Question about Toshiba Estudio 200L Copier
Estudio 3511 empty waste toner problem
The machine keeps coming up with empty waste toner. Is there a way to turn of the waste toner check
    President:
  • Toshiba Master
  • 990 Answers
Hello sir;You have to empty waste toner container, it located at the end of the drum unit.
Posted on Jan 05, 2009
I keep getting a message install waste toner box and close all doors, i have tried all that and the message keeps coming, the waste toner box is empty.
remove the toner, check if there is any debris perhaps also blowing in the guides of the toner. Give it a shake and refit it.
Close the doors and if you still get the message you need to replace the empty toner
Mar 11, 2015 | Office Equipment & Supplies
Hi Sir. I got a problem of my Toshiba e studio 3510c printer, when I swich on the button, the screen shows there is a sentence said ;'disposal of the used tonner', should I replace the wasted...
It said exactly what? If it mentioned waste toner, emptying that tray (Toshiba has nice zero-waste-to-landfill toner recycling program) should have pretty much cleared things up; it appears that the sensor for that still sees lumps of toner..or something...coming up close to the paper path. Check it out carefully and replace the tray.
Sep 10, 2011 | Office Equipment & Supplies
Toshiba estudio 450 Used toner cartridge is empty and I have put it back in but machine keeps stating to dispose of used toner...replace the ic of toner cart. is till problem how will solv..?
Hello
You will have to remove the waste toner bottle, put some cleaning solvent in the bottle and wash the toner out of the bottle.
Please the bottle out to dry before you replace it in the machine.
Regards
Jul 24, 2011 | Toshiba E-STUDIO 450 Copier
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
What does CD70 error message mean and how do i fix it. On the printer it says call for service
Waste toner bottle is overfull or you have a problem with the waste toner auger or drive. The simple thing to check is the waste toner container inside the front door and make sure it is not over full. Then check the tube that fits into the bottle for clogged toner. If these simpler things do not resolve the code then you may want to consider calling your local service provider as it gets much more technical from there. Including dis-assembling parts of the machine. Turn off main power to reset the code.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 30, 2010 | Toshiba E-Studio 3511 Color Copier
Our imagistics 8130 has the replace waste toner bottle error message on but the waste bottle is empty and I turned a wheel above the waste toner bottle and nothing.
Hi how are you this is jack ... jack_pak@hotmail.com
Dear you wash the waste toner bottle clearly. But error still your copier you check the waste toner bottle dection SENCER OR IS DIRTY CLEAN IT..
PLEASE VOTE ME .
Thanks
Best Regards,
Aug 14, 2010 | Toshiba E-Studio 3511 Color Copier
Hi, My Toshiba E-Studio 3511 color copier has a error message of 'dispose of used toner.' Even if I followed the direction, the error message is still there and the copier can't work. Would you help me...
I am assuming you have emptied the old waste toner "box" and not replaced it with a new box. This is not a problem, just clarifying. If this is the case then you have toner packed into the sensor block which is telling the machine that the waste toner box is still full. Just look behind the waste toner box and look for a little set of wires. They lead to a small black sensor. Now look at the waste toner box where it mates up with the sensor. You will see a small square box area on the waste toner bottle. The sensor looks thru this block and if it is blocked with toner it will tell the machine the box is full. Just tap on the little block and make sure there is no toner in it and re-install the waste toner box and the indicator should go away.
Aug 11, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba 3530c estudio waste toner error message.
Your waste toner box is located inside the front cover on the far left side of the copier. There is a plastic cover that is just clipped in (no screws) and just pops off, the waste toner box just slides out from there.
Jul 06, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Sep 30, 2009 | Toshiba E-Studio 3511 Color Copier
651 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
