Question about RCA HD56W58 56" TV
Resistor and or doides arcing on hd56w58 ( r4718,r4703,r4705) how do i fix it . also having trouble finding parts
What needs to be replaced and where to i find the parts
LOCKS IN STANDBY SWITCHING ON AND OFF AT MAINS DOES NOT HELP, OFTEN HAVE TO WAIT AND GO BACK AND TRY LATER
Power supply problem,the power supply is dead.Its better to repair by the authorized technician.Maybe theres a shorted parts like regulator transistor,doides or leak capacitor and open resistor.
Jul 20, 2011 | Televison & Video
TV is blurry and the red and green look as if the picture is in 3d and I need glasses. Can I fix this myself?
There is almost nothing that can be fixed by yourself if your not trained in high voltages and advanced circuitry now days. This sounds like it could be your color guns going bad or the power supply.
This set also has an issue with The tv convergence board,require 2 STK convergence ICS and some or all it resistors to replaced to solved the tv convergence picture problems.
Jan 12, 2011 | RCA HD56W58 56" HDTV
Shows 3 screens all Different colors overlapping
This tv have a problems known as a convergence problems,it dead.The tv convergence board,require 2 STK convergence ICS and some or all it resistors to replaced to solved the tv convergence picture problems.The shop will,cost u $300-350 for parts and labors.
Oct 07, 2010 | RCA HD56W58 56" HDTV
The tv turns on and the large circuit board just
Sounds like you have Bad FBT Flyback Transfomer
to be sure you need to remove back and see where arking is coming from? Mats Electronics has Parts for this TV.1-800-628-1118 Let me know if you need anymore help.
Mar 23, 2010 | RCA HD56W58 56" HDTV
Arcs at the Top and Bottom of the screen!
You will find small 1/2 or 1watt resistors close to the ic's, you must measure them and they must be exact ohms. I believe you'll find a couple open or have changed in value, I hope the new Ic's haven't been fatigued. That should fix your problem.
Jan 19, 2009 | Philips 60PP9202 60" Rear Projection...
RCA HD56W58
RCA HD56W58 Rear Projection TV quit today. Resistor burnt up r14705. Power light goes on and high pitched noise but no picture or sound.
Nov 09, 2008 | RCA HD56W66 56" HDTV
Won't power on. Burning smell, High pitch arcing sound,
I have a HD56W58 and it had the same problem. One day the picture went blank and then it made a loud popping sound and smelled like something burning. Now it will not turn on. Has this happened to anyone else? I
Jul 20, 2008 | RCA HD56W58 56" TV
Zenith red convergence problem.
yes thats the right board if those two resistors are open the convergence ICs will need to be replaced as well. Its an easy repair. Heres a link where you can order the parts and recieve free installation instruction. If you need me to post the STK numbers and values of the resistors
Apr 02, 2008 | Zenith R40W46 40" Rear Projection...
RCA TV
ok is this s hd56w66 or hd56w58? if its a 56w58 then it is a atc321 chasis there has been some issues with the splitter and defecllection boards with that unit
Mar 23, 2008 | RCA HD56W66 56" HDTV
Screen went black, no picture
A clue to what is wrong is by looking from the back (taking the back off) and looking to see if the three picture tubes have any yellow glow at the bottom of them where the three identical boards are located on each tube.. If you have no glow there you possibly have a resistor R4703 open. It is a 3.3 ohm resistor and feeds the voltage to the filaments in each tube where the glow is suppose to be. If you do have the glow the problem could be much more complicated. Another to check is to see if the menu comes up on the screen. You could possibly be in the wrong input mode, Check your input mode with the input button on the remote The number R4703 is a location number to identify where the resistor is. This is all I can tell you that would not require much more complicated procedures requiring a tv repairman to look at it. If you have an ohm meter you can check R4703 but it must be checked out of circuit. (or at least one leg loose) Hope this helps
Jan 04, 2008 | RCA P52930BL 52" Rear Projection...
RCA HD56W58 56" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
