Question about Bloomfield 8571 Coffee Maker
Can the amount of water coming from the waterline be adjusted to ensure a stronger cup of coffee?
    Problem Solver:
  • 11 Answers
Yes there is a timer located behind a removable plug behind the pot to control how long the valve is open. Simply pop the cover off with a standard bit screwdriver and turn counter clockwise to reduce the amount of water in the pot.
Posted on May 20, 2013
LIKE DRINKING WATER WITH A HINT OF COFFEE
You have 3 selections, thus use #1 or #2 for a stronger brew. Naturally the water levels will differ. Get a Reusable Kcup device and pack your own coffee for better results. Get fine ground coffee or grind your own, and then pack the Kcup reusable with your grinds. A fast hot water flow is excellent.
Feb 11, 2014 | Keurig K75 Platinum Coffee Maker w/78...
Coffee to water
The Instruction Manual for the West Bend Coffeemaker can be found here:
http://www.westbend.com/supportdata/L5590A_Coffeemakers_ALL.pdf
See page 4 for amount of coffee to use.
Water Level Amount of Ground Coffee
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
Use electric perk grind coffeeror coofee ground for all coffeemakers. Do not use drip or finely ground coffee.
Mar 19, 2011 | West Bend (58036) 36-Cup Coffee Maker
I can't seem to get a good strong cup of coffee.
Is the green "ready" light on?
You can get a stronger blend K-cup coffee.
3 key components for a great cup of coffee: Water temp., amount of coffee and the quality of the water.
The darker the stronger, but less caffeine, The lighter the blend the more caffeine.
Jan 14, 2011 | Keurig B100 Coffee Maker
How does the pot make strong or reg. coffee by pressing a botton not adding coffee amount ?
By pressing the button for "stronger" coffee, it slows down the rate at which the water enters the grounds. This allows the water to set in the grounds longer and therefore can make the coffee a bit stronger. This is why on some pots when there is a 4 cup setting used, it takes longer for the coffee to be made. With such a small amount of coffee, it should go thru more slowly to get the same result.
Mar 04, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
How many scoops per cup?
Don't follow the machine directions for the coffee, follow the coffee
for amount per cup. Each coffee can call for a different amount.
Once you make a few pots with the same brand you will know if you want a stronger blend or weaker blend.
Start with 1 tablespoon per cup 6 oz of water.
Feb 06, 2010 | Krups Aroma Control 197 Coffee Maker
Does the coffee and water come automatically out of the coffee dispenser or do top up with water after coffee has been dispensed
It comes out together. You can adjust the amount by holding down the coffee button when making coffee and release it when it reaches the desire quantity.Can be adjusted on all three cups individually.
Jan 24, 2010 | Saeco Royal Professional Espresso Machine
Coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Need owner's manual for a West Bend 57870 coffee maker
Manual Not Listed On Website, but Information on Coffee Amount is.
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=2318&secid=54&linkon=category&linkid=21
Coffee Amounts
How much coffee should I use?
4-Cup Quik Drips - We recommend using 1 tablespoon automatic drip or ""all grind"" coffee for each cup being made. You can adjust the amount to suit your personal preference but DO NOT USE MORE THAN 2 TABLESPOONS per cup being made. If more than 2 tablespoons per cup are used flooding of the basket may occur.
10 and 12 Cup Quik Drips - We recommend using 1 tablespoon automatic drip or ""all grind"" coffee for each cup being made. If making less than 4-cups of coffee, add an extra tablespoon of coffee for better flavor. You can adjust the amount of coffee used to suit your personal preference.
Dec 28, 2008 | West Bend 56870 Coffee Maker
West Bend 36 cup coffee maker amounts
It's a percolator. Use about 1 heaping teaspoon of coffee per cup. Each coffee pot is different. You will have to adjust the amount of coffee for what you like.
Dec 03, 2007 | West Bend (58036) 36-Cup Coffee Maker
Need measurement guide
We use 'em every sunday at church - 1/2 cup grounds for every 10 cups water. Allowances: finer coffees will use less grounds, and the more you are making, the fewer grounds you need ( or vice versa- the less you are making, you may need to increase grounds a bit, as perk time will be shorter
Nov 07, 2007 | Faberware 12-55 Cup Coffee Urn
Bloomfield 8571 Coffee Maker Logo
46 people viewed this question
Top Bloomfield Coffee Makers & Espresso Machines Experts
Leakfixr
Level 1 Expert
Kelley Hopper
frankecoffee
Level 1 Expert
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
