Question about Toys
Cricut Imagine Die Cut Machine lcd does not display
Lcd does not display
5 Suggested Answers
CricutAddict
  • 13 Answers
SOURCE: my cricut will turn on but the lcd screen is black
Sounds like you have a bad connection in there. I would contact Cricut for tech support; they will probably be able to send you another machine to replace yours. Mind you they will put a charge on your card and remove it when they receive your machine. I hope this helps if you need their contact number get back in touch with me.
Posted on Mar 25, 2010
CricutAddict
  • 13 Answers
SOURCE: Cricut Expressions Machine error
  1. Make sure your cricut is off when you plug it into your computer via usb.
  2. Make sure your usb cable is plugged directly into the machine, and not to a usb hub.
  3. Start up the DS Once the DS is fully loaded, choose HELP > UPDATE FIRMWARE.
  4. On the cricut machine, hold down the STOP button. Keep holding it down and briefly hold down the power button. Keep holding down the stop button and in about 3-5 seconds, you will hear a beep. That means you are good to go.
  5. On the "update firmware" screen on your computer, select the model you have and then click "begin updating now"
  6. Go and read a magazine or make a cup of tea because it takes a while to update. If it goes really fast (no matter how cool your computer is) it means it did not install properly and you will probably have to do it over again.
Hope this helps you.
  • 7 Answers
SOURCE: My LCD on my cricut
after doing some research i found a lot of problems with the machines purchased this xmas exp the colored ones the best thing is to contact cricuit and see if they will replace them
Posted on Jan 11, 2011
SOURCE: WHen the cricut is cutting it tears my paper even
After having the Cricut for many years, I finally figured out how to cut the intricate cuts. Use multi cut 2, speed on med (3) and pressure on 4. I also keep my blade at 4. It takes a lot longer to cut but it cuts out good!
Posted on Oct 17, 2011
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    What exactly is die cutting?
    Die cutting is manufacturing a lot of the same shape from a material. You can do it with fabric or wood, plastic, etc. The shapes you create are called blanks and are usually used decorated before they are sold.
    Feb 27, 2013 | Crafts & Hobbies
    When the cricut is cutting it tears my paper even though the cardstock is good and the machine cannot cut anything intricate. I tried changing the blade, but the same problem still exists
    Mar 12, 2010 | Provo Craft Cricut Disney Font Cartridge
    I can't get my cricut to cut out the whole letter. it cuts part of it but not all of it
    I need more information. Are you using Cricut Design Studio or cutting just from the cricut itself. If you're cutting from Design Studio then you need to make sure your letter is within the space of the mat. If there is some hanging off the edge or past the cut line then it will skip over it and not cut it.
    Feb 15, 2010 | Provo Craft Cricut Disney Font Cartridge
    My cricut will turn on but the lcd screen is black
    Feb 11, 2010 | Provo Craft Cricut Disney Font Cartridge
    How do you put the cricut together?
    I would contact Cricut there are no end user serviceable parts to this machine.
    Jan 18, 2010 | Provo Craft Cricut Disney Font Cartridge
    I just opened the box from a TV ad purchase of the cricut. When I turn it on the carrier moves to the right and makes a horrible noise. Nothing will work.
    Yes, the carriage does move to the right and it makes a funny noise as it moves. The cricut then should light up with display and power light. If yours is not then I would contact Cricut as you may have a defective machine. Just know they will put a charge on your card to ship another machine to you and will remove the charge when you ship your machine with issues back to them.
    Dec 27, 2009 | Provo Craft Cricut Disney Font Cartridge
    LCD not working and not all buttons come on
    I would contact Cricut as there is a way to reset your machine. Resetting your machine may fix the issue. If it continues after the reset Cricut may ask you to send the machine to them. They will however ship another to you after applying a charge to your card then removing the charge after you ship your machine with issues back to them.
    Sep 20, 2009 | Provo Craft Cricut Disney Font Cartridge
    I have a cricut expression die cut machine, the green power light is on but the LCD and other control buttons are not working can you help
    there is a relay on the under side of the keyboard that goes out. ther is a release on the left side of the keyboard on the cricket expression that lets you remove the keyboard for a tall cutter or something. Turn the keyboard over and take the back off.there is a square area that protrudes from the back of the key board. that's where the relay is. it can be replaced. or bypassed.
    Aug 28, 2008 | Computers & Internet
    Toys Logo
    Top Toys Experts
    ray gallant
    Are you a Toy Expert? Answer questions, earn points and help others
