Question about Kenmore Elite 45986 Front Load Washer
My HE5t has power, but when i press start botton it making that clicky sounds, no water was coming in? anybody know what the problem is? and i opened the filter area located in lower front and i see nothing was stuck? what could it be ?
  •  Emilio L
    Emilio L Nov 06, 2012
    and the water volve was turned on when I pressed the start button.
  •  Emilio L
    also didnt get any error message. thank you so much
Do u have both hot and cold water hooked up? if not u need to switch the buttons from hot to cold supply
Posted on Nov 08, 2012
  • 3 Answers
SOURCE: Kenmore Elite He5t front load waher
hey there is a temo fix till some body comes to your home if you remove the soap try and reach in to the back of the opening you can rest the spring loaded wheel that controls the soap disspenser and that will stop the clicking and allow the machine to run!!!!! after reading all the post i could find i figured it out now my washer is running fine!!!
Posted on Aug 09, 2008
mgprice
  • 744 Answers
SOURCE: He5t Kenmore ELITE front load washer flashing f35 code
Hi, Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch. If you have any further questions or concerns please feel free to comment again, Good luck.
Posted on Jul 07, 2009
  • 172 Answers
SOURCE: I can't even turn it on.
Try sears service dept
Posted on Aug 11, 2009
  • 1937 Answers
SOURCE: drum full of water.wont go into spin cycle. it
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The Sears site for your washer may have a section on the gearcase. Check in that section for a Neutral Drain repair kit.
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
http://www.fixya.com/support/r699497-replacing_gearcase
OR ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Oct 08, 2009
blueextc3221
  • 15935 Answers
SOURCE: My HE5t front loader not powering on
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
Daewoo side by side no water
Could it be that the plumber installed the water line but then did not turn the water on? That's what it sounds like. The sound you hear is just the solenoid valve. It just uses the static water pressure of the household -- no pump.
Don
Mar 24, 2012 | Daewoo Refrigerators
My Star mobile is restarting if i play some Video
Dear Friend,
Do the Following
  • Power the phone on. The phone should go through the basic start-up and come to rest on the main screen.
  • Press the "Menu" button and find the "Settings" option, then "Reset Settings." You may have a "Restore Factory Settings" option here, or a more extensive menu that lets you choose what to reset, such as sound settings, display settings, phone settings or all.
  • Reset the phone by choosing "All" or "Restore Factory Settings." Press the "Yes" button when the phone asks you to confirm that you want to reset it.
  • Power cycle the phone, and when it comes back on you will be able to reconfigure your settings correctly.
Then Play your video ..... I like to know Feedback... Hope this Make you Better.. Thanks For Contacting FixYa
Apr 19, 2010 | Samsung Star GT-S5233 Cell Phone
How do i lock my keypad on my nokia 5130? Thanks
hello,you can kindlyb follow the shortcut procedure below,
press MENU>AND STAR BOTTON ON YOUR KEYPAD.BUT YOU HAVE TO MAKE SURE IMMEDIATELY YOU PRESS THE MENU BOTTON YOU CLICK ON THE X BOTTON ON THE BOTTOM LEFT OF YOUR MOBILE PHONE IN NOT LESS THAN 2 SECONDS.
THANKS FOR USING FIXYA.
TAKE CARE.
Apr 06, 2010 | Nokia 5130 Cellular Phone
I build a new password but now i forgot it
1.press Menu botton and then quickly press * (star) know your cell phone in lock mode.
2.know press unlock botton for three scends and then quickly press * (star)..
Mar 07, 2009 | Nokia 1110 Cellular Phone
Wont power on
Good day, papamotts;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
Jun 21, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
X5 -alarm system can't be activated
I press the remote control middle (BMW) botton, one time to set up the alarm, when I release the alarm, I press the one above the
BMW botton one time, this botton control driver side door too, if I want to open other three doors, I have to repress the same botton one more time.
Hope this can help .
May 17, 2008 | 2002 BMW 5 Series
Belt stops running and clicky noises
If this is top loader the gearbox is faulty. Regards Advisor
Aug 23, 2007 | Maytag Performa PAV2200
Kenmore Elite 45986 Front Load Washer Logo
35 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
