Question about HP LaserJet 4700 Printer
How to perform nvram clear on hp laserjet 4700
  • 624 Answers
SOURCE: hp color laserjet 4700
Evening eavotri, -The first thing to do is pull out the EIO card and all of the added memory. -Restart the printer and listen for the fan to come on and see if there are any changes in the boot process. If it boots then starting with the memory reinsert one of the modules and reboot. Repeat the process till you find the culprit. You may find that after reinserting everything its still working. You may have lucked out and just had an EIO card or memory module that had a bad contact or you may have an intermittent fault that will reappear again. If nothing has changed can you give me more details about what you observed or heard during the boot process: - Does the fan come on shortly after you power on? - What displays during the boot process besides the memory check? -You mentioned the last thing you saw; does that mean the LED went blank? Let us know what you find out and don?t forget to rate the posting.
Posted on Jan 06, 2007
  • 99 Answers
SOURCE: i am getting a dotted line when I print on my hp
that dotted line is produced by one of you toner cartridges,put attention to what color the dots are and replace the cartridge.
also there is an option in the menu to disable the cartridge check ,do that under "diagnostics menu" and start taking 3 cartridges the first time and print something,check if dots are present,if not put another cartridge print something and check ,repeat process until you find the defective one.
Posted on Sep 14, 2009
  • 202 Answers
SOURCE: clean cycle/Test
press menu and you will see a list on the list find print quality press enter and another list will appear. Find create cleaning page and press enter. A page will be printed, follow instructions on the page printed.
Posted on Apr 01, 2010
  • 202 Answers
SOURCE: my hp laserjet is printing shaded
What do you mean by printing shaded.
  • 304 Answers
SOURCE: How can I perform an
NVRAM initialization
CAUTION NVRAM initialization will erase all network settings. Before performing NVRAM
initialization, print a Network Configuration page, which contains network-setting information.
NVRAM initialization performs the following actions:
? Resets all customer-accessible menu settings via control panel and software back to the factory
default settings
? Resets the language to the value set at the factory
? Resets the default media size to cold reset media size
? Resets the symbol set to PC-8
NOTE The following steps reset the same NVRAM locations that are reset using the
Restore Defaults option in the control panel Service menu. The following process should be
used if the MFP does not come to a Ready state and an NVRAM initialization is desired.
Use the following procedure to perform an NVRAM initialization.
1. Turn off the printer.
2. Press and hold the Right arrow and Cancel buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
When the NVRAM init is complete, the printer returns to the Ready state.
Posted on Aug 02, 2011
Error code 59.90 on color laserjet 470
59.9 is SCANNER MOTOR ERROR.
It is a rather tough part to service.
The entire scanning assembly would have to be replaced.
see
HP Color LaserJet 4700 Series Printer Numerical Control Panel Error...
Nov 01, 2016 | HP LaserJet 4700 Printer
Laserjet 4700 49.4cf2
Clear the print queue and power cycle the printer. One of the jobs your are trying to print is bad.
Jul 10, 2014 | HP LaserJet 4700 Printer
Printer does not reset
HP tech support might help you in this matter you can reach them directly on this number (877-690-9305) or just follow the link Support For Hp Printer
Apr 18, 2013 | HP LaserJet 1200 Printer
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
How can I perform an NVRAM initialization with my HP CM1015 MFP
default settings
Aug 02, 2011 | HP LaserJet CM1015 MFP All-In-One Printer
How can i reset factory defaults on my hp laserjet 3600. goal is to clear non-volatile memory (if any)
To perform an NVRAM initialization
1. Turn the printer off and then on.
2. When the printer begins its initialization sequence, press and hold down arrow until all LEDs are lit.
3. Press up arrow one time, and then press Menu.
4. Press down arrow until NVRAM INIT appears, and then press check mark.
Make sure that you print out a config page first.
Jul 07, 2011 | Office Equipment & Supplies
When trying to print it says
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults.Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Aug 30, 2009 | HP LaserJet 3015 All-In-One Printer
Fax Memory full
please perform the following:
When a super NVRAM Init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM Init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM Init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
Sep 10, 2008 | HP LaserJet 3050 All-In-One Printer
Hp 2300 laserjet printer error code 13.20.00
this problem persist NVRAM resetting
To perform an NVRAM initialization, complete the following steps:
1 Turn off the printer.
2 Press and hold (DOWN arrow), and turn on the printer.
3 When all three status lights are lit, release (DOWN arrow) and press (UP arrow).
4 Press PAUSE/RESUME. The first item of a menu appears.
5 Use (UP arrow) or (DOWN arrow) to scroll to NVRAM INIT, and press (SELECT).
cihat ALTIN FROM TURKEY ANKARA
Jul 16, 2008 | HP LaserJet 2300d Printer
Low memory display on HP Laser Jet 3050
Hello All,
Please perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
To perform a super NVRAM init
1.
Mar 10, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 4700 Printer Logo
133 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
