a seperate humidistat and a drain for excess water. Your unit may also include fancy controls including an outside thermometer & humidistat to avoid over humidification that can cause problems during freezing weather. The humidistat looks a lot like a thermostat and is located in your living space or in the return duct. The prop fan in the box pulls air from the duct, through evaporation media and back to the duct. An electric solenoid valve releases water that pours over the media.
If the humidiy is below the humidistat seting and the AC/heater is running, the Aprilaire fan starts and the solenoid valve opens. I suspect the facier controls include the flashing warning light.
The warning light spells problem. Aprilaire's customer service should be able to provide guidance for the homeowner in the form of simple checks. I suspect your contractor is avoiding a warentee call and the trip it requires.
A word of caution. These humidifiers can be powered directly from your air conditioning unit control board from an auxiliary connection. If the control board isn't rated to carry the current required by the Aprilaire fan, valve and controls or the Aprilaire encounters and electrical problem, the board can be damaged. This can be avoided by using a relay. The AC board switches a low energy relay. 120 volt house power is connected to load side of the relay and runs the Aprilaire.
My board cooked at a location near this connection, but I can't be sure that the load from the humidifier caused it since four of our neighbors also lost their board. It failed the evening of a snow storm and required a costly emergency after hours service call. The next day a new board required a three hour drive. Fortunately a fan powered propane heater kept our pipes from freezing.
Posted on Oct 07, 2008
  • 17 Answers
SOURCE: aprilaire 600 humidity level too low
you may try running your blower 100% of the time.this should allow the humidifier to stay on even when your not heating. once the humidity level gets to where you want it, you may be able to put the fan selector back to auto. also you mentioned you have a variable blower. this is great if it is set up to run at approx. 20% fan speed when it is not heating or cooling. at 20% you can circulate enough air through the house to humidify without being able to hear the noise of the blower. it will really increase the comfort level of the house if you tend to have hot and cool spots. if it was not set up this way, contact the installer and ask if they can do this for you.
Posted on Jan 27, 2009
  • 4 Answers
SOURCE: Humidity too low
But by putting it in manual mose, you have to shut it sdown every season. With it in auto mode, and an outdoor sensor hooked up, you won't have to mess with it.
Posted on Feb 09, 2009
SOURCE: How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Posted on Dec 29, 2009
SOURCE: Vicks v4500 humidifier stopped working.
i know why. clean the small long tubular thing that is sucking the water. put a q tip in there and get the gunk out. thats what you need to do -- try it and let me know if it worked. msoobhawan@gmail.com it worked for me!
Posted on Feb 06, 2010
Water refill light prevents unit from working. Tank is filled . Unit has been cleaned
Your problem is most likely a damaged Ultrasonic Disk (sensor).
If your product has not been used for a while, this piece was most likely damaged if it wasn't properly cleaned before storing. Cleaning well sometimes isn't even enough for this sensitive unit.
Unfortunately, there is no way to get this part, even though it is easily removed and could be easily replaced. Bad PR on the manufacturer's part. Your only solution is to send it for repair (if under warranty, you just pay shipping, if not, you pay shipping and $30) or to buy a different brand. You would think for as expensive as these machines are, the manufacturer would have a better solution to this extremely common problem.
Jan 13, 2014 | Germ Guardian H-3000 Ultra-Sonic...
Where do I find manual for germgaurdian H3000 humidifier.
http://www.guardiantechnologies.com/product-instruction-manuals/
Germguaridan website.
This manual can be found under discontinued models. This was most likely discontinued because it is very sensitive and quits working too soon because of the ultrasonic sensor.
Dec 10, 2013 | Germ Guardian H-3000 Ultra-Sonic...
Germ guardian h3000 not blowing air
I have a Vicks, similar, and it recomends a little table salt in the water to create a mist, read your manual and see if this helps. Don't go overboard on the salt, or you'll have old faithful instead of a mist!
Apr 07, 2013 | Germ Guardian H3000 Humidifier
Hi, I was cleaning my H3010 Germ Guardian Humidified and damaged the small round part with 2 wires (JR707). It is the part where the water mist comes from. Is there a way to buy this small thing ot...
For replacement parts contacting the manufacturer of the humidifier would be the best thing to do. They know what parts can be replaced and if they have service repair facilities or if you would need to work directly with the company. Germ Guardian website is www.germguardian.com. Toll free 1-866-603-5900.
Apr 09, 2011 | Germ Guardian Humidifiers
The night light turns on, nothing else works.
check the humidastat, its the setting on how much humidity you want . your supposed to turn on to high speed for a couple of minutes and then switch to low to keep filter wet. the humidity level will affect the on and off operation. other than that test the plug with another appliance such as a lamp to see if plug is good, the night light will work for awhile without power for some reason.
Apr 01, 2011 | Hunter Care-Free Plus 34352 Humidifier
Water only runs with humidistat in test/reset mode. Aprilaire 600 with an Aprilaire 56 Automatic Humidistat, both about 5 years old. Water line is clear, and test mode runs fine for the 1 minute interval....
you need to make sure your humidity level in the house isnt higher then what your humidifier will provide at any givin outdoor temp. this chart is in the owners manual. you cant remove the wires going to the ODS or it will give an error unless you have a resistor to put in its place. Anyway if the humidifier works in test mode according to AA it works so you may have higher humidity than you think, the highest your gonna get is 45% as the temp outside drops it will allow less humidity so it doesnt cause window condinsation (property damage) here is a copy of the chart. the #s on the left are the dial setting
TABLE 2 – % Relative Humidity Guide
Outdoor Temperature (°F)
-10°F 0°F 10°F 20°F 30°F 40°F
10% 10% 10% 15% 20% 25%
2 10% 10% 15% 20% 25% 30%
3 10% 15% 20% 25% 30% 35%
4 15% 20% 25% 30% 35% 40%
5 20% 25% 30% 35% 40% 45%
6 25% 30% 35% 40% 45% 45%
7 30% 35% 40% 45% 45% 45%
Nov 28, 2009 | Aprilaire 600 Humidifier
The power light on my Bemis 4D-7800 humidifier flashes.
On my water wheel several parameters must be met. 1. Power on, cord plugged in. 2. Water in tank, the float arm needs to move to indicate water present, the red light on the dash indicates no water. 3. Humidity controll set higher than the room atmosphere humidity, clockwise is higher on mine. 4. The fan speed selecter must be on either high or low, the fan won't run unless one position is selected. I hope this helps
Dec 30, 2008 | Bemis 4D7-800 Humidifier
Lack of humidity
Try the following test, ( I will resume this is a flow through humidifier)
Spray water directly oin the filter make sure it is saturated. Some water should leak from the bottom. After 10 min measure the Humidity to see if this helped. If there is a higher level of humidity the pbm is that not enough water is saturating the filter. Check the level of the filter & water feed nozzle.
Option 2 is to connect the water feed tube to a Hot water source.
Hope this helps.
Dec 28, 2007 | Honeywell HE220A1019 Whole House...
Humidifiers Logo
196 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
