Question about Amana Washing Machines
Amana front load washer nfw72ootw washes ok starts to pump then stops
Pump ok
jsrock516
  • 5911 Answers
SOURCE: Calypso kenmore elite - problems trying to wash a load
This is usually a symptom of a bad motor control board which located under the console. I had the same problem. You can open the console by removing the three screws in the back and lifting from the rear first. The console will pop off. In addition, if you look along washer top front edge in the seam there is a retaining clip about 2 inches in from each side. Using a putty knife, push in on each clip while lifting and the top should pop up. There will be a tech sheet affixed to the front wall of the washer between the wash tub and case. This tech sheet will give you all the guidance necessary on how to perform tests to prove whether or not the motor controller is at fault, or if the pump is at fault. I believe you may have a motor controller problem, though. Another possibility is getting something caught in the drain pump reservoir. This could binding the pump. Let me know if any of this is helpful to you.
Posted on Aug 16, 2007
  • 125 Answers
SOURCE: our amana nfw7200tw front load washer won't drain.
You can access through back panel. But before you do, make sure there is not a kink in the drain hose, it is very common
Posted on Aug 20, 2009
57 varieties
  • 1653 Answers
SOURCE: e10 code on my kenmore front loading washer
This can mean 1 or 2 things
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
OR it could mean
Motor Control Unit (MCU) Heat Sink Thermal Trip
If the thermal protector on the MCU heat sink gets too hot, it will open the thermal protector on the heat sink which will stop motor functions and an "E10" will be displayed
  • Check for Proper Installation, verify the unit is not located near a source of heat and has proper ventilation.
  • Check Wire Harness connectors to the MCU, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check Motor
Posted on Oct 30, 2009
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Posted on Nov 18, 2010
My amana front load washer, model NFW7200TW won't drain it gets down to 8 min of cycle and stop and display nd code. Check pump, fine also I can open washer door when it get stuck in this mode
remove the drain hose from back to see if there is any foreign object stuck in there , if washer faults out on code its common for door to unlock
Aug 16, 2016 | Amana Washing Machines
Whats so tricky about the repair?
Amana Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Amana-Washing-Machine-Parts
Huge selection of Amana Washing Machine parts in stock. Same day ... A small leak in front of the washer could be caused by a defective pump. OEM Part ...
www.repairclinic.com/Shop-For-Parts/a11/Washing-Machine-Parts
Find your parts fast and repair your Washing Machine with our free repair help. ...Admiral · Amana · ARDO · Asko · Bosch · Crosley · Danby · E-Wave · Electrolux · Estate ..... A small leak in front of the washer could be caused by a defective pump..... Washing machine door lock and switch assembly for front loading washers.
How To Fix Front Load HE Washer Does Not Dispense ...
removeandreplace.com/.../front-load-he-washer-does-not-dispense-deter...
May 15, 2015 - HOW TO REMOVE WASHING MACHINE SOAP DISPENSER ...
Jan 10, 2016 | Amana Front Load Washing Machine Washer...
I have a amana washer my drain line was froze. but now the lights don't come but i can hear the pump huming. Could the pump be froze or is there a reset button I don't know about?
If the lights are not coming on, but you hear the pump, it could be stuck in the force drain mode. Let it run for about 2 minutes and see if it stops on it's own. If it does stop, try putting the unit into a regular cycle, if it lights up, you should be ok. If the pump does not stop, and lights are out, replace your control board. Make sure you follow recalibration instructions for machine to work properly.
Feb 15, 2015 | Amana NTW4650YQ Top Load Washer
My amana nfw7200tw needs a new drain pump. ive been online trying to find the best deal and i acaully have found a few (for a really great price) that pop up when i type in the washer model # and the
make sure it a drain pump, they same will fit Samsung ,amana and Maytag, make sure it not just stopped up remove it and look at the impellers, i put one in to find out it was the water sensor was soaped up and telling the washer it was full when it was empty and i would get a nd on the front , no drain,Matt, need the answer to fix that let me know.
Sep 21, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Amana front load washer how to clean water pump
remove the hoses and and remove the pump then use coat hanger to try to clean inside pump and try to turn propeller by hand depending on ur model some pumps cant be taken apart depending on either direct or belt driven ones
Aug 09, 2014 | Amana NFW7200TW 27-in. Washer Front...
Washer will not advane from wash to rinse
It sounds like, when the dial gets to the pump stage, the contact expected to pump the water out isn't making contact. That could be a burnt contact within the controller, or a loose wire to to the pump from that section of the controller. Once the weight, or water level was low enough from your pumping it out, the sensor that checks the level/pressure allowed the spin. The problem could be on the control board too.
Here's an incomplete schematic I found:
http://www.doityourself.com/forum/electric-large-kitchen-home-appliances/474475-front-load-washer-amana-model-nfw7200tw.html
Jan 02, 2014 | Amana Front Load Washing Machine Washer...
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washing Machines Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
