Question about Generac 5793R iX2000 iX Series 2000 Watt Portable Inverter Generator
Ix 2000 surging
Problem with Generac Power Systems Power Generators Generac 5793 Ix 2000 surging. Also the unit surges up and downd very bad when starting a low watt microwave oven. Once started the oven works fine. It seems to do the same thing with other loads alos. Seems like the unit responds quick enough but hunts to stay at a proper power level.. Hope someone can help me, Just Thanks
    Habit-Forming:
  • 80 Answers
YOU NEED TO AJUST THE FUEL MIX ON THE CARBURTOR
Posted on May 22, 2014
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 15kW Generator
That sounds just about right, if the relay contacts get welded together it sometimes takes out the driver on the printed circuit board. As you found out, 12vdc from 23 to 194 makes the transfer switch move to the Generator position, relay not energized makes the ATS move to the Normal position.
You can make a nice test function by installing a 10 amp contact switch in series with either the N1 or N2 terminals. When the switch is open the generator thinks the Normal power has failed.
Regards,
Carl
Posted on Jan 26, 2009
  • 26 Answers
SOURCE: Generac 4456 does not start on power loss
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
Posted on Jul 09, 2009
SOURCE: When utility power goes out, the transfer switch doesn't transfer
Call an electrician.
Posted on Jan 23, 2010
  • 5603 Answers
SOURCE: I have a Generac 15KW generator, the starter went
I suspect you will SOMEPLACE find protection fuse(s) for the sense lines from the utility. That is the first place to check.
Posted on Mar 24, 2010
SOURCE: Generac generator will start, run for a moment and
Its the Oil sensor just pack the oil sensor wires together with a smal screw and bolt and try starting if it starts your problem is the oil sensor they tend to go bad I have run through several myself . To avoid hassles I now have overidden the sensor but I check the oil level everytime I need to use the generator
Posted on Sep 03, 2010
Why is it surging under load?
Yep - the carb needs to be removed and cleaned out thoroughly to remove the clogging responsible for the surging. Motor needs a smooth supply of gas - look at what your car does when you jerk around with the gas pedal. Also check the governor area of generator since that keeps motor running at a certain fixed speed. If there is something wrong with it, that will also cause the problemo.
Sep 08, 2015 | Generac XG8000E - 8000 Watt Electric Start...
Why isn't it producing rated output?
Rated output is at full load. Units will produce power up to that limit and use gas accordingly. Very lite load = less output and less gas consumption, etc.
Aug 27, 2015 | Generac Power Systems Generac 5793 Ix 2000...
Generac ix 2000 mod 0057932 start up ok but then stops running
Possibly blockage in fuel tank or line to carburetor? Fuel filter?
Fuel turn off valve? Generator malfunction that pulls the kill switch?
Owner's manual trouble shooting?
No manual try for owners and repair manual http://www.manualslib.com/
Mar 17, 2015 | Generac Electrical Supplies
Why does my Ryobi 2200 watt generator surge at low RPM's
Engine governor sensitivity may be set too high, it keeps correcting too much, it's typical for all generators, 1 KW - 1 mega watts units.
Nov 17, 2014 | Electrical Supplies
How do I fix this problem
You are drawing to much power and if your not drawing any power and that light is still on then the breakers in the gen are toast
Oct 12, 2014 | Generac iX2000 iX 2000 5793 Portable Power...
Generac 5793R iX2000 iX Series 2000 Watt Portable Inverter Generator Logo
550 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
