Question about Plumbing
How to replace cartridge mico 7705 - Plumbing
Where can I buy cartridges for my Mico kitchen faucet?
try plumber supplies wholesalers where the plumbers get their spares from
not a hardware or supermarket shop
Dec 24, 2017 | Plumbing
Does Maxi cosi pebble car seat cover fit to maxi cosi mico car seat?
Hi
We wouldn't advise a Pebble fabric on a Mico as the models are a different design so the Pebble fabric wouldn't be an optimum fit on the Mico model.
For replacement Mico fabric contact crelations@djgusa.com
Apr 25, 2013 | Maxi-Cosi Mico Infant Car Seat
Is there a sim card slot the nokia twist?
i want to purchase a nokia 7705 twist phone unlocked off of amazon and my question is does it have a slot for a sim card to be used
Jul 28, 2011 | Nokia 7705 Cell Phone
NOKIA TWIST 7705 PHONE WON'T CHARGE
it could be that a problem between the charger or phone contact examine the two and see if this is the problem. If the contacts are dirty try cleaning them with a pin tip gently.
Mar 01, 2010 | Nokia 7705 Cell Phone
One Handle Tap has gone random and hot/cold keep moving position.
look under the cap for a screw,see if you can tighten,if no screw under the handle is a plastic piece that is attached to the faucet diverter,this may have broken or the screw has come loose.you may have to replace the handle
Jul 30, 2009 | Plumbing
I have a Mico 7777 Kitchen faucet that was purchased in 2001.It has become difficult to move from side to side. Do we need to replace the cartridge in the faucet and if so how much does it cost and how...
it may not be nesesary to replase the cartridge you could just have some lime or sediment build up in the faucet a bad cartridge would effect your handle not your spout turn the hot and cold water off under the sink,pull the bonnet or cap off and the spout should just lift up take care not to damage o-rings pulling and reinstalling spout check for debris clean and replace spout to insure not damaging o-ring try putting a little vaseline on them 1.it will help go on easier 2.it will help to lubricate the swivel of the spout replace the cap turn your water back on. if your cartridge is bad your faucet will drip or constantly run
Apr 07, 2009 | Plumbing
Broken thumb lever to a kitchen faucet side spray
Unless you have a super duper fancy faucet, all spray head for kitchen faucets are standard, and can be picked up at any hardware store, home depot, lowes or plumbing supply.
The easiest method of replacement is to screw off the handle, and leave the old hose intact. On the hose you will find two black washers. one fat and one thin. Take note which one comes off first and replace in that order. Pull back the screw housing and you will see the white plastic tube on the end of the spray hose has a locking ring nestled in a groove. Remove it. Now you can remove the old screw housing and put the new one on. After putting the handle screw housing on the hose, install the lock ring back into the groove., put washers back on in correct order, and screw your new spray head on. Good luck!
Apr 08, 2017 | Plumbing
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
