Question about Panasonic Palmcorder SDR-H18 Camcorder
I am unable to connect it to my PC for transfereing pictures.
Th problem is that if i want to fix the wire in the cam then i have to remove its battery bcoz of the location of the wire-socket in the cam. Now, if the I remove the battery it wouldn't start even when the USB wire is connected to my PC.
  • itsmyid_meht Jan 07, 2009
    I was missing on the power cable.....I am comfortable with the entire apratus now....thanks a lot for your assistence....
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you have a power cord for it?
  • Panasonic Master
  • 2,794 Answers
I don't know if the usb cord is a good power source for it. That wire may provide data service only but no power to the camcorder.
Posted on Jan 07, 2009
How to transper the picture in netbook to digital cam
there are two ways:
1. plugging the usb cable of the camera into the netbook ang transfer/copy the pictures from the netbook to the cam.
2. removing the memory card of the camera and attach it into a card reader then transfer the pictures from the Pc to the memory card
May 31, 2011 | HP Mini 1000 Netbook
Aiptek camera transfer to cumputer
Using the PC Camera Function
1. Installing the AF Cam driver
You need to install the AF Cam driver before using PC Camera
or video conferencing function.
* If you have already installed the AF Cam driver, skip step 1. "Installing the AF Cam driver" and go to step 2. "Connecting your camera to your computer".
2. Connecting your camera to your computer
2.1 Turn on your computer
2.3 Insert the USB cable to the USB port on your computer
2.4 Insert the other end of the USB cable to the USB port on your camera.
* Then you can see the camera as removable disk. You can transfer the pictures from your camera to your computer like transfering files from one folder to another.
1. Go to camera folder
2. Select the file/pictures you want to transfer then right click and choose move option (if you want the files to be moved on your computer) then choose the desired target folder or drive.
*you can just copy the files form the camera to your computer too.
select the files that you want to copy then right click, choose copy then paste on the desired folder or drive.
Apr 09, 2010 | Aiptek PocketCam 3M Digital Camera
Photograph Transfer. Unable to transfer from VAIO
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Feb 09, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
Unable to transfer photos from by phone to my PC.
ck settings in pc might have to reinstall most software problems can be fixed with fresh install.
Feb 01, 2010 | Cell Phones
Unable to transfer pictures from camera to pc
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
May 04, 2009 | Pix FUJIFILM Fine S1500fd Digital Camera
Unable to load pics from cam to pc
i think your memory stick create problem,put out your memory from the camera , and take some picture on your camera s internal memory and than connect it to your pc
Feb 22, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Have an Olympus Stylus 850 SW...........How do I down load photos from my Favorites in camera to a computer. Is this even possible? thanx ernie
yes this is possible all you have to do is follow these instructions:
there is two ways to load pictures from your cam to pc:
step 1
youll need a card reader to put in the memory card to a usb port.
A.then the computer will recognize the device as a FLASH DISK/ REMOVABLE DISK.
B.some pc will automatically open once you inserted the card reader to the usb port "click open containing folder". if the pc does not open automatically open my computer and find the "falsh disk/removable disk" and click.
C.once inside find the DCIM folder this contains your pictures taken from your cam.
D. now you can choose a picture you like to be transfered or copy to your PC
E. save picture in a folder that you ca easily remember
step 2
need a usb wire to connect cam to usb port
A. attach wire from your cam to usb port/pc
B. your cam will show options choose storage data. the other options requires a software
C.same as step 1 from B-E
i hope i was able to help you! good luck!
Nov 18, 2008 | Olympus Cameras
Lost software disc
step 1
B.some pc will automatically open once you inserted the card reader to the usb port "click open containing folder". if the pc does not open automatically open my computer and find the "flash disk/removable disk" and click.
step 2
here is the site for version 1.10:
http://drivers.softpedia.com/progDownload/Pentax-Optio-230-110-Download-16224.html
here is the site for version 2.1
http://driverscollection.com/?file_id=29747
Nov 16, 2008 | Pentax Optio 230 Digital Camera
Help Please
step 1
step 2
i hope i was able to help you with your problem! good luck!
Nov 02, 2008 | Canon PowerShot A80 Digital Camera
Can't get the software for my new Panasonic TZ5 Lumix to load into my iMac! iMac doesn't recognize it as a CD. Urgently need to download my photos to update my website! Help! Patti
step 1
step 2
Nov 01, 2008 | Cameras
Panasonic Palmcorder  SDR-H18 Camcorder Logo
94 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
