Question about Craftsman Air Tools & Compressors
Craftsman evolv brad nailer - Craftsman Air Tools & Compressors
  • 74 Answers
SOURCE: porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Posted on Aug 29, 2009
Testimonial: "Thanks for the info. I was not oiling it at that rate. Is there anything I can do to fix the issue now that I didn't prevent it?"
  • 10865 Answers
SOURCE: need a manual for craftsman 18 ga comb
go to sears.com where all of these manuals are found in downloadable form.
Posted on Oct 29, 2009
SOURCE: Craftsman nailer striker is stuck down after firing.
my porter cable nailer does the same thing. what is the problem
Posted on Jan 27, 2010
  • 142 Answers
SOURCE: My brad nailer shoots staples without any problem
the only suggestion i have is that you may have a feed problem, so i would clean and lube the track the nails run on
Posted on Mar 27, 2010
  • 885 Answers
SOURCE: does the brad nailer only use 2" brads or cam
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Posted on Oct 22, 2010
How do you load the brads.
Depends on the Type of Brad nailer & Model No. Gimmie that info please?
Nov 29, 2017 | Tools & Hardware - Others
How do I fix my craftsman electric brad nailer
I have one that looks just like the illustration and mine doesn't operate either. I have had it apart and the switch is faulty and seems to be a very poor design.
Mine has a different brand name (Rapesco) and under the label is a generic Chinese export which the local supplier reckons is a throw-away item and no spares are available.
One of these days I will exercise some guile and attempt a repair.
Feb 02, 2015 | Craftsman Electric Brad Nailer
Craftsman 18 guage nailer jams
Make sure that you are using the correct gauge nails
Feb 23, 2013 | Craftsman Air Tools & Compressors
Evolv 2 brad nailer no power
If you can check nailer on another compressor. If it works check your compressor, if not the nail gun is in need of repairs. Otherwise, reading the two guages on the compressor, check that the pressure in the tank is around 100psi and the regulated pressure is between 85 and 90psi. If not, regulated pressure is adjusted by the knob on the front of the housing. With a blowgun on the end of hose, connect the other end to the compressor. If you don't get any air the regulator may be broken and not letting air through. If you have air at the blowgun the problem may be with the nailer.
Apr 08, 2012 | Craftsman Air Tools & Compressors
Craftsman evolv braid nailer leaks air around the trigger when i try to nail. it does not nail sears no. 00915206000 mfg no. 42081 (for kit) on gun model:6G28/F50
Air leaking from trigger when trying to nail indicates that the headvalve is stuck or headvalve orings are dry and allowing air to pass. Remove the head and pull out the headvalve piston. Examine orings for cuts or broken (replace as needed if orings worn and cannot make seal). If headvalve was stuck/dry, lube with plenty of silicone paste lube (sold at Lowes in the plumbing dept. ). Should be good to go. Good luck
Jun 30, 2011 | Craftsman 184060184070184080 Brad Nailer...
Jan 26, 2010 | Air Tools & Compressors
Need a manual for craftsman 18 ga comb
Oct 29, 2009 | Air Tools & Compressors
No brad
Your anvil is not returning to the home position to allow the brad to index into the receiver. Try and push the anvil up all the way to the home position. If that works, then you need lubrication, new return spring, etc. All related to the anvil firing.
Jul 02, 2009 | Craftsman Nailer Kit, Palm Air Driver
Air Tools & Compressors Logo
67 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
