Question about Nintendo Pokemon: Trading Card Game for Game Boy Color
The game boots up(nintedo game boy logo) but then goes blank I think the ram is fried what is your opion.system clean and batterie works fine.
Evety thing looks clean and the baterie shows full charge. clean conections and no visual damage.
  • 53 Answers
SOURCE: wont work the gameboy color screen shows a blurred nintendo logo
this happened to me as well, from personal experience it seems that your game got to hot and fried the circuitry a bit, i had to get a new game, found out if a little moister gets in there and heats up on a hot day, the power supply on the game system fries the circiutry, if you got it used see if they will return it for a better one, if you recently got it, i hope so...best of luck...shia
Posted on May 03, 2009
  • 273 Answers
SOURCE: How do you fix a game boy color game that won't
the game cartridge is dirty.
get a q-tip, put it in the open side of the cartridge game and clean the metal parts that look like piano keys.
hope this helps ;p
please rate solution
Posted on Jan 08, 2010
jecboys
  • 35 Answers
SOURCE: The game won't go past
Take out the game carterage and blow in the end of the game to get any dust or anything out... if that doesn't work your game is probably bad.
Posted on Sep 23, 2010
  • 4 Answers
SOURCE: When i put the game
That happened to my game when i used gameshark, so i stopped cheating.
Posted on Mar 10, 2011
  • 5 Answers
SOURCE: I have the game boy
Lately, many GBC games have hit their age limit. there is a small battery inside each cartridge that allows your game to be saved. follow the instructions below to replace it.
http://www.instructables.com/id/How-To-Replace-A-GBC-Cartridge-Battery/
Posted on Jul 27, 2011
Car will not turn over
check that battery has a full charge andcheck the batery conections for corrosion and tighness
Dec 31, 2013 | 1999 Ford Windstar
When i unplug my phone it says usb conected when it is not
follow the instruction :
1. make sure if your usb port is not damaged specially pin connector,
a) if yes then show some official repairer.
b) if no see point number 2.
2. Make sure if your usb port has a dust,
a) if yes clean with alcohol and brush then see if problem persist,
b) if no see point number 1.a).
If my solution was helpful, please rate my answer.Thanks visiting Fixya.com
Jul 05, 2012 | Samsung Cell Phones
Won't fire after charging battery
ef you have alarm. // remuve nicetive wire black ( --) charge your batery and then look doors and boot and masking tape the switch of your bonett dawn then you conect your batery good luck?
May 27, 2012 | 1992 Buick Roadmaster
Hi, im not quite sure which part i need so any help wold be good. ive got a kawasaki zrx1200-s (2003) which will not start, when i turn the ignition key to on, some times the dash lights come on and some...
HI Dave, according with you discription of the problem (by the way very good explained) look like you have a problem with the wiring conection in some parts or the batery is no good (you don't say if it is new).If the batery is good then start removing every conection and clean it well (w40 is a very good cleaner) dry proply and back assembly the conection. First with the cable from the point of the batery to the main switch with all parts in betewen, like the black box you say (that is probably a relay). After this is finish, or before if you like, check the earth cable, remove it from both ends, at the batery point and at the point where is conected to the engine, I think may be it, the earth cable is the main cause of the problem. Be pacient and do step by step and I'm sure you will resolve the problem. If still it is no enough to resolve the matter, and you consider I'm of value to help you to resolve the problem, do not exitate and send me a message and I will help you with real plessure.
Cheers Oscar
May 04, 2011 | 2002 kawasaki ZRX 1200 R
It wont crank like not getting power
ok sounds like you have a dead battery
1) if turns but slowly:
posible causes:
1.1) old dead batery/
or underchaged battery >check altenator in this case
did you leave your headlights turnt on and drained the battery of its charge?if so get a jump start and then run the car for 30-45 mins to rechagre the battery
if you have at your disposal anothere batery that you know has a good charge
try starting your car with that batery(not using jumper cables) hook it up!
if the slugish turn over is still there
1.2) check your wire conections for corision this means completly disconecting 1 lead at a time (only on one end of that lead)and cleaning them with a wire brush or some sand paper.
(on the battery and the starter also the ground strap conection to the frame.)
2) WONT TURN OVER AT ALL:
posible causes:
2.0) dead battery >try charging it>get a jump start
2.1) blown turnkey igntion fuse
2.2) blow fuse for main har nes wires
2.3) bad starter
2.4) corosion on wire conection (most often the batery terminals)
2.5) starter replaced and hooked up incorectly.
2.6) alram system preventing the turnkey igntion system from getting power
Feb 24, 2010 | 1994 Mazda 626
4x4 doesnt work at all.no lights on the dash nothing.2001 s10 blazer can i fix this myself.looks like a corrided wie.tried it last year,she came back after i cleaned it up,but once i shut off the...
YOU MAST GET STEP BY STEP ON THIS PROBLEM TO RESOLVE FRST CHECK BATERY MEYBI YOU NIDED ANADAR VAN IF THIS IS TO OLD END CANT HOLD ELECRIC INSIDE .STEP 2 CHECK YOUR ALTERNATOR HIS CHARGING BATERY VEN MOTOR RUNING IF BROKEN FIX IT .3 CLEAN OLL ELECTRIC CONTACTS END INSURE GOOD GRAUND( - )POLE TO EVRY PART OF VECHILE DOORS ENGINE SHASHY EVEN THE DASH MAST HAVE GRAUND CONECTION YU MAST PUT THE DASH DAUNT TO CHECK EVRI LIGHT END HIS CONECTION DANGER:VORK SLOVLY TO IMPROVE CHIRCHUT.I THINK THE BIGEST PROBLEN IS VITH ALTERNATOR(BATERY CHARGER)-VISIT nedic@nikola.com for more help
Nov 08, 2009 | 1994 Chevrolet S-10 Blazer
87 regal will not start. i turn key starter just clicks but does not begin to turn motor. ita new napa lifetime starter
Hi check the batery conection to be well tigth and clean, if they are ok you have to check the starter motor an the starter solenoid, very often its only brushes. allso if you rotate the crank shaft some times fix the problem. and dont forget to check the batery charge.
Jun 28, 2009 | 1987 Buick Regal
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
Will Not Detect Battery
Check your battery capacity if its below 3v then you'll need to get it back up by rejuvenating it. also clean the system connector on the phone where the charger conects into. Good luck.
Aug 08, 2006 | Samsung SCH-a650
Nintendo Pokemon: Trading Card Game for Game Boy Color Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
