Question about Refrigerators
LG Refrigerator - Lights on inside the refrigerator however the digital display is not working and the refrigerator is not cooling. I reset the breaker in my basement (althought it wasn't tripped
Lights on inside the refrigerator however the digital display is not working and the refrigerator is not cooling. Refrigerator is getting power. I reset the breaker in my basement (althought it wasn't tripped) and everything worked for a few minutes, and then went back out again when the compressor kicked on. Everytime I unplug it and plug it back in it works, but only for a few minutes.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 07, 2012
  • 958 Answers
SOURCE: Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Posted on Feb 19, 2008
22yooper
  • 828 Answers
SOURCE: LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
Posted on May 19, 2008
  • 63 Answers
SOURCE: Refrigerator cools as normal. Trips 15 AMP circuit breaker.
a full size refrige has to be on a 20 amp circuit, a 15 amp is just not big enough.. you should also know that this circuit has to be on a 12-2 gauge wire.. I also highly recommend installing a 20 amp HD receptacle
Posted on Mar 20, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Maytag, side by side refrigerator stopped working
Check the thermostat which is located in the top left hand coner of the refrigerator. Also check the relay on the compressor to make sure it is not staying open all the time. Also there has been a huge recall on Maytag side by side refridgerators made between 2001 and 2005. I would also try calling Maytag and get the problem fixed by them by recall
Posted on Apr 13, 2009
  • 3 Answers
SOURCE: GE- GTS22WC refrigerator. Both the refrigerator
The auto defrost heat element is not working. When the ice buildup clogs the airflow the unit stops cooling. Once you unplug it and give it a chance to melt it works again. You need to have the defrost unit replaced.
Posted on Jul 09, 2009
I have an LG fridge display giving me ER F1 code. i can unplug the fridge and plug it back in and the display resets for about 2 minutes and the the code comes back?
The ER 1F code usually means that there is a problem with the ice compartment fan, the ice maker motor or one of the control boards (the one for the ice maker or the main control unit). You can try resetting the refrigerator by leaving it unplugged for a day. Next check for ice build up on the fan that is blocking it from turning. Usually, if the fan hasn't been turning, you will have to at minimum replace the motor. It will burn out trying to force the fan to turn.
Sears Parts Direct has a diagram of the LFX23961SW case parts here: http://www.searspartsdirect.com/lg-refrigerator-parts/model-LFX23961SW/3204/0161000/K0810254/00001.html . The fan motor is part 405G.
I hope this helps.
Apr 15, 2015 | LG LFX23961SW French Door Refrigerator,...
Cabinet not cooling, when i go through the test sequence the cabinet works perfectly the display shows all lights illuminated is this a sensor fault and if so where are the sensors?
The lights inside the refrigerator are not turning off when you close the door .
The light switch is broken. replace the door operated light switch.
Nov 26, 2010 | LG LRSC26920TT Side by Side Refrigerator
GE refrigerator is not working. the lights are on in the inside of fride and freezer but the fridge isn't running. My external digital temperature controls, water dispenser, ice cube dispenser, is not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
qrtgfs
Jun 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator section not cooling
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jun 20, 2010 | LG LFC22740 Bottom Freezer French Door...
Refrigerator is not cooling.Freezer is working normal.Display in refrigerator reads 5 6 7 LG model #LRBN22514ST
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Oct 25, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Freezer and Refrigerator are not getting cool enough
there is more ice built up behind the panel
defrost is not working
Jun 27, 2009 | LG 26 Cu. Ft. Side By Side Refrigerator...
Refrigerators Logo
158 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
