Question about Dometic Rooftop RV Air Conditioner
What type freon is used in model 630035-331 duo therm ac
    Genius:
  • Dometic Master
  • 1,363 Answers
R-22
Posted on Aug 20, 2015
SOURCE: penguin Duo therm AC bogs
Try replacing the wall thermostat with an electronic unit. It sounds like it is short cycling. If there is not at least 5 min delay before trying to restart the compressor this is what happens. Most electronic thermostats have a delay feature built in to solve this problem.
Posted on Jul 09, 2008
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Posted on Aug 02, 2008
motor1258
  • 6674 Answers
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Posted on Aug 14, 2008
dealt_soul
  • 296 Answers
SOURCE: how many amps does ac draw?
Im taking this is a RV Heater and Air.
Amps 14.7 cooling (at 95 degrees ambient), 12.7 Heating w/optional heat strip
Posted on Jan 20, 2009
heatman101
  • 43501 Answers
SOURCE: Dometic Duo-Therm Model 57915.622 Fan will not start.
Hi, Sounds like your fan motor has gone bad...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
1986 Duo Therm. What type of Freon would have been used?
the gas used will be stated on the plate attached to the outside unit or the ac cabinet outside
it should be R12, R12A or R132A
Oct 14, 2015 | Heating & Cooling
RV Dometic Duo Therm roof top AC w/heat pump Model #630515.321El Serial #21631212 Yr. 2003. It is the rear unit, front unit working fine. In AC mode it is blowing hot air as if the heat pump is on. Fan...
If the Air comeing out is the same as the temp inside the RV make sure the compressor is running and not just the fans. It could be low on freon. If freon is ok then you would need to ck the wiring to the selector switch for a short. It would be obviouse because there will be melted wires. I am leaning toword low on freon since you have already been inside the wiring/control unit.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
What type of freon is used in Model 59516.601 Duo Therm rv Air Conditioner
there is a data tag with the type and weight of the refrigerant used.
Jun 08, 2010 | Heating & Cooling
Replacement Fan Motor
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Duo therm air
unfortunatly with the new laws u are unable to unless u are a licenced refrigeration/ac technician
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
Duo Therm Model 630515
check freeze sensor should be plugged into coil then air box cannot mix intake and cold air if all ok low on Freon cannot refill
Oct 04, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
112 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
