Heat is not working on my GE Zoneline 3100 AC/HEATER
Over the summer the unit was not consistently staying on, I replaced the main switch and that seem to have corrected the problem. When I turn on the heat now it stay on for a min. then stops and turns on again, and the heat is blowing cold air. I think maybe the main switch went bad again and/or the temperature control thermostat needs replaced? thank you in advance for your help.
5 Suggested Answers
ACTECH
  • 80 Answers
SOURCE: I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Posted on Jan 14, 2008
  • 54 Answers
SOURCE: Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Posted on Jun 08, 2008
  • 659 Answers
SOURCE: no heat
It sounds like it could be the tstat itself. Unless you use a voltage meter to take some readings it's hard to determine if it is a board. The best thing for you to do is remove the tstat from the system and manually operate it with a jumper wire to try and recreate the problem. If you can't recreate it, by manually turning on the unit, then it's the t-stat and if you can then it is the board. This happens with t-stats occasionally. Good luck and I hope this helps!
Posted on Mar 20, 2009
  • 4 Answers
SOURCE: GE Zoneline 2100 heater/ac won't heat/doesn't shut off
well, it's been almost 4 years since this was posted, but it's the selector knob. these things are HORRIBLY designed (the selector knobs) very easy to break if someone pushes it to the side too hard.
ASSUMING when you cleaned it, you didn't get the controller knob wet, which could cause heat and ac to come on at the same time. If after a few days, it's still the same, it's the selector. I've replaced a million of them (ok, not really a million, but, a lot.)
Posted on Mar 10, 2012
We have a Weatherking Heater/AC unit the heater works and the AC worked last summer when we tried the furnace this winter no heat found out it was the 24 volt transformer replaced it and heat worked fine...
I think you have a definite short and it's in the 24 volt circuit. The only problem is - 'finding a low voltage short' is not the easiest thing in the world to do - so - I would guess you'd need a Service Tech.
good luck!
Jun 28, 2010 | Heating & Cooling
Needs a thermostat
go to sears.com and put the model number and you might be able to order one from there.
Apr 25, 2009 | Heating & Cooling
GE Room Heat/Cool unit will not heat with heat pump
If it was me I would cnage the sensor first. Simply because it is way cheaper than the control board and these sensors are fickle as hell to begin with.
Dec 14, 2008 | GE Zoneline AZ55H07D Air Conditioner
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Zoneline 3100
check on / off switch.
wiring of unit
there is loss connection
Feb 05, 2008 | Heating & Cooling
Jan 22, 2008 | Heating & Cooling
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Loud Popping Sounds
If this is a heat pump system it is possible that your fan blade is hitting ice on your condenser coil.
Nov 17, 2007 | GE Zoneline AZ55H07D Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
