PIXMA MG 6250 problem
Printer is offline, will not print.
SOURCE: canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Posted on Mar 12, 2008
aicaxz
  • 511 Answers
SOURCE: i was trying to print using a PIXMA iP1300 but it
Printer offline : make online in printer properties.Printer offline when start to print : head problem. Replace head.
Posted on Jun 12, 2009
takibd
  • 26 Answers
SOURCE: Canon Pixma MP150 offline - won't print from computer
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-25
Posted on Sep 04, 2009
SOURCE: Just set up cannon PIXMA
I had the same problem - my printer showed that wireless LAN was enabled & my mac showed the printer but said it was offline. I went to preferences, print & fax, hit the + key to add a printer, added the canon printer again, set that printer as my default, did a print command from Word & that created a queue in the new default printer ... and it printed. Deleted the first Canon printer that was "offline." Oh, and I'm not sure if it made a difference, but before what I just described, I checked for software updates after the printer CD install process & uploaded one update.
Posted on Feb 23, 2011
SOURCE: Canon PIXMA MP495 InkJet Printer - Offline issues
For Vista wireless setup: Open your Control Panel. Choose Printers. In the Printers box it lists your printers. Hover over the wireless printer icon, right click, choose Run as Administrator, then choose Use Printer online. This should change the status of the printer to Ready (from Offline). Be sure you've chosen this printer as your default printer. Might have to do this on a regular basis.
Posted on Dec 11, 2011
My Canon Pixma MG5200 will not print E-MAILS or browser items
When you rightclick on the side you want to print, choose print and some times you have to chose printer.
Aug 10, 2014 | Canon Large Black Pixma Mg 5200 Compatible...
Printer offline which was working earlier
My computer detected printer offline. I have just used to print some documents. So, please advise what is the problem.
Mar 28, 2013 | Canon Black Pixma Mp 280 High Quality...
My printer keeps saying it's offline what could be wrong?
Use printer offline setting on the computer maybe checked. For win xp
  1. click on start,printers and faxes then right-click on the Canon Pixma Mp250 printer logo.
  2. if use printer offline has a check mark before it,left-click on it to remove the check mark.
  3. restart printer
  4. try printing again
For win vista
  1. click on start,in the search box,key in printers then hit the enter key on the keyboard.
  2. right-click on the Canon Pixma Mp250 printer logo.
  3. if use printer offline has a check mark before it,left-click on it to remove the check mark.
  4. restart printer
  5. try printing again
For win 7
  1. click on start,in the search box,put in devices and printers,hit enter
  4. restart printer.
Let me know if the steps above do not solve your problem.
Jul 17, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Just set up cannon PIXMA MX870 printer. Cannot get it to print from wireless connection. In my printer box it says the printer is offline. It will print when I connect the printer with a cable. I use a...
Jan 27, 2011 | Canon PIXMA MX870 Wireless Office...
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Won't print because it says its offline, what should i do to make sure it prints
go to the printer folder double click on the printer, go to the printer menu and uncheck use printer offline and try to print.
Jul 08, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
I was trying to print using a PIXMA iP1300 but it doesn't allow printing withe a message box appearing "printer is offline".can you help me please
Jun 12, 2009 | Canon PIXMA iP1300 Printer
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
110 people viewed this question
k24674
jasbo
jasbo
