Question about Canon imageRUNNER 5000 Copier
Software problem with canon copier ir5000i - Canon imageRUNNER 5000 Copier
  • 3 more comments
  • Anonymous Jan 13, 2009
    Hi...
    I have just bought iR5000i (not new). My problem is, after I
    use the copier, sometimes its' software programme is changed by itself.
    Especially when I use the top tray and FLSC settings, the result is
    cropped at the bottom part, its top position is lower than the original
    ( X axis). And it only happen occasionally, for example : the first job
    is ok, but the 2nd job is cropped.
    What should I do about this?
    How
    about the minimum size of free size paper if I could use for "stack
    bypass" without having jammed paper problem? Can I use a piece of paper
    which only sized as ID card?
    Thank you.
  • danar308 Jan 13, 2009
    Hi...
    How
    about the minimum size of free size paper I could use for "stack
    Thank you.
  • Anonymous Jan 23, 2009
    i have canon image5000 every day in the morning when i start the copier machine the earror code is 61-00001 what can i do
  • danar308 Feb 15, 2009
    It only happens when I use legal original papers, and use auto feeding tray at the top of the machine. I have set my paper for legal tray too.
  • Mike May 11, 2010
    how can i help you?
    Problem Solver:
  • 8 Answers
Error 0001 is the main thermistor or sub thermistor has detected about 230 C or higher for 2 sec
Posted on Feb 04, 2009
  • Canon Expert
  • 1,326 Answers
Why don't you change the third paper tray to the size you need. It is the only paper tray that can be change by a end user. The second question is the smallest paper size is a Statement Size, about 5x8, and it will not do envelopes at all the paper path is to long between the paper feed rollers. Good Luck
Posted on Jan 20, 2009
I have error 746 in ir5000i
System software version 9.01 should be installed if the imageRunner does not have the upgraded controller kit.
Sep 13, 2010 | Canon imageRUNNER 5000 Copier
Ir5000i system software E602-01
The error code E602-01 means that the hard drive has a problem. The fix is to replace the hard drive, there are a few tricks to try, but may only hold off the replacing of the hard drive for a short time.
Sep 06, 2010 | Canon imageRUNNER 5000 Copier
I have problem in canon ir5000i the problem is waiting to print error how to solve this problem
Have you deleted all the pendding jobs in your print Q and reboot your computer & copier? Some one may have sent a print job on a odd size paper? Did you see if some one sent a job to the by pass tray. Try to put paper there and let the job run out.. Good Luck
May 11, 2010 | Canon imageRUNNER 5000 Copier
Canon ir5000i check the network connection
if you do not have the machine connected to your network it will display it
Nov 20, 2009 | Canon imageRUNNER 5000 Copier
Ir5000i error 602
Ask Canon. If you're authorized they should be able to help you get what you need.
If you're not a tech get a tech to do it.
Jun 10, 2009 | Canon imageRUNNER 5000 Copier
Document Security
you should be able to send a job to a mailbox and do a secure print that way.
Jun 02, 2009 | Canon imageRUNNER 5000 Copier
Hardisk ir5000/ir5000i
You need to have the hard drive "Flashed" with the correct software. They come from Canon blank, you need to find a tech to flash the HD for you. If your question is if one would work in the other copier, the aswer is yes, but you need to have the printting software on that HD if you want it to print.... Good Luck.... Just for your info. you may want to ask your question in English if you want a respones from one of the techs.
Dec 30, 2008 | Canon imageRUNNER 5000 Copier
Scan to e-mail using Canon ir5000
cant be done with the ir5000s, only the ir5000i. The 5000s only does whats called "pull scanning", where you put the document on the copier and then go to your computer and use an application to "pull" the scan from the copier to your desktop. You can then attach the image to an email and send it that way.
Jul 18, 2008 | Canon imageRUNNER 5000 Copier
Document in queue with "Waiting to print" then doesn't
i know what the problem may be call 0776 4303923
advise is free
Feb 13, 2008 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 5000 Copier Logo
194 people viewed this question
old marine
old marine
