Question about Nikon COOLPIX L18 Digital Camera
Lens Error Hi This is Amitav Roy from Bangalore ,My Nikon L18 Camera shows Lens Error whenever I try to switch it on.The screen is empty and the focus doesnt even open.PLease help me out. My mobile number is 9844002154
  • 2 more comments
  • lizhud3 Jan 05, 2009
    I have the same problem, but my lens is open and will not close. Talked to someone at Nikon and they suggested that I send It in for repairs. Has anyone done that and what did they do ? Repair or replace? Was there a charge or did warranty cover it? Any info would help/
    Thanks
    Liz
  • married2004 Jan 19, 2009
    same thing, lense stays open, green light appears, lens error shows up etc. very frusturating
  • erprash Feb 09, 2009
    same problem with me,
    they give me estimate nearly equal to new camera's price.
  • jimjadi Feb 14, 2009
    They tell you it will cost $119 dollars to fix it which is more than the camera.
Camera shows Lens Error whenever I try to switch it on.The screen is empty and the focus doesnt even open.PLease help me out. My mobile number is 9460746537
Posted on Jun 11, 2009
  • 4 Answers
Well don't play with ur lens on ur own give it to the ppl they will repair ur lens and give them a phtocopy of ur warranty card.
But yes if the problem persists thats is the test they do after repair they might cahe ur camera .....But there are slime chances for an exchange
Posted on Jan 10, 2009
My nikon L18 coolpix camera shows a lens error when turned on...
If the lens is stuck at an angle, you can try and SNAP it back towards the center to straighten it out. If it's not at an angle then the lens needs to be replaced. Sorry I don't have better news than that.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Nikon COOLPIX L18 Digital Camera
L18 lens error
From Nikon site...
Why does my camera show "lens error" on the screen?
Having a "Lens error" message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
Remove and recharge the battery. Retest.
If this does not help, then we regret the camera must be sent to our Nikon Service department as there are no user serviceable parts on Nikon Coolpix cameras.
Additionally, this link could helpfull: fixing-lens-error-on-digital-camera.html
Hope helps (remember to rate and commet this answer).
May 12, 2011 | Nikon COOLPIX L18 Digital Camera
Nikon COOLPIX L18 Digital says lens error!
Sometimes the lens is just stuck, sometimes it needs to be replaced. Try to mechanically move the lens in and out by gently twisting, pushing and pulling. If that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Apr 19, 2010 | Nikon COOLPIX L18 Digital Camera
Lens Error
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon-authorized service representative."
Dec 23, 2009 | Nikon COOLPIX L18 Digital Camera
Lens error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Jul 25, 2009 | Nikon COOLPIX L18 Digital Camera
Lens Error on L18
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 23, 2009 | Nikon COOLPIX L18 Digital Camera
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon Coolpix: lens goes in and out of focus, then LENS ERROR
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 10, 2009 | Nikon COOLPIX L18 Digital Camera
S210 coolpix lens error and wont focus
Mar 31, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
268 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
