Question about Sentry Security Safe with Electronic Lock with override key
Factory code for sentry model A3550
Need to open safe no key
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
SOURCE: sentry safe msw3517
I have a Sentry Safe MSW3517 and forgot my code.
Posted on Nov 19, 2008
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
SOURCE: factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Posted on Dec 18, 2009
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    Lost factory code for sentry safe model #d8W5840
    did you ever find the factory code? I lost mine also. if you have the factory code for this model please message me on facebook.com/vernhartjr
    Sep 09, 2012 | Sentry Safe Sentry Fire-Safe Combination...
    I have a sentry safe model s0310 i lost my combination but i have the key but it doesnt work how do i open it!
    Hi Juli, if you still have the manual, there is a factory code printed on the beginning page and that code can be used if you forgot your code. The factory code can never be deleted. If you dont have your manual anymore then the only other option is to call the company and they might be able to give you the factory code somehow.
    Sentry Safe Customer Service - 1-800-828-1438
    Feb 12, 2011 | Sentry Fireproof Safe
    Need to open a Sentry keyless combination safe
    First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
    If the factory combination has been changed to something else, then Sentry won't have it.
    In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
    The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
    You can take it from there.
    Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
    They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
    Get 'hold of Sentry on the web and the rest is just process.
    BTW -- this is exactly what the locksmith would do.
    Apr 10, 2009 | Sentry Fireproof Safe
    Sentry Safe A3750 won't open new batteries
    http://www.sentrysafe.com
    call them
    mj
    Feb 22, 2009 | Home Security
    Sentry codes v260
    You should have received two skeleton keys when you bought the safe. They will open the safe without the key AND without the code. If you don't have it, the only solution is to get help from Sentry. By following the instructions below, they will send you a skeleton key for your safe. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe (outside). Send this, a notarized letter(last name must be different) stating you are the safe’s owner, and a check or money order or $8.00 (U.S. funds) to:
    Sentry Group Dept. 200
    882 Linden Ave
    Rochester, NY 14625-2784 If using a credit card (Visa/MasterCard only), call 1-800-828-1438.
    Oct 19, 2008 | Sentry Fireproof Safe
    My sentry safe will not open after entering the code it reads "err"
    You have to press the program / enter button after you enter the code How to open electronic sentry safes.
    Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
    Aug 10, 2008 | Sentry Fireproof Safe
    How to open my safe with the code
    Apr 18, 2008 | Sentry Fireproof Safe
    Sentry Security Safe with Electronic Lock with override key Logo
    169 people viewed this question
    Top Sentry Home Security Experts
    Jim London
    Jim London
    Computer Repairing
    Computer Repairing
    Joseph Vernice
    Joseph Vernice
    Are you a Sentry Home Security Expert? Answer questions, earn points and help others
