Question about Water Heaters
Halstead boiler won't stay lit - Water Heaters
  • 44 Answers
SOURCE: how to check if pressure switch on halstead boiler 82 combi
Hi I am thinking what your tryig to say is the air pressure switch?
you can check this switch to see if the boiler works by removing one of the sensing tubes from it & by sucking on or blowing as this willactivate the switch you dont have to do it very hard, just gently as you will hear the switch clicking, if the boiler does fire when you click, in order for it to continue to ignite you may have to fold over the tube, when you release it the boiler should stop.if it does work then you will have to change the air pressure switch, but remember this can only be done by a Corgi Engineer
Kindly
Richie
Posted on Dec 20, 2008
  • 659 Answers
SOURCE: Halstead Finest Gold Combi Boiler water input temp
I know of no limitations on the temperature of the inlet water for any boiler. The warmer the water, the less energy it will take to heat it to desired temp and the colder the water, the more energy it will take. Extreme temps over an extended amout of time in either direction can stress a unit and could possibly, only possibly reduce service time.
Posted on Mar 31, 2009
  • 9 Answers
SOURCE: Halstead boiler reluctant to stay on
next time it turns off let it cool and clean with a cotton swab with rubbing alcohol after brushing.
Posted on Sep 08, 2009
stug_57u
  • 99 Answers
SOURCE: I HAVE A HALSTEAD ACER HIGH BOILER AND IT IT IS
The overload button is on the left underside of the unit. There is a finger sized hol and the button is in there. Once you have reseet the button you will also have to reset the boiler by using the switch on the control panel (furhtest left switch).
Posted on Feb 25, 2011
  • 1015 Answers
SOURCE: Pilot won't stay lit, replaced thermalcouple but
I would remove pilot light assembly and clean orifice and blow out gas line to pilot. Check to see that thermocouple is centered in pilot flame. It is possiblethat your gas valve is bad but it is also possible that you got a defective thermocouple. I would change the thermocouple again as they are much less expensive then the gas valves. The next time when you are sure you have the thernocouple mounted as close to the center of the pilot flame hold the pilot button down for several mins. If none of this works then you may have to change your gas valve.Thank you.
Posted on May 06, 2011
Halstead free standing boiler ignition working but no hot water or heat?
Does the gas valve click/clunk? In the fan operating. Need to know more
Mar 03, 2014 | Water Heaters
I HAVE A HALSTEAD ACER HIGH BOILER AND IT IT IS SAYING LOCK OUT ON THE BOILER WHAT CAN I DO TO FIX IT
Dec 03, 2009 | Water Heaters
I have a Halstead High Ace which will not light up the light flickers then goes off we have fitted a new dectection electrode but still will not light the boiler We also have flushed the system out ....
sounds basic, but make sure the electrode is in the pilot flame
check the overheat thermostat is not jammed on
disconnect and join wires together for temporary override check and run boiler.
Nov 14, 2009 | Water Heaters
Aug 31, 2009 | Water Heaters
Heating circuit getting hot when hot water is running
Check to see if diverter valve is in domestic mode or heating mode.
Jul 04, 2009 | Water Heaters
Mar 31, 2009 | Water Heaters
How to check if pressure switch on halstead boiler 82 combi
Kindly
Richie
Dec 17, 2008 | Water Heaters
Water Heaters Logo
56 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
