Question about RCA HD52W140 52" Rear Projection Television
My tv starts scrolling through video modes,and the menu screen constantly flashes on and off and i turn up the volume and it goes back down by itself,any thoughts how to stop this would be very helpful ,thank you
  • cameron bennett Nov 06, 2012
    sorry my model is a rca hd52w26,would same solutions apply or new ones?
  • RCA Master
  • 8,617 Answers
Thats caused by the Small signal board. which is the green board on the right side with all the inputs on it. Thats a very famous issue for RCA rear projection models.
Posted on Nov 07, 2012
  • 1030 Answers
SOURCE: tv problem
i have encounterd this problem a few times in the shop.. i resolved the issue by replaceing the front control panel pcb. i had one instance of a bad ir sensor causing the problem
Posted on Jan 04, 2008
ladywinn
  • 5138 Answers
SOURCE: Volume & Menu screen flipping out
Replace all of your contact switches on front panel board power/off/on vol- vol+ ch- ch+.
Posted on Jan 05, 2009
  • 184 Answers
SOURCE: MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Posted on Feb 17, 2009
  • 1030 Answers
SOURCE: My tv has got to
this is farely comon i see this all the time at the shop... you have two options replace the keyboard cuircit board. or disconnected and just use your remote to control tv. of coarse you can remove the board until you get a replacment
Posted on Apr 05, 2009
video-tek
  • 150 Answers
SOURCE: menu screen appears constantly, volume decreases by itself
Hi, common issue with rca sets, you need to replace the tact switches on the front control board. If your not good at soldering / un-soldering you may be able to still purchase the whole control board, call a local tv shop with the complete model # and chassis # of your set and they can give you price & availability, video-tek
Posted on Jun 02, 2009
Tv volume goes down
Try a (hard) factory reset
Dec 13, 2017 | Televison & Video
Screen for the menu flashes on constantly while viewing also volume sometimes can't be controlled by remote or tv but other times goes up and down without touching anything
hello,
that problem because switch tack are dirty. Open your TV, pull out pcb than replace all switch or clean up them with WD40 or contact cleaner.
good luck.
Apr 07, 2011 | Televison & Video
My screen indicates hdmi 720p on the top right corner then the video menu pops up. it goes back and forth making watching tv unbarable. also the volume flashes when it is pressed i have a Hesense 32 inch...
The HDMI 720p pop up,because on the tv Menu setup OPTION,U pick YES on the tv Program Title Display option,pick NO should stop the pop up HDMI 720p indicator.The volume bar indicator pop up when it press the button to turn volume up or down it is mornal functions of the tv.
Apr 04, 2011 | Televison & Video
My 26" TDX-02610B LCD Polaroid Flat Screen sometimes goes haywire. On these occasions, remote will not work, except sporadically, and TV responds in fits and surges, scrolling uncontrollably up or down the...
Take out the piggy back signal should solved this problems,not than ur Tuner Signal board have some kind of intermitten short in the board.Must replaced the bard.
Mar 13, 2010 | Polaroid TDX-02610B LCD TV
I have an RCA 27in. screen TV. Cannot program, all is fuzzy.
try unplugging and plugging back in 2 minutes later. go to menu and find channel selection. scroll down to where it says channel. then using volume up and down buttons. will add or erase channel. just play with it and you will see what im talking about. go to channel 4 and press volume up. this will save channel 4 in memory. if no work, try turn on video souce and do a auto program in menu. fixed. enjoy!
Nov 09, 2009 | RCA F27252GY 27" TV
Menu Screen pops up, try to exit and goes to video 1
This could be a stuck button on the front control panel or a bad solder connection on one of the switches on the front control panel.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Menu Trouble
perhaps the volume down button on the TV is stuck. It could be either physically stuck, or the electronic logic could be messed up. Just to rule out a problem with the remote, take the batteries out of it and then adjust the volume at the TV and see what happens.
Sep 07, 2008 | Samsung LN-S4051D 40 in. LCD Television
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Picture goes black
GO TO MENU, THEN SETUP, SCROLL DOWN TO TIMER AND MAKE SURE IT IS ON 0 (ZERO) MIN. SOUNDS LIKE ITS PROGRAMMED TO GO SLEEPAFTER A CERTAIN TIME. THIS TV ALSO CUTS OFF AUTOMATICALLY IN 15 MIN. IF ITS TUNED TO A VACANT CHANNEL( NO PICTURE).
Jun 18, 2008 | Toshiba 36AF42 36" TV
RCA HD52W140 52" Rear Projection Television Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
