Question about Philips 32PFL5403 LCD TV
Sound quality problem
Picture is OK but sound deteriorates as volme control goes above 50% on all chanels. The sound is still there but there is a terrible 'flat metalic' sound superimposed as if the speaker diaphrams are torn. It started slowly about over 2 months or so I had to use computer speakers fed from earphone socket. Sound is better but metalic sound is still evident but much quieter. Is it speakers, amp or settings???
SOURCE: 15PF9936/12 Flat TV
need new tv
Posted on Feb 20, 2008
SOURCE: Sound Problem
Hi all
I also had this problem. I fixed it by tracing the fault to a dry joint on Z401, a zener diode responsible for the -7v to IC405/6.
There are 4 zener diodes (Z401 - 4) that should have between 6 and 7 v across them. They're visible from the top side of the main PCB.
There's an excellent Service manual available from here.
I'm listening to my LX3000d right now with a smile on my face.
Posted on Apr 04, 2008
  • 14 Answers
SOURCE: very low output
Are the Philips speakers powered ????
Try in the headphone socket on a radio and check the sound then.
Posted on Aug 01, 2008
  • 66 Answers
SOURCE: additional speakers
two options use the RCA audio out (red and white) on the back or side of the tv to connect to a home theatre system also you could use the headphone jack to connect to a home theatre system or some sort of external speakers. other than that it doesnt look like you have too many options on that model of tv if you need the owners manual here is the link for an online version.
Posted on May 24, 2009
  • 203 Answers
SOURCE: Philips 42PFL3603 tv sound but no picture.
Hold a flash light to the screen after it goes off and see if you can see a faint picture. Sounds like your backlight might be cutting off. Repair can be expensive but some of the newer units don't require the entire LCD to be replaced.
Posted on Sep 27, 2009
How can found this problem,a 14"sansui tv displayed with check screen program can changed volm cntrol working but not sound and picture?
Sounds like system control-chroma IC jungle have damaged. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Sep 26, 2014 | Sansui Televison & Video
Sound ok no picture hp invent comes on then the screen goes gray
Display or its board has got affected partially and might require the attention of a qualified service technician.
Jul 30, 2012 | HP PL4260N 42 in. Plasma HDTV
Ive got a freesat dish and reciever but we get 90% signal but no quality any suggestions
Your on the wrong satellite, If your on any satellite youll get a high Signal but you wont get a high quality until your on the specific satellite. Astra 2A is for freesat. If you can bring that up on the menu then just keep moving the dish until the quality goes above 50% and that will suffice for a decent picture.
Mar 14, 2011 | Televison & Video
My computer xp not come sound volme icon, what i do
Please check if the sound driver is installed, if sould is available but the sound icon is missing please follow the following steps.
Click on start
Click on settings / control pannel
Click on Sound and audio devices
In the volume tab you will find a check box Place volume control icon in the taskbar
check this box if you need to have a volume icon in the system tray / notification area.
If the above option is not working or sound driver is not installed, please download the updated driver from the website or the CD that came along with the sound card and then try the same steps above.
Dec 25, 2010 | EZ Media EZ-Media 8738 4-Channel PCI...
No picture
try replaced DIGITAL PCB ***'Y
Manufacturer Toshiba
Part Number 72784100
Description DIGITAL PCB ***'Y
Apr 27, 2010 | Toshiba 50HP66 50 in. Plasma Television
I have replaced a yellow cartridge and the colours
If this is a remanufactured cartridge, and its the yellow (new cartridge) that has gone weak, this could be caused by a missing idler gear.
I do the QC checks on a lot of these cartridges and have seen the occasional missing gear. It can happen sometimes.
The cartridge could have tested OK at manufacture, but then deteriorated in use
First, check the end of the cartridge with the white plastic 'end cap'. This is held on by a single screw (don't loose it, or the spring that pulls the two halves of the cartridge together).
Having removed the end cap being careful not to damage it, if the small idler gear is present, it will look like the following picture.
If the small idler gear is missing, this WILL cause rapid deterioration of print quality, certainly within 50 pages and I would have expected to see deterioration within less than 30.
The other side of the cartridge is more difficult to remove, and there are therr idler gears at that end, any 1 of them if missing will cause deterioration of print quality, though I would expect more than 50 pages before it would show.
Regardless, if the cartridge is new OEM, or new remanufactured, it should have some sort of warranty, so talk to your supplier.
Apr 21, 2010 | Dell 3110cn Laser Printer
Hdmi audio not working when conected to tv
Follow these steps to change the audio output settings for the HDMI option.
  1. Follow steps 1 through 8 above.
  2. From the Windows Vista™ default Start menu, click Control Panel.
    View Picture
  3. In Control Panel, using the default Control Panel Home setting, click Hardware and Sound.
    View Picture
  4. In the Hardware and Sound window, under Sound click Manage audio devices.
    View Picture
  5. In the Sound dialog box, click to select Digital Output Devices (HDMI).
    View Picture
  6. Click Set Default, and then click OK
    View Picture
Note: The default audio setting for your notebook is Speakers / Headphones.
You must change the audio output back to the Speakers / Headphones option for the computer to once again be able to use the internal speakers and headphone jack.
Sep 24, 2009 | Gateway T-1620 Notebook
No sound on tv chanel
hi, no sound with tv but have picture, also have lost sky but works on other tv with a tv link, tv make LG Lh3000
Apr 22, 2009 | Logitech Harmony One Advanced Universal...
Creative speakers 2.1 Deteriorated sound quality
Yes.speakers like all the other computers parts need to be maintained very well.dust can deteriorate the sound quality.Regular servicing might help out to get the original quality.Else you can do it on your own by cleaning with a normal hand brush.Hope this helps you out.Please do rate If this could solve your problem.
Sep 12, 2008 | Creative Labs SBS 330 Computer Speakers
How can I set my option as 'default'?
This could be a firmware problem Tell Olympus Tech support team
Jul 20, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Philips 32PFL5403 LCD TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
