Where Can I Find A Manual For An Eberhard Faber Rapid 90 electric stapler? I do not know how to open the stapler to install staples or how to troubleshoot it. Stapler will do 1 staple then I have to
Information on the tag on the bottom: ISABERG AB SWEDEN TYPE 90B No184142 115V~ 50/60Hz AVERAGE 30W Registered Design GB NO 1001818
  • 2072 Answers
SOURCE: AS 300 electric stapler--pulled out
What has most likely happened is part of a staple is stuck in the front portion of the stapler where it forms the staple and presses it into the stapler.
You would most likely have to remove the stapler, and remove the binding staple from the stapler head.
Posted on Sep 28, 2008
brainyass
  • 242 Answers
SOURCE: Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
Posted on Oct 23, 2008
  • 1602 Answers
SOURCE: Inspiron 2200 what headset with microphone?
TAKE YOUR OLD PEAR WITH YOU AND COMPAIR THEM
MAKE SURE THE PLUG IN PARTS LOOK THE SAME OR CLOSE TO THE SAME OR IT MAY NOT WORK
SAME LINKTH
CANDYMANGANDY
Posted on Jan 28, 2009
SOURCE: loading staples
Never used one before and sons lost the packaging. No instructions.
Posted on Dec 04, 2009
faceofftech
  • 185 Answers
SOURCE: I have a manual Craftsman stapler 68447 and an
you can try here:
http://cgi.ebay.com/NEW-ARROW-1-4-MONEL-STAPLE-504M1-/220606637809?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335d2e26f1#ht_2432wt_911
I checked the crown website and it is a little bit harder to buy from them
if it works for you don't forget to rate me
thx
Posted on May 21, 2010
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How do I prevent Rapid 5080e stapler from jamming
Make sure that the tray for the staples is clean and LIGHTLY oiled, Staples are held together with glue. IT could also be an issue with the wear on the staple head driver. If you use it a lot, the unit might be worn to the point that it is out of spec.
Aug 28, 2015 | Rapid 5080E HEAVY-DUTY FLAT CLINCH...
We have a rapid heavyduty 9 stapler and need to replace staples. put in and know will not staple??
reset the anvil where they should come out with a flat bladed screw driver by pushing the anvil back up
Feb 18, 2015 | Tools & Hardware - Others
What gage staples do I need for a p300 ryobi air stapler?
Good morning Victoria,
The staple series that you'll need is probably need is a 90 series. These are again an 18gauge wire in several different lengths.
Regards
collatedfasteners
Jul 05, 2014 | Ryobi P300 One+ Stapler Brad Nailer
900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Mar 27, 2013 | Tools & Hardware - Others
Panosonic Electric Stapler does not staple paper!
It could be either jammed up with staples or the spring mechanism is shoddy.
Apr 14, 2009 | Office Equipment & Supplies
Installing nail brad in a stapler
I have the same problem and the silly thing is I have used it. Ridiculous that you can't find a manual on it. Well, I have solved it!!!!
our problem is we open the stapler and stare straight down into the cavity. But if you angle it, you can see that there are grooves along the side which the head of the brads would hang and slide along.
1. on one side of the stapler it will say "load brad this side"
2. open the chamber and place the stapler on its side with the aforementioned side down
3 place your strand of brads in the appropriate groove and close the chamber
4 start shooting
pklew52@gmail.com
Dec 22, 2008 | Electric Stanley Tre500 Staple Gun /...
Staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Aug 27, 2008 | Black & Decker 5700 Powershot Forward...
355 people viewed this question
jasbo
jasbo
