Question about Ovens
I am hooking up a double oven to my house the wires coming from my house is black black and copper both blacks are hot the wires coming from the double oven is black red white and copper How do I hoo
    Problem Solver:
  • 6 Answers
The blacks are hots which wilkl give you 220 volts the bare one is the neutral conductor so the hook up the stove black to one lead red to the other white to bare.
Posted on Nov 06, 2012
I am instling a whirlpool accubake double oven, my house wiring is 3 wire (black,black,coper) the instructions say coonect red to red, black to black and white and neutral to coper. If neither of my house...
Doesn't matter....hook one black to the black and the other black to the red....copper to the green,white, and/or ground...whatever you have...
then you are good to go...
heatman101
Apr 30, 2011 | Whirlpool Ovens
It has a white wire,red wire,and bare wire but I on have 2 black wires and one bare wire for ground that comes out the wall.I don't know what hooks up with what
Hi and welcome to FixYa, I am Kelly.
What is the model number so I can look up the installation procedures for THIS oven?
Usually for a 3 wire connection it will be connected as follows:
1 WALL black to the left terminal block terminal
The bare copper wire to the center terminal of the terminal block
2nd WALL black to the right terminal of the terminal block
See this picture link:
http://www.ask-the-electrician.com/images/RANGE%203-WIRE_CORD_CONNECTION_250.JPG
If you notice in the picture it shows a black red and white connection.
Red = black for your connetion 115VAC
White = bare wire neutral Ground
Black = 2nd black for your connection 115 VAC
When the power is connected properly and using the house wires as a reference if you are
reading it with a meter you would read EITHER black wire to the bare wire = 115 - 120VAC
Reading Black to Black = 230 - 240 VAC
If you still have questions feel free to respond here and I will gladly help you.
Thanks for choosing FixYa.
Kelly
Dec 02, 2010 | Ovens
WHERE DOES WHITE WIRE ON WALL OVEN GO FOR HOOK UP - WE HAVE RED, BLACK, WHITE & COPPER
white wire goes in the middle copper goes to ground or chassis
Oct 04, 2010 | Whirlpool Ovens
Oven says: ''supply open neutral'' no buttons work what to do?
That means the range is not connected properly, or the power supply to it is not correct. The range needs the neutral (along with one of the hot leads) to supply the 120 volt portion of the voltage required to operate the control. On built in ovens, the red and black are connected to the two hot supply wires, the white to neutral, and the green or bare copper wire to ground. If your supply only has three incomming wires (older homes) then the green (or bare copper wire) and white are both connected to the neutral.
Nov 11, 2009 | GE Profile JT980 Electric Double Oven
I have a jenn-air wall oven it has a red wire a black wire a white wire and a copper wire but coming out of my wall is only a red/black and copper what dose the white wire go to please help thank you
IF you nhave a 3 wire feed fronm the house for your range, you connect the red and black for the power and then use the copper wire from the wall to connect to the white and copper wires from the range. All new construction must have a 4 wire feed to a range and dryer.
Oct 26, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
I wired up the the Fridgedaire wall oven and it worked for two days and then just shut off. It has a green, white, black and red. The white and green are taped together coming out of the oven. The...
the unit is 240 volts not 120 volts/its ok to have the wht and green tied together so long as it comes directly from the house main panel/new law in some places require them to be separate/wht=Neutral/Green=safety grd to case...now how many watts does this unit draw? 2/12 wires sound awful small for the input current/sounds like you need to upgrade to atleast 2#6 wires for power/1#8 for neutral and atleast a #10 for safety ground
Sep 30, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Ge oven install
go ahead and wire the blk to blk and the red to the white as long as the data plat on the old oven say's 220 you should be ok
Dec 26, 2008 | GE Profile JTP56 Electric Double Oven
Installing my oven
you may not be able to dur this because the whit shoul be a neutral and the red and blk 22o and the copper is your grd. look at the old oven's data plate and see if it says 120/220 volts ok? you may have to get another wire to the ovens
KitchenAid Architect Series KEMC308KSS
the black to white 120 the red to white 120 the red to black 240 the bare copper can tie to the white neutral and ground will work as the same any other reading then there is a voltage problem in the house
Apr 12, 2008 | KitchenAid Architect Series KEMC308KSS...
What coloured wires go where on the main oven thermostat
If you are speaking of the 240v connection to hook up the oven to the electrical source, then white is the neutral(white to white), black is one of the 240v hot wires(black to black), and red is the other 240v hot wire(red to red).
Finally there is a bare or green color ground wire that goes to the bare or green wire form your source.
normally, the two outside wires on a terminal strip are the hot wires and the middle onif the neutral(white). It does not matter which wire(red or black) goes to what hot terminal at the appliance.
If you are talking about the internal wiring, I can get you a schematic of that.
Mar 13, 2008 | Ovens
Ovens Logo
69 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
