Question about Husqvarna 28CC Handheld BlowerVac
Husqvarna leaf blower won"t start,changed the plug and gas,now what
boscia
  • 163 Answers
SOURCE: leafblower
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
  • 251 Answers
SOURCE: husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Posted on Oct 21, 2009
jdlipscomb41
  • 157 Answers
SOURCE: what is the ratio of oil to gas for Husqvarna leaf
i mix my husky and stihl the same 50;1 ratio that way i know it has enough oil not to burn the piston
Posted on Oct 26, 2009
  • 110 Answers
SOURCE: My husqvarna 225B leaf blower starts easy when
A few possibilities, first check the tiny little vent hole in the gas cap for a clog.Second, check the fuel filter in the tank. Third, remove the muffler and inspect the piston for scores and that the rings are free, remove ant carbon build up from the exhaust port. If the trouble persists its time to go into the carb, The pump and metering diapgragms will harden over time and loose their elasticity and cause this problem also
Posted on Nov 01, 2009
  • 198 Answers
SOURCE: Husqvarna Leaf Blower won't start
yes, it is. i suggest checking to make sure the plug is firing--you can check by removing it, plugging it back into the plug wire and resting the threads of the plug on any ground--usually right outside the spot where the plug screws in. have someone pull the cord while you see if the plug fires. DON'T touch the plug while the engine is being cranked. also, even if you see a spark, it may not fire inside the engine. if the spark is weak, you may want to put in a new one.
Posted on May 12, 2010
Worked last weekend will not start
Need more info. Is it getting gas? You can check this by squirting some fuel into the carb or spark plug hole and cranking it. If it tries to go, then it is getting gas. (Be sure to put the plug back in though). We can work from there. . .
Mar 25, 2014 | Husqvarna 130bt 130 Bt Gas Powered...
As you pull the cord do you feel a thud thud? if not you don't have compresion. However take the carb apart and clean it with carb cleaner it only takes one small peice of **** to cause trouble.Dennis
Nov 06, 2012 | Husqvarna 28CC Handheld BlowerVac
Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Aug 02, 2011 | Husqvarna Hand Held Blower 125 B Grass...
The blower will not start. I changed the spark plug but it still will not fire..
Maybe you have some problem with the carburator. You can put some gas in the carb if it start and then turn out your problem was the carb.
Jan 08, 2011 | Husqvarna 28cc Hand Held Blower HVH 125B
May 11, 2010 | Husqvarna 28CC Handheld BlowerVac
Unable to start my 155BT blower. Have changed
Is the new spark plug wet? If not, the machine is not getting fuel (fuel filter, carb, etc.) If the plug is wet, you may not be getting spark (bad ignition module, short in switch/harness, bad plug (yes it does happen with even new plugs)), or flooding due to incorrect starting procedure or clogged airfilter. Stale fuel can also cause an engine not to start as it lacks volatility. If in doubt, take it to your local dealer.
Oct 22, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Husqvarna 28CC Handheld BlowerVac Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
