Question about Gem Sound GemSound PA-585 2-Channel Amplifier
Gem sound 3950
My exa 3950 ihas been burning the fuses conected to 2,singles 18 peavey subs400rms@8ohm on bridge mono1400w @4ohm,,, on daysi chain
    Genius:
  • 1,175 Answers
Hi...
Does it pop fuses run in stereo mode?
Can you get ahold of a DC voltmeter?
If there is more than 0.200 volts on the speaker terminals, you'll need to have it serviced
Posted on Jan 08, 2009
  • 85 Answers
Dc problem in amplifier (short circuit) needs to be serviced
What is the actual watts per channel @ 8-ohms and 4-ohms on the Behringer PMP3000?
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
Aug 16, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
How do I wire up my 4subs in bridged to my peace 2600
Please state the subs impedance, but assuming 4 subs with 8Ohm Voice Coil you CAN'T run them in parallel in Bridge Mono because this amp's minimum impedance is 4Ohm in bridge and 2Ohm stereo, maybe a series/parallel connection work, but what's the advantage to run them in Bridge mode? This amp delivers 900W per channel at 4Ohm, you can run a pair paralleled for each channel in a safe way and without the high-risk of your amp being destroyed, besides, amp power at 4Ohm Bridged is NOT recommended for continuous use, let me know your results...
May 13, 2012 | Peavey Pv 2600 Power Amplifier
Hi, I want to know what is the best way to wire these subs. (Pair). I have heard of several ways. I have a 4 channel amp the soundstream picasso 4.760. Bridged it produces the most power. I was told...
Hello , I will be glad to help you.As far as your speakers..It depends on what impedance your subs are rated and if your Picasso amp can be bridged at 4ohm or 8ohm. If your subs are 8ohm each you can wire your subs in parallel and wire them to picasso amp in bridged mode. If your subs are 4ohm each.Then wire the subs in series then wire them to amp in bridged mode..caution do not wire subs in parallel if they are 4ohm .This would bring impedance to about 2 ohms and would be harsh for amp to handle...Goodluck
Sep 22, 2011 | Planet Audio BB212D Car Speaker
Wat does the peavey 2600 do in a 2ohm stereo & a 4ohm bridge
It burns up...You are allowed no less than 4 ohms stereo or 8 ohms bridge mode.
Jan 14, 2011 | Peavey Pv 2600 Power Amplifier
Peavey Horn Drivers (compression drivers)
Did you sort your problem? I need 2 also, but seems quite easy to get 4ohm but 8 ohm a little harder. The woofer in the cab is 4ohm, cabinet is rated 4ohm so wondering wether to replace th 8ohm horn with a 4ohm diaphram.
Any thoughts?
Thanks.
Nov 26, 2009 | Peavey Audio Players & Recorders
How many speakers and woofer solid audio f2000 2 channel amp can support ?
  • 8ohm Stereo / 1200 W
  • 8ohm Bridged / 3400 W
  • 4ohm Stereo / 2000 W
  • 4ohm Bridged / 4300 W
  • 2ohm Stereo / 2900 W
  • it can support 6 but i would use 4 but make sure the subs have more watts than the amp
    Jul 11, 2009 | Solid Audio Formula Series F2000 2-Channel...
    Gem sound exa-3950
    You could check the 115/230 switch. If you are getting power to the unit no fuse or circuit breakers tripped, and you have 8 ohm speakers connected, and a signal in you should get a signal out. Level controls should be up. If all of those things are true, then the amp is broke and needs an electronic technician to repair it.
    Jan 01, 2018 | Gem Sound GemSound PA-585 2-Channel...
    Gem sound exa 3950 amp
    Hi...
    If it's a straight-up power switch then it will need to be replaced if it works off a relay then the relay is gone.
    website
    http://www.gemsound.com/contact.html#
    Mar 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
    Gem Sound clipping problem
    First of all the EXA-3940 is rated at 350watts per channel in to 8 ohms. The 1400 watts is bridged into a 4 ohm load. Second, the speakers can handle 1000Wats peak with an average of 600 continuous (i'm guessing). That tells me that the amp is underpowered for the speakers. The sensitivity of the amp is such that the mixer is overdriving the input stage. That is what is causing the clipping. If you are looking for more volume, you are probably better off purchasing another amp and running them in bridge mode, 1 per speaker cab. Be careful though, not to overdrive the speaker cabinets either.
    Dan
    Sep 21, 2008 | Gem Sound GemSound PA-585 2-Channel...
    Gem Sound GemSound PA-585 2-Channel Amplifier Logo
    267 people viewed this question
    Top Gem Sound Audio Players & Recorders Experts
     Grubhead
    Grubhead
    brian williams
    Are you a Gem Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
