Question about Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television
Mitsu 47 inch tv's red light convergence is off!
We have tried using the tv's menu to fix the convergence but the red is off. We have heard this is a common problem with these tv's. The red in the screen is off and on a dvd's menu, for example, the red will be on the right of one letter and in another word on the other side of the screen the red will be on the left. How can we fix this without spending $300+ dollars on a repairman?
    Genius:
  • 1,694 Answers
The solution involves replacement of STK393-570 IC , which is
usually done by a skilled tech.........T.
Posted on Nov 09, 2007
SOURCE:
It will turn on, but as soon as the bulbs light up, the tv will go blank and the red power light will start blinking.
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 13, 2011 | Panasonic PT-47X54 47" Rear Projection...
Convergence
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Aug 12, 2010 | Samsung HC-P4752W 47" Rear Projection...
HDLP50W151 50 in. Rear Projection HDTV Television: have a 48 inch rca projection tv and the picture i...
  • Screen looks 3D
May 17, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
I have purple & green shadows on my panasonic rear projection tv
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Ther is a red line on the left side of the tv the blue an green is alright but it looks like it is in 3D i have tried to line the conrv- but still nothing the red is shifted 2 inchs to the right
  • Screen looks 3D
Jan 04, 2010 | Mitsubishi WS-48515 48" Rear Projection...
Been a while forgot what color but one color won't convergence
  • Screen looks 3D
Dec 29, 2009 | Panasonic PT-47WX42 47" Rear Projection...
My picture is shadowing itself like dual images and the colors seem to be separating, like the red from green. Is this repairable and is it worth it?
  • Screen looks 3D
Jun 27, 2009 | Panasonic PT-47WX51 47" Rear Projection...
Out of focus
You have a convergence problem, probably the convergence electronics are going out or the TV has been violently moved and needs a mechanical alighnment. Small adjustments can be made from the menu.
May 17, 2009 | Mitsubishi WS-55859 55" Rear Projection...
TV turns off by itself
  • Screen looks 3D
Feb 03, 2009 | Panasonic PT-47WX49 47" Rear Projection...
HD issues with ws-55805
  • Screen looks 3D
Sep 30, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
