Question about Sony VAIO VGN-N130G/W Notebook
Sony laptop VGN-N130G will not boot.
Info: Window failed to load because the system registry file is missing
or corrupt, I can not find my recovery disk. and will not boot in safe mode. can creat a boot disk and boot from there, If so what file to I use, and where can I creat a boot disk?
  • 565 Answers
Use any windows xp disk boot from it and use R key to repair windows then type fixboot
if helped rate fixya
Posted on Jan 05, 2009
Windows help support
do you have your boot disks that came with your comp. what version are you running
Aug 20, 2014 | Microsoft Windows 7 Home Premium 64BIT...
\windows\system32\kdcom.dll Missing or corrupt Kernel debugger
Try tapping F8 at bootup to enter safe mode, read your manual to see if you have a recovery partition on your HDD. You didn't post the model so I have no clue.
If you can enter safe mode you need to try system restore, not last good know configuration.
If you see last know config on your screen, then you should also see safe mode.
So you need to run in safe mode, and run system restore, or run the recovery mode if you have a recovery partition on the HDD.
If none of these work, then you only have three options, go to Avira.com, download the rescue disk, burn it to a CD and run it in DOS, this is before windows boots. Now if malware corrupted the DLL, Avira will kill it, but there is a chance it can't clean it and will destroy the files,DLL, and windows won't boot. So now you have to do below.
The other option is you need to download windows, what ever version you have, if you have win 7 home 32bit, then you have to download it, and burn it to a DVD. Then try a repair, if a repair does not work then you need to reinstall windows, and then install all the drivers like, (chipset, video, sound, lan, wifi)
This option, you can contact Acer and see if they have a recovery disk for you.
Good luck.
Apr 01, 2013 | Computers & Internet
When i turn on laptop i get a reading ,"window failed because system registry file missing or corrupt.have no back up disk.how can i fix?
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option
if you need more help with this poat a reply
hope this helps
Aug 26, 2011 | Compaq Computers & Internet
Error code in windows vista 64 bit ''0xc00000e9 - windows failed to load because the system registery file is missing or corrupt''
If it is a system registry error, boot up in safe mode and run CHKDSK/F this may find errors on the hard drive. To do this press Start and type CHKDSK/F into search box then run it.
You may have to purchase a registry utility.
Jan 11, 2011 | Computers & Internet
My Window Xp on my mini note book a file has been corrupt file missing so it wont load windows
Try booting in safe mode.
Switch on you note book, while its booting press F8 several times, this should bring up a black screen with several boot options, choose "Safe Mode"
This will load windows shell programme.
Once loaded click on Start - All Programmes - Accessories - System tools - System Restore.
Select a restore point prior to when you first had a problem and let your pc do the rest.
If you can't do a system restore for what ever reason, you'll have to do a system recovery, this tends to dump your data.
Nov 13, 2010 | Computers & Internet
The file in computer missing or corrupted
Will it boot to safe mode? If so, run chkdsk and have it do a through scan and fix all errors. You can do this via a bootable rescue disk or the Windows CD if safe mode does not work either.
If running chkdsk doesn't work, you'll have to extract the missing files from the Windows CD using the Recovery Console. If that doesn't work, then it's time for a repair install using the Windows CD.
Mar 17, 2010 | E-Machines etower 633ids PC Desktop
Gateway laptop modle mx8711 windows failed to load
Try to start in safe mode and then when it finished loading shut it down again. Boot again it should boot to windows if it not, maybe a corrupted files or some files are missing.
Apr 01, 2009 | Microsoft Windows? Vista Home Premium...
Ze2000
Do you have a recovery disk?
Insert the recovery disc, (if auto run starts up, just close it)
Go to Start>Run and type cmd and hit enter.
In the DOS command window, type sfc /SCANNOW and hit enter.
That will check your Windows files against the Windows files on the disc. If it finds corrupted or missing ones, it will repair or replace them. You will not lose any data or files this way. (If it will accept the disc again)
Jan 09, 2008 | HP Pavilion ze2000 Notebook
Sony VAIO VGN-N130G/W Notebook Logo
343 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
