Question about Brother IntelliFax-2820 Laser Fax
Mn1 code on fax - Brother IntelliFax-2820 Laser Fax
My print jobs say printing but no result. stays in the que. printer window shows mn1 and sleep, other than the date and time
If you know how, open the 'printers folder' in your computer and delete all the printing jobs.
Switch off the printer and unplug it from the computer.
Switch off the computer.
Switch on the computer.
Connect the printer and switch it on.
Hopefully it will have cleared itself
Mar 12, 2016 | Brother MFC Office Equipment & Supplies
I need a access code to recieve a fax
you have a fax machine or you have a fax program on your computer?if you have a fax machine you dont need access code.
Nov 27, 2013 | Brother IntelliFAX 1570MC Plain Paper Fax
My fax 2820 has mn1 in the corner of the function window where it should read fax, and is not functioning right what does this mean
hit "menu/set", "0", then "1". using arrows to select "fax only", hit "menu/set", then "stop/exit".
razors
Dec 02, 2011 | Brother IntelliFax-2820 Laser Fax
On the display it has a Mn1 listed. Since this has appeared our machine won't accept any faxes. What do I need to do to clear this and have it receive faxes?
try this. press "menu/set", "0", and "1". use your arrow buttons to select "fax only", then press "menu/set" and press "stop/exit". you should now be able to receive faxes automatically.
hth,
razors
Jan 11, 2011 | Brother IntelliFax-2820 Laser Fax
International Faxing??
you need an international phone service and dialing capability on your phone, the country code for Australia is 61 so you would dial:-
011-61- Y- xxxxxxxx where 011 is international code from USA, 61 is country code Y is area code and xxxxx is fax number.
Just dial the number as sending a local fax
Dec 15, 2009 | HP 1040 Plain Paper Inkjet Fax
LCD display has wrong date
I finally found what I wanted on the Menu and it worked!
P.S. I'm 83 and not all that swift.
Jan 10, 2009 | Brother MFC 420CN All-In-One InkJet...
Won't send faxes to 817 area code, all others OK
The recipient may have a DSL phone line, or receiving to a fax server that blocks your area code.
Oct 14, 2008 | HP 640 Inkjet Fax Machine
MN1 bootloader
First try turning on your phone without the memory card. I suspect you have an SD flash upgrade files in the SD card that's forcing the phone to reflash every time it turn on.
If it is still failed, you could try doing a hard reset? But be carefull, you'll need to back up all your data first, cause it will delete all files and data in the phone.
Dec 03, 2007 | O2 Xda Atom
Printer keeps turning off,,,error message MN1 in lcd
I realise this is an old question but I recently had a similar issue with our MFC-5860CN not receiving faxes and displaying the "Mn1" code. As it turns out "Mn1" means the machine is set to manual receive and was therefore not automatically receiving faxes. You will need to locate the "Receive Mode" option in the menu and change it to "Fax Only" or "Fax / Tel". Unfortunately I dont know what could have caused the turning off and on that the OP mentioned. I'm a little late to the party but I hope this info can help someone else!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother IntelliFax-2820 Laser Fax Logo
27 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
