Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
Dell optiplex 320 Desktop problem
I have dell optiplex 320 Desktop computer the windows was working fine so it was infected with the virus then i copy the ghost image in flash desk which was in about 4 GB i run the image which was restoring very slow so i turn of the pc i started booting from Windows XP it is giving the massage press enter to boot the CD when i press enter my monitor screen get black and even it is not prompting for creating partiation and other formulaties and the screen remain black.
please help me.
  • 298 Answers
SOURCE: unable to format the drive r copy files to the drive
Pocket Fuzzies?
Get a bright light and look into the USB connector of the Cruzer. It is possible that there is lint, paper bits, cookei crumbs, etc in there and that is your problem. The outer 2 connections of the USB is DATA and the inner two Power. B/C it is able to flash,you are getting power... but the data lines may be dirty, covered, bent, etc.
Clean it up and try again. Flat toothpick, small ty-wrap or Proxident (dental/braces) brushes work well for this - DO NOT use anything Metal!! It will scratch the connectors and vastly shorten their life (they are GOLD plated)
Short of that, goto HP site and get their USB format tool (get it here: http://files.extremeoverclocking.com/file.php?f=197 ) and try reformatting... if that doesn't work, it is hosed and only I can fix it so let me know ;-)
Posted on Jan 17, 2009
  • 77 Answers
SOURCE: kingston dti/1gb
Have you tried finding the drivers for the USB Flash Drive?
Sometimes XP may need a compatibility drivers.
Posted on Mar 17, 2009
bob_computer
  • 3153 Answers
SOURCE: My windows xp doesn't recognise my Flash USB genx
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Posted on Oct 30, 2009
  • 733 Answers
SOURCE: Can't read Kingston DTI/4 GB flash drive
you have to see in witch format is the stick mostly is FAT32 but normaly you dont need to format just when is some video on it,from my experience reinstal the drivers and i mean all.
Posted on Nov 23, 2009
Beelz
  • 666 Answers
SOURCE: i have a 4 GB kingston datatraveller 120 pen drive
I would say do a firmware wipe but seeing as you have no access to the drive at all I would say your probably SoL and in need of a new drive
hope this helps
Robb
Posted on Apr 26, 2010
330 power supply
Dell Optiplex 330 Desktop Product Video http://www.youtube.com/watch?v=K3CDVOZMVpo DELL (OPTIPLEX GX520/320/330) http://www.youtube.com/watch?v=xbaDqnoDNP4 Unboxing & Setting up My Dell OptiPlex 330 http://www.youtube.com/watch?v=LX_-y8Y9WcY Dell Optiplex Computer Powersupply issues.MTS http://www.youtube.com/watch?v=dzSCXgvAFGg
Mar 25, 2013 | Dell OptiPlex 330 Desktop Desktop Computer...
Optiplex 320 says drive 1 not found:serial ata, sat-1
Actually, just open the case and reseat the drive cable.
Mar 29, 2012 | Dell Drive for Dell OptiPlex 320...
Dell otiplex 760 does not boot
it may due to recent update or changes in driver of the computer. go into safe mode then restore your computer to a week after or virus infection may also cause that
Mar 05, 2012 | Dell OptiPlex 760 MT Desktop Computer
Network card disappeared overnite
Before adding any ethernet card, try to restore your system by using system restore option available with windows to a date on which your system was perfectly working. If the your system works fine after that, then it is quite likely to have your system infected by malicious software or anti virus. Scan your system for virus. If the ethernet is not working then add a new card after disabling the on-board network card in the CMOS setup.
Jan 01, 2012 | Dell OptiPlex GX620 PC Desktop
My problem is that my dell gx260 driver infected by virus i need new dell driver
Have you gone to the Dell Support website? Go to the Dell Support website, then Drivers and Downloads and look up your computer. I found your computer so you should be able to find it, too. There are all the drivers you probably need, although you weren't specific in which driver you need.
Sep 04, 2010 | Dell OptiPlex GX260 PC Desktop
Windows 7 drivers for Optiplex GX620
for drivers u visit driversdownload.com, register and then dowload required drivers for ur comp. i doubt ur computer is affected with virus. pls check it also
Jul 14, 2010 | Dell OptiPlex GX620 PC Desktop
My dell optiplex gx200 bios can't boot
maybe try taking out the cmos battery located in your case, looks like a small watch battery, that will clear bios settings and start from scratch, if there is no battery then there is a jumper sequence to do this
Feb 17, 2009 | Dell OptiPlex GX200 PC Desktop
Dell sound problem
sounds like the virus is still in the computer. you have to get something like Mc Afee virus protection, or Symantecs Spysweeper to get rid of it, and then you should be able to reinstazll the driver. If this does not work, try doing a system restore to the date before this started happening. to do this, go start programs, accessories, tools/system tools, the rest is self explanatory.
Feb 19, 2008 | Dell OptiPlex GX260 PC Desktop
DELL STARTUP
There was problem at one time with IOGear KVMs not working correctly with the USB chipset on the Dell motherboards. This problem was resolved by using a USB hub between the KVM cable and the computer. The user could take the USB portion of the KVM cable and plug it into a USB hub and then take the USB hub and plug it into the Dell computer. That should help with the problem.
Oct 16, 2007 | IOGear GCS632U 2-port KVM Switch
Computers & Internet Logo
80 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
